Jon H Posted March 2, 2019 Share Posted March 2, 2019 I have had rocker adjustors go on a saito and a few enyas. Same situation as cymaz but mine was the other way round. Went to gently nip it up and it snapped like a carrot. My enya 53 also failed while running and punched a hole in the rocker cover Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted March 2, 2019 Share Posted March 2, 2019 Posted by cymaz on 02/03/2019 18:32:46: I’m not the 110lb gorilla type to tighten nuts like that ! I was referring to the unknown history of my friend's engine - I'm sorry if you thought I was referring to you! Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 2, 2019 Share Posted March 2, 2019 No offence taken......I had a quiet chuckle Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 31, 2021 Share Posted January 31, 2021 Checking over my DH 60 ( powdered by. Zenoah G38)yesterday. Weather poor, no flying in Covid crisis. I took out the fuel tank to check it over as it hasn’t flown for over a year. I’m so glad I did. The clunk pipe was stiffer than a stick of rock. A DEFINITE PLANE LOSER While you all have the chance, have a look at your tanks and clunks. Also clean the tank out, replace any filters and replace the bung and pipework while it’s out. Edited By cymaz on 31/01/2021 08:44:23 Quote Link to comment Share on other sites More sharing options...
Roger Jones 3 Posted January 31, 2021 Share Posted January 31, 2021 The worst things for quick deterioration are SLEC control horns. Even my local model shop said so, even though he stocks them. Installed and the plane kept in semi-shade with only the evening sun (so low in the sky thus lots of UV reducing atmosphere to travel through) sometimes shining though the glass in our 'front room' they snap like a rotten stick after no more than a year. And the pumped OS glow engines have a built in failure point - the pump diaphragm. Using a cleaning/preserving oil on such engines makes it worse. Edited By Roger Jones 3 on 31/01/2021 09:10:09 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 31, 2021 Share Posted January 31, 2021 I suffered from those brittle control horns many years ago. Lost my Oodalally that way. I am told that, although the plastic looks the same, some batches supplied have a different composition which can make them go brittle. Quote Link to comment Share on other sites More sharing options...
