Farrier Marc Posted June 15, 2014 Share Posted June 15, 2014 Father and son build (I built the 190 and my son the p51) Test flew them today and we are very happy with them. They are surprisingly quick and very agile. The p51 is quite a stable flyer whereas the 190 is a lunatic, and put a big childish grin on my face. Looking forward to tomorrow for sum more dog fighting!! Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted June 16, 2014 Author Share Posted June 16, 2014 Marc, What a great build they both look fantastic , a job weldone. Great to know you both enjoy the models and would love to see a vdo of the flying and even better a good dogfight. Would love to know what setup youre using and what the finish is, because they look great. Thanks for building the models and yes the P51 is more stable than the FW190 which is much more a wildthing. Cheers, Ton Quote Link to comment Share on other sites More sharing options...
Farrier Marc Posted June 16, 2014 Share Posted June 16, 2014 Cheers Ton, the setup is a 1510-22 motor with a 5.5x4.5 prop, 10a speed controller, 2s/500 lipo and 4.8g digital servos. The finish is solartex painted with Tamiya acrylic and some printed decals. I use solartex although slightly heavier than film I find it very strong, durable and takes paint well. For the amount of solartex used the weight is very minimal. Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted June 18, 2014 Author Share Posted June 18, 2014 Thanks for the info on the motor , thats the same setup Iam using, Iam sure you it will be good fun doing an Dogfight. Cheers Ton Quote Link to comment Share on other sites More sharing options...
Phil Fraser Posted July 6, 2014 Share Posted July 6, 2014 I need some help with a way to connect the wing servo arm to the inner cable of the aileron snake. I've been stuck on this for the past month and still haven't found a solution. I've considered all sorts of solutions involving soldered piano wire but I cannot think of a secure way to then connect the piano wire to the servo without excessive play. I bought some push rod retainers from Asia, and after waiting a month, I found that they are too large. The push rod hole is 2.1 mm and they are quite large all round. I've since discovered that they do have some 1 mm retainers but they still look a bit bulky. Maybe this is the best or only solution? So, what's the smart way to connect the servo arm to the aileron cable? Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 7, 2014 Author Share Posted July 7, 2014 Hi Phil, Great your building the Microwarbird, what you should use is an 0.6mm pianowire. Here are some pics hope this helps you to make the ailerons work. Cheers Ton Quote Link to comment Share on other sites More sharing options...
Phil Fraser Posted July 8, 2014 Share Posted July 8, 2014 Thanks Ton, I hadn't thought of putting two pieces of wire into the same hole on the servo arm; good idea. The problem is that my nearest hobby shop is 1000 km away and buying piano wire online is usually difficult and expensive because of the long lengths. However, you've given me an idea that might work using what I have on hand. Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted August 6, 2014 Author Share Posted August 6, 2014 Phil, Any news if it all works rightnow and is the Microwarbird already flying. Iam sure there are more Microwarbirds in the making and flying out there and would love to see some more pics of models flying or in the making. Cheers Ton Quote Link to comment Share on other sites More sharing options...
Phil Fraser Posted August 7, 2014 Share Posted August 7, 2014 Posted by Ton van Munsteren on 06/08/2014 21:40:39: Phil, Any news if it all works rightnow and is the Microwarbird already flying. Hello Ton, I couldn't find any suitable wire locally so I decided to order a servo connector to clamp onto the snake inner cable. Mail normally takes a month to arrive from Asia so I expect to receive the connector sometime soon. The partly built wing has been sitting around far far too long gathering dust. Quote Link to comment Share on other sites More sharing options...
Joachim Söderblom Posted February 19, 2015 Share Posted February 19, 2015 Well, a year! after I started this build, I´m finally done! My first scratchbuild, only done lasercut kits earlier, apart from all my arf´s and foamies. Well, built a couple of indoor-foamies and a Polaris from scratch as well, but I´ve started liking the balsabuilding more... Setup is the "standard-motor" recommended, a 6A Turnigy esc, some cheap 4.7g servo for the elevator. Tried a HXT500 for the ailerons, but that seemed to weak to handle the bends in the pushrods, so swapped it to an Emax08. AUW with 2S 500 is 187g. Not maidened yet, mostly due to bad weather and icy snow. Don´t want to rip the covering on the first flight... L /Jocke Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted February 19, 2015 Author Share Posted February 19, 2015 Joachim, Welcome to the world of scratchbuild and congrats on an great job. Thanks for posting the pics the Mustang looks great. Looking forward to the maidenflight report. Cheers Ton Quote Link to comment Share on other sites More sharing options...
Andy Horsman Posted February 24, 2015 Share Posted February 24, 2015 Ebay "bargain" anyone? http://www.ebay.co.uk/itm/BF-109-Profile-RC-aeroplane-/221695026945?pt=LH_DefaultDomain_3&hash=item339e0da701 Perhaps it's unique being as it's the "BF-109" version Quote Link to comment Share on other sites More sharing options...
herreraa Posted April 21, 2021 Share Posted April 21, 2021 On 15/01/2014 at 17:29, Ton van Munsteren said: And more I do hope you like your MicroWarbird as much as I do Ton 1 Quote Link to comment Share on other sites More sharing options...
herreraa Posted May 13, 2021 Share Posted May 13, 2021 On 21/04/2021 at 10:40, herreraa said: Do you have the plans for the planes , i want to build one for my son , he loves warbirds and he is learning to fly. Thanks Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted September 4, 2021 Author Share Posted September 4, 2021 Hi herreraa , Sorry that I missed you post I have send an pm with the plans and hope that you still want to build the model. Cheers, Ton Quote Link to comment Share on other sites More sharing options...
Jeffrey Cottrell 2 Posted October 19, 2021 Share Posted October 19, 2021 Hi Guys New to this topic, where can I get plans? Jeff Quote Link to comment Share on other sites More sharing options...
