Matt Halton Posted August 16, 2011 Share Posted August 16, 2011 Here is my Moth flying over an airfield. This is just a test vehicle, I won't be flying the Moth with the GoPro cam on board anymore, but have to say, the quality in r5 at 60 fps is stunninhg! I mounted the HD keychain cam above the upper wing centre section looking rearwards over the tail The plane was a pain to flddrity, and ch for my tastes heavy with additional ballast in the cowl to offset the camer's weight and position. It is panning using a 16 gram MG digital servo, worked pretty good! Next up is a tricopter I have started to build, which will be prefect to use with the GoPro. Cheers Matt Quote Link to comment Share on other sites More sharing options...
Matt Halton Posted August 16, 2011 Author Share Posted August 16, 2011 Was trying to edit my typos...was trying to say the model was very tricky to fly with the extra weight and additional nose ballasting, plus the rudder was suffering sitting in turbulence spilling off from the camera box. (edit function failed so am adding corrections here) Cheers Matt Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted August 16, 2011 Share Posted August 16, 2011 Very nice video Matt. In my personal view it will be a pity if that the last from the Moth - I like the view from there! BEB Quote Link to comment Share on other sites More sharing options...
Matt Halton Posted August 16, 2011 Author Share Posted August 16, 2011 Thanks BEB, I will keep the Moth for airborne videos, I will just take the GoPro out for my tricopter, remove some weight from the cowl, and just put my mini HD keycam in place of it, sitting on the panning servo, so all is not lost!It is an interesting perspective though, looking out from the cockpit. With the extra weight removed she will be her old sprightly self, and I can then fly aero's again, should look good, but the handling was pretty bad with that huge box and ballast on board. Incidentally, go to the YouTube site itself and watch it in 1020p if you haven't, the quality is superlative to say the least! CheersMatt Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted August 17, 2011 Share Posted August 17, 2011 Agreed! The quality is I think the best I've ever seen from an on board camera! BEB Quote Link to comment Share on other sites More sharing options...
Malcolm Fisher Posted October 19, 2011 Share Posted October 19, 2011 I once had the chance to fly in the front seat of a full size Tiger Moth from Duxford. The view from the camera was much better than my reality as I could barely see above the edge of the cockpit when looking forwards. Malcolm Quote Link to comment Share on other sites More sharing options...
