GrahamC Posted November 2, 2013 Author Share Posted November 2, 2013 I'll use flocked CA hinges for ailerons. They will be fine. [My WOT4 has hours and hours and hours of lying under its belt, and the hinges are still fine] The elevator will be hinged with archive quality sticky tape... I will post on hinging when I get there! Quote Link to comment Share on other sites More sharing options...
GrahamC Posted November 4, 2013 Author Share Posted November 4, 2013 A few notes on the canopy and pilot.... I made a 'blank' for the canopy from scrap balsa and shrank a pop bottle over the blank using a heat gun and then cut the canopy from the shrunk bottle. I pressed the canopy into place, and drew around it on the fuselage... and then traced the shape made onto tracing paper... and painted the shape first with WBPU varnish and then with black acrylic paint. I then placed the tracing on the Solarfilm and cut the shape straight through the tracing paper and Solarfilm, I applied the solar film, and then glued the canopy in place with canopy adhesive. The pilot bust was made by spinning a piece of scrap balsa glued on a cocktail stick up on a dremel and using sand paper to make a bead. The visor was made with some scrap lithoplate and cyan's in place. I'm getting there... Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 4, 2013 Share Posted November 4, 2013 The canopy transforms the appearance for me Graham. Definitely the way to go. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted October 5, 2014 Share Posted October 5, 2014 Hi Graham, very useful blog. On the plan there is mention of removing part of the top of F3 for battery. I assume he is talking non lipo here. Can you tell me what position a lipo will be in the fuz. I assume there is no need to tamper with F3 Thanks Quote Link to comment Share on other sites More sharing options...
brfc7 Posted October 5, 2014 Share Posted October 5, 2014 The regular place for the lipo batterys on all the PC's I've seen and including mine is straight in the nose in front of F2, So no need to alter F3. The plan was made when Brushed motors and big heavy nicd's were been used. Here's another couple of good write ups of a build on here - Kens build - http://www.modelflying.co.uk/forums/postings.asp?th=89454 Mass buld - http://www.modelflying.co.uk/forums/postings.asp?th=88922 Baz Edited By brfc7 on 05/10/2014 17:48:02 Edited By brfc7 on 05/10/2014 17:48:34 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 5, 2014 Share Posted October 5, 2014 here is my build for no 4(no longer with us).....I would def put the lipo in the nose graham ... help you to get the C of G ...spot on as per the plan... ken Anderson ne...1 construction dept. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted October 5, 2014 Share Posted October 5, 2014 Thanks Baz and Ken, can carry on in confidence now. Cheers Quote Link to comment Share on other sites More sharing options...
