Ian Jones Posted June 10, 2011 Share Posted June 10, 2011 Hi Mal, That looks so good, like the radial cowl and the smooth lines of the cockpit. Ian Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted June 11, 2011 Share Posted June 11, 2011 The BebBit... BEB Quote Link to comment Share on other sites More sharing options...
Steven Webb (Steve Webb Models) Posted June 27, 2011 Share Posted June 27, 2011 Thats a thread of WebBITs Lindsay Todds Cow WebBIT had grown horns by the time it got to Greenacres. Steve Quote Link to comment Share on other sites More sharing options...
Martyn K Posted October 23, 2012 Share Posted October 23, 2012 Very very late, but here is my humble offering - only completed and test flown last weekend.. Better late than never, but better never late.. Fully Dressed Naked... AUW 810g (incl 2200 3S). The biggest changes are intended to reduce drag, no undercarriage and a slimmed down fuselage profile (Sorry Steve). And here is the broken prop shaft (failed on full chat on the 2nd flight) Failed in mid flight at the circlip, note the granulation in the steel. A replacement motor (3536 1700kV) on order from GC. A few more photos here if you are desperate http://www.modelflying.co.uk/albums/member_album.asp?a=21677 Best wishes Martyn Edited By Martyn K on 23/10/2012 17:15:54 Quote Link to comment Share on other sites More sharing options...
Terry Walters Posted October 23, 2012 Share Posted October 23, 2012 Lindsay - are you from Milton Keynes? If so you will have to guard them against vandals! Very nice tho' and imaginative! Have you any udder ones? Are they original spec or beefed up? You can fly them in the Winter when it's Friesian weather! Terry Quote Link to comment Share on other sites More sharing options...
Ian Jones Posted October 23, 2012 Share Posted October 23, 2012 Posted by Martyn K on 23/10/2012 17:15:22: And here is the broken prop shaft (failed on full chat on the 2nd flight) Failed in mid flight at the circlip, note the granulation in the steel. A replacement motor (3536 1700kV) on order from GC. A few more photos here if you are desperate **LINK** Best wishes Martyn Edited By Martyn K on 23/10/2012 17:15:54 Do you think that if you put a lightweight wire undercarriage on it that it would offer some protection for the prop and therfore the drive shaft? Quote Link to comment Share on other sites More sharing options...
Andy Green Posted October 24, 2012 Share Posted October 24, 2012 Here's mine - no longer with us I'm afraid. Andy Quote Link to comment Share on other sites More sharing options...
Martyn K Posted October 24, 2012 Share Posted October 24, 2012 Posted by Ian Jones on 23/10/2012 23:41:56: Do you think that if you put a lightweight wire undercarriage on it that it would offer some protection for the prop and therfore the drive shaft? Hi Ian Clearly some protection, but it had only one previous landing which was very gentle (as you saw). I think it was a duff batch of steel looking at the granulation in the fracture. I suspect a harline crack formed when the circlip groove was cut and it was just waiting to happen. I may be tempted with a monowheel.. A 4mm shaft simply should not break, bend reluctantly, but NEVER break. The prop blades should have sheared before the shaft failed, even if the motor had seized solidly. Regards Martyn Quote Link to comment Share on other sites More sharing options...
Ian Jones Posted October 25, 2012 Share Posted October 25, 2012 Posted by Andy Green on 24/10/2012 09:19:19: Here's mine - no longer with us I'm afraid. Andy Sadly mine bit the dust too, well the top of a tree actually. I wonder how many mass build webbits are still live and well? Quote Link to comment Share on other sites More sharing options...
David Gilder Posted October 25, 2012 Author Share Posted October 25, 2012 Mines still around (although not flown for a while!) Bet there's actually quite a few!! Quote Link to comment Share on other sites More sharing options...
Andrew767 Posted October 25, 2012 Share Posted October 25, 2012 I wonder if Webbs could be persuaded to run another batch?. They've sold out........and i didn't get one. Andrew Quote Link to comment Share on other sites More sharing options...
David Gilder Posted October 25, 2012 Author Share Posted October 25, 2012 Best thing is to just give them a ring Andrew. I'm sure they are likely to still have 1 or 2 kits around! Tel : 01928 735252 or 01928 735225. Quote Link to comment Share on other sites More sharing options...
