Jimbo565 Posted November 1, 2020 Share Posted November 1, 2020 Cheers Paul,looking forward to getting her fired up. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 1, 2020 Share Posted November 1, 2020 nice job as usual JC..... ken anderson...ne..1..J Carrs dept. Quote Link to comment Share on other sites More sharing options...
Torsten Spitzner Posted November 1, 2020 Share Posted November 1, 2020 My latest scratchbuild, just in time for thermaling in our hot summers... 3m span 'Paragon', courtesy of Outerzone. Electrified and spoilers fitted. It came out a tad heavy for my liking so I may eventually build a lighter fuselage for it. Flies well none-the-less. 1 Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted November 1, 2020 Share Posted November 1, 2020 Chees Ken, Hope all is well in NE 1 JC NE23 ____ all is well dept. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 2, 2020 Share Posted November 2, 2020 all good here also JC......stay safe. ken anderson...ne..1...lockdown dept. Quote Link to comment Share on other sites More sharing options...
David Barker 2 Posted November 2, 2020 Share Posted November 2, 2020 Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted November 5, 2020 Share Posted November 5, 2020 Both maidened yesterday, both electric on 6s. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted November 6, 2020 Share Posted November 6, 2020 Acrowot, not new but completely refurbished. I built this from the original Chris Foss kit in 1986 with the then brand new Laser 75. It has languished in my loft for nearly 30 years. The blue Solartex had gone brown and the engine completely neglected was stripped, cleaned and rebuilt with new bearings. The covering was all removed and the airframe glassed, sprayed and fuel-proofed. I was surprised to find a replacement canopy at SMC which would have been a show-stopper otherwise since the original had cracked and buckled. The engine was run and tuned this afternoon much to the neighbours delight! Quote Link to comment Share on other sites More sharing options...
Keith Evans 3 Posted November 13, 2020 Share Posted November 13, 2020 Here is my ARUP finally finished . Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted November 13, 2020 Share Posted November 13, 2020 Like it. Quirky. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted November 14, 2020 Share Posted November 14, 2020 Really nice build and to be honest I have never seen one of those before so a super special in my book. Well done interesting build log Keith. Quote Link to comment Share on other sites More sharing options...
Keith Evans 3 Posted November 17, 2020 Share Posted November 17, 2020 Hi I've had a few questions from some close friends so I'll give some more detail re the ARUP here. The weight is 5lbs. The wing area is 800sq.inches . The balance is spot on with a 4.8 volt battery positioned under the tank . I did add 1.5"" to the nose length at the initial redesign stage and straightened out the outlines a bit . I needed to angle the U/C legs forward a bit so it would sit properly on the ground . As it is a bit cumbersome to handle I found that using pins to hold the covering on and then adjusting it before tack gluing and shrinking was of benefit . Keep well Keith . Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted November 18, 2020 Share Posted November 18, 2020 I finished a Multiplex Akro today, slope soarer with a one-piece foam/veneer wing and a fibreglass fuselage. Two other models that I completed earlier this year are a Multiplex Cortina and a PSS F-101 Voodoo. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 18, 2020 Share Posted November 18, 2020 Love your Voodoo Gary. Quote Link to comment Share on other sites More sharing options...
Gary Binnie Posted November 18, 2020 Share Posted November 18, 2020 Cheers! It fought me all the way. Originally a plan by Harold Bull this was a Boddo kit. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 18, 2020 Share Posted November 18, 2020 I built one many years ago (Boddo Kit) I.C though. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted November 18, 2020 Share Posted November 18, 2020 Waiting for lockdown V2 to end, so that I can do the maiden. Now building a Dracon. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted November 18, 2020 Share Posted November 18, 2020 Deleted. Double post. Edited By Kevin Fairgrieve on 18/11/2020 18:16:05 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted November 18, 2020 Share Posted November 18, 2020 Posted by john stones 1 on 18/11/2020 15:27:28: Love your Voodoo Gary. Voo doo, so do I Quote Link to comment Share on other sites More sharing options...
trevor wood 2 Posted November 19, 2020 Share Posted November 19, 2020 I was recently gifted a BNIB, old stock model as payment for finishing the assembly of another model on the understanding that I would actually build it and not just use it as loft insulation. The recently completed kit is a Solent Sailplanes "Ridge Racer" (there's a clue in the first photograph!) dating I guess from the mid '70s. The fuselage is a polyester/glass fibre moulding and the wings are veneered foam core with a rarely seen 'reverse taper' ailerons operated via a single centrally located servo and a pre-installed Bowden cable. Just waiting for a 15 kt westerly at my local slope to get the maiden out of the way. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted November 19, 2020 Share Posted November 19, 2020 Very Smart indeed Trev. D.D. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 20, 2020 Share Posted November 20, 2020 Around 1979 I did some slope soaring on the Malverns and the Ridge Racer was really rated as a top model, very fast. Solent Sailplanes did a tamer version as well, called the “Ridge Runner”. You’ve got a good one there. Quote Link to comment Share on other sites More sharing options...
Trevor Posted November 20, 2020 Share Posted November 20, 2020 I seem to remember a Ridge Runt as well from the 80s, but I don't know if that was from the same stable (or litter!)? Trevor Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 20, 2020 Share Posted November 20, 2020 Trevor, I've got a feeling that the Ridge Runt was from another maker, but I could be wrong. I remember the plane. Quote Link to comment Share on other sites More sharing options...
