WOT 4 Foam-E Mk.2
Manufacturer: Ripmax
Find more products by Ripmax
| Average Rating |
| No. of Reviews | 11 |
| RRP | N/A |
Dickster wrote on
18/08/2012:
COMPACT AND CONVENIENT
Strengths: Great 2nd plane, aerobatic trainer (the use i've put mine to). convenient flying, i leave mine assembled at all times - just charge and go. 20 min flight times.
Weaknesses: none really, ok, its foam and the undercarriage is weak/small. i removed mine for hand launching and belly landings.
Overall: superb out of the box (i've not touched anything on mine yet). difficult to beat as a hack. flies well on all conditions. everyone should have one!
| Ease of assembly |
| 80% |
| Build quality |
| 80% |
| Flight performance |
| 80% |
| Value for money |
| 80% |
| Overall |
| 80% |
Dave Robertson wrote on
06/04/2012:
REASONABLY GOOD VALUE
Strengths: Ease of assembly
Weaknesses: "NEW"ESC burnt out after 2 hours flight.
Poor Under Carriage design, useless on grass strips. Weak hinges on all control surfaces.
Overall: Great fun to fly.
| Ease of assembly |
| 60% |
| Build quality |
| 40% |
| 80% |
| Value for money |
| 60% |
| Overall |
| 60% |
Victor Saliba wrote on
03/05/2011:
EXCELLENT 1ST TIME IN ELECTRICS
Strengths: Model was put together in less than 30 mins, powerfull motor and well balanced. It's a Wot 4 after all.
Weaknesses: I found no weaknesses in this model.
Overall: This is a true RTF, plug and play. I'm a Wot fanatic and this is my 1st electric model, very impressed. The 3S 2200 battery gives about 13 mins of pleasure without having to clean it up afetr 4 flights.
| Ease of assembly |
| 100% |
| Build quality |
| 100% |
| 100% |
| Value for money |
| 100% |
| Overall |
| 100% |
brian fearnley wrote on
02/05/2011:
GREAT SPORT PLANE
Strengths: I must have a different model to other reviewers, had no problems (or any of the other 4 being flown on our patch)great fun model
Weaknesses: If your are really clumsy tail bracket and back up elevator hinges with tape to be sure
Overall: really cannot fault it great fun flies in almost any conditions- mine needed a lot of tail weight to make it really sharp
| Ease of assembly |
| 60% |
| Build quality |
| 60% |
| 80% |
| Value for money |
| 80% |
| Overall |
| 60% |
Steve W-O wrote on
11/03/2011:
GOOD CONCEPT, SPOILT BY POOR QUALITY
Strengths: Great idea
Weaknesses: Very poor quality, had to repair rudder and elevator, fit new servos, ESC and motor BEFORE flying. Wing tip had been broken and repair attempted at the factory.
No response or help from dealer.
Overall: Would recommend if they could get the quality and service improved, otherwise it turns out rather expensive.
| Ease of assembly |
| 60% |
| Build quality |
| 20% |
| 60% |
| Value for money |
| 40% |
| Overall |
| 40% |
Burnsmoker wrote on
08/03/2011:
EXCELLENT FUN FLYER -BUT!
Strengths: Flies well.
Weaknesses: The decals supplied are too similar above and below wing making orientation difficult.
Empennage retaining screw wouldn't take up so captive nut had to be re-tapped.
Foam tongue at base of fin which fits into plastic control shoe is stupidly flimsy.
Plastic moulding which retains u/c is too flimsy and won't stand a hard landing.
My ESC fried on first flight causing a crash. ESC and fuz replaced by Ripmax.
Overall: A great plane spoiled by poor design.
| Ease of assembly |
| 40% |
| Build quality |
| 20% |
| 80% |
| Value for money |
| 60% |
| Overall |
| 40% |
Robert Ayres wrote on
14/11/2010:
EXCELLENT FOAM-E
Strengths: Quality, Looks, Quick build, Strong.
Weaknesses: Extra 20g need at the rear.
Overall: Good trainer, intermediate and expert alike.
Nice power to weight combo.
| Ease of assembly |
| 80% |
| Build quality |
| 100% |
| 80% |
| Value for money |
| 100% |
| Overall |
| 80% |
Toby Mack wrote on
13/11/2010:
GREAT!
Strengths: Easy to fly (I'm using it for my A cert).
Good value.
Generally well thought out.
Weaknesses: Tail feels a bit flimsy although I have yet to damage it.
Airflow in battery area is poor - hot esc and battery until I made a simple fix.
tail wheel mount flimsy, mine also came bent but it has worked ok so far.
Small wheels and light weight means it noses over easily on wet grass. Larger wheels help a lot.
Overall: A great plane. With rates set as the manual I find it fine for practising for my A cert but will not get boring as I get better. Generally feels robust apart from the tail wheel although I have not yet done anything worse than "land" in long grass.
Another review states 215W. I get around 300W with an APC-E 11x7 which is close to the rated current of the esc but I have no problem now I have repositioned the ESC and added a reverse scoop to extract air from the battery area.
| Ease of assembly |
| 80% |
| Build quality |
| 60% |
| 80% |
| Value for money |
| 80% |
| Overall |
| 60% |
Bob Cotsford wrote on
11/10/2010:
GOOD BASIC AIRFRAME LET DOWN BY POOR ELECTRONIS
Strengths: flies well, easy to assemble, good finish
Weaknesses: very variable quality power train, the esc self-immolated on the first flight
Overall: A fast way to get in the air at a reasonable price, just needs a battery and RX (in principle), but in reality check the current drawn with a wattmeter and replace either the esc to cope with the supplied prop or the prop to match the 30A supplied esc
| Ease of assembly |
| 100% |
| Build quality |
| 60% |
| 80% |
| Value for money |
| 60% |
| Overall |
| 60% |
Allan Bowker wrote on
03/10/2010:
ALL THAT YOU EXPECT FROM A WOT4
Strengths: Sensible price, easy to build, easy to fly and quite robust for a foam model.
Good build manual.
Everything you would expect from a WOT 4, a very capable model.
Weaknesses: Beware of the quality of ESC and servo's supplied. May be better to fit your own. I have had a failed aileron servo on its second flight and have seen 2 reports of smoking ESC's.
Tail wheel hinge could be a weak spot, keep an eye on it.
Personally I would prefer more throw on the elevator.
Stickers may start to peel over time.
Stock motor is enough power but not immense, just enough to keep the smile on your face.
Overall: All up weight: 1097g (inc. 3S 2200mAh Li-Po & AR500 receiver)
Static power: 215watts @ 19amps (average)
The maiden flight went without a hitch and the CG seems to be about right as indicated in the manual.
Stickers could do with numbering and mapping them on the plan. A bit of trial and error was required to find their exact position. The bottom blue sticker would have been better to put on first and to the the cowl as a guide as to how high the side blue stickers should be positioned.
| Ease of assembly |
| 60% |
| Build quality |
| 60% |
| 80% |
| Value for money |
| 60% |
| Overall |
| 60% |
Slatts wrote on
31/08/2010:
EXCELLENT
Strengths: Very well thought-out and well engineered.
Weaknesses: Nothing really, I had to fit larger wheels for my grass flying patch. A bit floaty, doesn't penetrate a breeze too well.
Overall: Flys very well, use low rates initially. Climbs away on half throttle. Very light, glides well and even soars!
| Ease of assembly |
| 80% |
| Build quality |
| 80% |
| 60% |
| Value for money |
| 80% |
| Overall |
| 60% |
