OZ e flyer Posted March 20, 2018 Share Posted March 20, 2018 Very nice Jason. I was just doing a bit of work on my redeagle. Getting ready to run the snakes for the tail feathers before I sheet the top deck. What power train are you using? Heading to my LHS in the morning to hopefully obtain a spinner and folding prop set so I can shape the nose of my red eagle. TP Quote Link to comment Share on other sites More sharing options...
Jason-I Posted March 20, 2018 Share Posted March 20, 2018 Posted by Tipsy Pilot on 20/03/2018 11:42:07: Very nice Jason. I was just doing a bit of work on my redeagle. Getting ready to run the snakes for the tail feathers before I sheet the top deck. What power train are you using? Heading to my LHS in the morning to hopefully obtain a spinner and folding prop set so I can shape the nose of my red eagle. TP Hi TP, I'm using a propdrive v2 2830, 1000kv https://hobbyking.com/en_us/propdrive-v2-2830-1000kv-brushless-outrunner-motor.html Plus a 30A esc. J Quote Link to comment Share on other sites More sharing options...
Jason-I Posted July 22, 2018 Share Posted July 22, 2018 Its nearly finished! Just a few jobs left: - Make some graphics for the fin & nose - Install receiver & program radio - Install flight pack & set CG - Fly! Colour scheme borrowed from this thread albiet with a few small changes (think it was one of Ton's clubmates schemes). Weight without battery: 684g Thanks to Ton for a nice easy design. Thanks also to Andy for his assistance! Edited By Jason Inskip on 22/07/2018 14:34:45 Quote Link to comment Share on other sites More sharing options...
Andy G. Posted July 23, 2018 Share Posted July 23, 2018 Glad I could be of assistance Jason. That looks lovely. I have had so much flight time with mine now. Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 27, 2018 Author Share Posted July 27, 2018 Jason , your welcome and thank you for building the RedEagle. You did a great job it's a beauty. Set the CG on 90mm the RedEagle will fly at its best. Cheers, Ton Quote Link to comment Share on other sites More sharing options...
Handyman Posted July 27, 2018 Share Posted July 27, 2018 Hi everyone on this build, I have watched a lot of the postings with great interest. Its a nice looking aero-plane/glider. Has anyone brought out a kit for the RedEagle yet? I rather fancy one of these but at 77 years old, I do not think I would have the patience to start another build. I have got a Cub to re-build, a 1960s Ugly Stik on the building board, by Phil Kraft plus a Phil Kraft Kwik Fli 3, all vying for my time. Mind you, if there is a pre-cut kit of the model, I might just talk myself into it!!!!! Regards to all Red Eagle fliers. Anthony. Edited By Handyman on 27/07/2018 15:09:04 Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 27, 2018 Author Share Posted July 27, 2018 Hi Anthony, Check the following link **LINK** for a kit of the RedEagle. Cheers, Ton Quote Link to comment Share on other sites More sharing options...
Handyman Posted July 27, 2018 Share Posted July 27, 2018 Hi Ton,that was quick. Thanks for the link. I will check it out after tea. I cannot let all of these youngsters have all the fun. Can I ? All the very best. Anthony. Quote Link to comment Share on other sites More sharing options...
Chris Evans 10 Posted January 19, 2021 Share Posted January 19, 2021 It's been a quite a while since this thread was active, but during lockdown I stumbled across the Red Eagle whilst hunting for a balsa kit project. It's been so helpful to go through the questions in here, especially since it's been such a long time since I last built anything, and I'm looking for some advice on how to remove the wood from the nose before adding the material to be sanded to fit the nose cone. All of the pictures here look astonishing neat - what have you used to do this? Thanks in advance! Chris Quote Link to comment Share on other sites More sharing options...
kc Posted January 19, 2021 Share Posted January 19, 2021 Welcome to the forum Chris. I would suggest a Permagrit sanding block would remove lots of balsa very easily. Glasspaper block would do the same but creates much more dust and uses more effort. Carving with a scalpel first would help. Permagrit seems expensive but last forever and you really only need the wedge block. A David plane is also very handy for shaping balsa. Edited By kc on 19/01/2021 16:32:18 Quote Link to comment Share on other sites More sharing options...
Chris Evans 10 Posted January 20, 2021 Share Posted January 20, 2021 Got it, that makes sense. I've been feeling pretty nervous about hacking away large chunks of fuselage after many painstaking hours getting it all assembled! Thanks very much for the advice, much appreciated! Quote Link to comment Share on other sites More sharing options...
kc Posted January 20, 2021 Share Posted January 20, 2021 The technique of rounding a fuselage is just a matter of doing it evenly - one stroke off each side and same on the other, moving the plane or sander around in the shape you desire. Dont plane flats on it! However if you make a mess just plane it flat and glue on a slab and start again. As with all new things make a test piece from scrap and experiment. I have just received ( 10 minutes ago! ) my 'free gift' Permagrit block which came with my RCME subscription. The offer is in the latest RCME and is valid until 12th Feb. But the gift took 6 weeks to come as there was some delay. A good deal if you want RCME & are not in a hurry. Otherwise just buy the smaller cheaper wedge block. Still expensive but worth it as it cuts so agressively but smoothly. Ideal for reducing birch ply items to exact size,. Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted October 23, 2021 Author Share Posted October 23, 2021 Still having fun with the RedEagle Ton 2 Quote Link to comment Share on other sites More sharing options...
michael harper 2 Posted July 11, 2022 Share Posted July 11, 2022 Just bought one of these kits Quote Link to comment Share on other sites More sharing options...
michael harper 2 Posted July 12, 2022 Share Posted July 12, 2022 Not impressed with quality control 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted July 12, 2022 Share Posted July 12, 2022 That is poor 😲 Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 13, 2022 Author Share Posted July 13, 2022 Oei sorry to see that and thats no good. Please contact RBCkits Iam sure they will replace the parts. Ton Quote Link to comment Share on other sites More sharing options...
Ace Posted July 14, 2022 Share Posted July 14, 2022 That looks as though it's just printed on the wood still requiring cutting out/finishing (no laser/routing) ? Hopefully an optical illusion. Quote Link to comment Share on other sites More sharing options...
michael harper 2 Posted July 14, 2022 Share Posted July 14, 2022 Its actually routed out. The ply is 2mm thick but the cutouts in the trailing edge are still 3mm wide for 3mm balsa wing ribs. Quote Link to comment Share on other sites More sharing options...
michael harper 2 Posted August 28, 2022 Share Posted August 28, 2022 Just gets better. Plans say it should be 105mm long Quote Link to comment Share on other sites More sharing options...
