cymaz Posted December 9, 2012 Author Share Posted December 9, 2012 He is only making a small bracket to bolt onto the rear of the central crucifix for mounting the rear strut. There is nothing to it but I didn't have a bench grinder then when he did it. Found this picture that might help Quote Link to comment Share on other sites More sharing options...
Dylan Reynolds LaserCraft Services Posted December 9, 2012 Share Posted December 9, 2012 You see what I meant about the quality of die cutting and parts in the kit now? its a complete ball ache, but I made a template from mdf (8mm) of the ribs and re cut a lot of them from new fresh balsa, although the template may not be exactly the same rib profile as the kit, because i scaled a ClarkY section to the overall length and height of the ribs in the kit and cnc'd it from the mdf at work and used that as a template Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted December 12, 2012 Share Posted December 12, 2012 Hi cymaz, thanks for the diagram, very useful. Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 13, 2012 Author Share Posted December 13, 2012 I hope to ring up Richard at Falcon about my wings today, will let you all know how it goes Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 16, 2012 Author Share Posted December 16, 2012 John Hill 6 et al , News for you.... Here are some pics of the undercart after 1st fix (bolt holes done and everything lined up and working properly-but nothing epoxied or permanently fixed yet... above you can just see the centre bracket on the crucifix for the rear stay. Quote Link to comment Share on other sites More sharing options...
jeff2wings Posted December 16, 2012 Share Posted December 16, 2012 Now that looks like money very well spent !! Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted December 21, 2012 Share Posted December 21, 2012 Hi cymaz, I worked on the wings yesterday and all seams to be fine with them, I've nearly finished the top right one and only had to do very minor adjustments to make everything fit. Here are some pictures of my progress, as you can see i always like to put a carbon fibre rod at the end of the trailing edge sandwiched between the balsa. This makes it more resistant to hanger rash, adds strength and means you can sand it down to really fine edge. I also built the wing with the aileron in place, I'll cut this out once it's all sanded. Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 22, 2012 Author Share Posted December 22, 2012 I sent off the plane to Falcon Aviation First Class. The Post Office have not delivered them yet - still its been only 10 days Anyway, if I don't hear anything by Jan 6th then i will have to send them off again. So at the moment I am installing the rudder and elevator servos, pictures to follow.........in a day or two Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 23, 2012 Author Share Posted December 23, 2012 Here is a vid.... here Edited By cymaz on 23/12/2012 20:10:23 Quote Link to comment Share on other sites More sharing options...
Dylan Reynolds LaserCraft Services Posted December 23, 2012 Share Posted December 23, 2012 did you get to Homebase before 4? Looking good, I do like the hidden elevator horn Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 23, 2012 Author Share Posted December 23, 2012 Yes I got to Homebase in time. Elevator control tries to mimic the original...... Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted December 24, 2012 Share Posted December 24, 2012 Nice job, looks like it woks a treat. Quote Link to comment Share on other sites More sharing options...
karl grey Posted December 24, 2012 Share Posted December 24, 2012 Looking very tidy there Peter. At this rate you will soon have it down the field for its maiden, specially with this weather stopping us from flying lately. Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 24, 2012 Author Share Posted December 24, 2012 Like to have it ready by June..........but I don't know Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 26, 2012 Author Share Posted December 26, 2012 ITS BOXING DAY.......will start on the cockpit and floor etc while I can still get into the sides and over the airframe OK. Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 26, 2012 Author Share Posted December 26, 2012 Picture of cockpit progress.... Roughed in the seat, cockpit walls, switch, dashboard, floor and central column. Not bad for a quiet Boxing Day Quote Link to comment Share on other sites More sharing options...
karl grey Posted December 26, 2012 Share Posted December 26, 2012 Will you be fitting onboard glow with working light mounted on the dash. Like the switch placement, very tidy Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 26, 2012 Author Share Posted December 26, 2012 Just like my Meteor Monoplane , mate Edited By cymaz on 26/12/2012 22:09:17 Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 28, 2012 Author Share Posted December 28, 2012 More cockpit detail. It will be finally glued in after trail flights but I couldn't resist it!! I'm not going for 100% accuracy but fussy cockpit detail is good enough for me, and I like it it's my build Edited By cymaz on 28/12/2012 13:05:10 Quote Link to comment Share on other sites More sharing options...
flight1 Posted December 28, 2012 Share Posted December 28, 2012 come on pete I want a glowing pannel, There is plenty of time it's still raining Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 28, 2012 Author Share Posted December 28, 2012 Richard (Flight 1), I've done enough boy. Just will have to wait for the wings now. Next job is to sheet the front of the fuselage. Quote Link to comment Share on other sites More sharing options...
flight1 Posted December 29, 2012 Share Posted December 29, 2012 I see you are suffering from flying withdrawal symptoms. The build is looking good so far. I will have to get my Hanriot in the air again so we can do a bit of formation flying, I have enough time i think before your ready me thinks, i will have to concentrate on one as I keep flipping between the Fokker DXX1, the Tiger Moth and I am recovering the Jenny as I speak. The weather might be ok next weekend Cheers Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 3, 2013 Author Share Posted January 3, 2013 Great news!!!! Richard from Falcon Aviation phoned this morning, and he said that the wing plans have arrived. Not bad as I sent them off in the middle of December I have been doing all the fiddley stuff on the fuselage. Stringers, hatches, sheeting. Pictures to follow. Quote Link to comment Share on other sites More sharing options...
John Hill 6 Posted January 3, 2013 Share Posted January 3, 2013 Glad to hear your getting somewhere with your wings, I’ve nearly finished building the top wing I joined it together last night using the 60mm measurement under each wing tip and it was spot on, you can see some pictures of my progress on my profile page. I’d be interested to see pictures of your fuselage, I’ve been thinking of the best way to make the doors. One idea I had was to glass cloth the entire sheeted area of the front fuselage making the panels for the doors more rigid and thus hold their shape when cutting them out. Another idea was to make them out of glass cloth by laying a protective sheet of plastic where the doors are and then laying up 4/5 layers of glass cloth, these are then perfectly moulded to the shape of the side fuselage. I can’t decide which method to go for, what do you think? Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 4, 2013 Author Share Posted January 4, 2013 I was going to try and make them from litho plate with dummy piano style hinges, they won't open but it may look ok. See here. This link may be of interest, John, it has really good useful information Edited By cymaz on 04/01/2013 05:57:00 Edited By cymaz on 04/01/2013 05:57:48 Quote Link to comment Share on other sites More sharing options...
