ericrw Posted April 15, 2012 Share Posted April 15, 2012 Is it ok, to put a 3" extention "Y" lead to the throttle and ubec lead from the esc and connect to the throttle aperture on the receiver? Or should I fit seperate extention leads to both?? This is necessary because of the position of the receiver and it cannot be moved nearer to the esc. Quote Link to comment Share on other sites More sharing options...
Codename-John Posted April 15, 2012 Share Posted April 15, 2012 thats fine, you can use a y lead for the ubec on any channel as the + and - are just commoned through the rx. 3 inches wont do any harm Quote Link to comment Share on other sites More sharing options...
Codename-John Posted April 15, 2012 Share Posted April 15, 2012 one thing tho, if your esc has a bec too, as well as your ubec remove the red cable from the esc / throttle connector and keep the one from ubec Quote Link to comment Share on other sites More sharing options...
ericrw Posted April 15, 2012 Author Share Posted April 15, 2012 I assume that as the info on my ESC, states that it has a seperate ubec ;means that it does not have a BEC within the esc. So there is no need to remove a red cable from the esc; or is the need still there ?? Quote Link to comment Share on other sites More sharing options...
Codename-John Posted April 15, 2012 Share Posted April 15, 2012 you dont need to do anything then, just connect em up and your away Quote Link to comment Share on other sites More sharing options...
ericrw Posted April 15, 2012 Author Share Posted April 15, 2012 Thanks John, I can now go flying tomorrow am; it's the only flying weather window this coming week ! Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 15, 2012 Share Posted April 15, 2012 Hi Guys, I've changed the title of this thread. The reason is that a big part of the value of the forum is the "archive" of answers. But you can only find answers with the search engine if there are appropriate key words in the thread title! So, good question - with a good answer. Deserves to be findable from a search! BEB Quote Link to comment Share on other sites More sharing options...
NigelH Posted April 15, 2012 Share Posted April 15, 2012 Posted by ericrw on 15/04/2012 19:37:45: I assume that as the info on my ESC, states that it has a seperate ubec ;means that it does not have a BEC within the esc. So there is no need to remove a red cable from the esc; or is the need still there ?? If it says that it has a BEC then I'd read that as it has a BEC. What else could it mean ? Or, did it say that you'll need a separate UBEC ? Which make and model is it ? Is it an opto one ? Quote Link to comment Share on other sites More sharing options...
ericrw Posted April 16, 2012 Author Share Posted April 16, 2012 The info on the ESC is as follows: Hobbywing Pentium 60A. Brushless motors, UBEC-3A/5v, Version 3.1, DC 5.6v-26v 60A. And I have fitted a indepedant ubec. The info on that reads, Hobbywing UBEC, 5A, Max7.5A. Input: 8v-42v, 3-10 lipo. I've soldered the Neg/Pos wires to the battery. And there is an off/on switch. Hope this helps!! Quote Link to comment Share on other sites More sharing options...
Codename-John Posted April 16, 2012 Share Posted April 16, 2012 Posted by ericrw on 16/04/2012 08:40:25: The info on the ESC is as follows: Hobbywing Pentium 60A. Brushless motors, UBEC-3A/5v, Version 3.1, DC 5.6v-26v 60A. And I have fitted a indepedant ubec. The info on that reads, Hobbywing UBEC, 5A, Max7.5A. Input: 8v-42v, 3-10 lipo. I've soldered the Neg/Pos wires to the battery. And there is an off/on switch. Hope this helps!! That has a bec, 3 Amp 5 Volt, already eric, see bold text, cut the + cable out of your throttle connector, and tape it up safe Quote Link to comment Share on other sites More sharing options...
ericrw Posted April 16, 2012 Author Share Posted April 16, 2012 Thanks, Electricity is just wichcraft to me, as you are now aware. But I do enjoy my electric powered 'planes. Eric. Quote Link to comment Share on other sites More sharing options...
