Biggles' Elder Brother - Moderator Posted December 31, 2013 Share Posted December 31, 2013 Well 2014 is with us tomorrow - time to get started on the Mass Build! The Dawn Flyer was my vote, I'm hoping for a nice relaxing model for the long balmy summer evenings we're going to have in 2014! I want to complete this build as quickly if I can as I have another build in mid flow! For this reason I bought the CNC pack - saves a lot of time. I will have in all the rest of the wood I need, but if you're new to building and don't have a "stash" of wood you might want to buy the woodpack as well. So, Tiffie airframe up on the rack and look at this,... now that's a sight you don't see often - my building board clear, well nearly clear! To start the ball rolling let's get the fuselage plan out and start identifying the key bits and labeling them up,... Next pin the plan down and lay a sheet of clingfilm over that and off we go. We have to sort out F1 and F1A first - they will be glued back to back to make a single double thickness former. But the position of these along the fuselage side is a "moveable feast" - ie its exact position is governed by what motor we're going to use. I'm planning to use an E-Flite Power 10 that has come out of another model. In theory its a bit small for this model - but its a powerful little number so I think it will be fine. So the length of that sets how far back F1/F1A have to go. Once that's settled we need to mark the position of the thrust line on F1, then draw a circle the pitch of the motor's mounting screws,... We can then drill the centre hole and four mounting screw holes. A tip here is to clamp the ply former to a substantial piece of wood behind it. That way when you drill through the ply you won't split the ply. Next, apply glue to F1A, place the two formers together, place the mounting screws through and tighten up, drawing the captive nuts into the back of F1A. A couple of clamps and everything is in place. So from the front,... And just to prove that the backing wood does stop the ply splintering, the view from the back with the captive nuts well bedded in,.... OK, we have to leave that now and move on to the fuselage sides and glue on the triangular doublers that will reinforce the landing gear mounting area,... Don't forget to make a right and left-hand side! Its easy to make two rights! Next weigh those doublers down - a couple of six cell Lipo's do the trick! OK, we have to leave all that to dry now - and the family are kind of suggesting that I should be doing something else on New Years Eve! But at least we've made a start! BEB Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted December 31, 2013 Share Posted December 31, 2013 your cracking on with it young man. just don't forget to finish the tiffie. Quote Link to comment Share on other sites More sharing options...
Monz Posted December 31, 2013 Share Posted December 31, 2013 Do you have a pic of what it'll look like? Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 31, 2013 Share Posted December 31, 2013 Nice to see Teddy is supervising the build Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted December 31, 2013 Author Share Posted December 31, 2013 Where would I be without teddy to keep an eye on me? Monique it will hopefully look something like this,... Don't worry Tony - the Tiffie is looking down on me from the rack, this is just a "breather"! BEB Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted December 31, 2013 Share Posted December 31, 2013 yeah i try to convince myself like that as well. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 1, 2014 Author Share Posted January 1, 2014 Just had a question back stage about side and down thrust on the Dawn Flyer - I meant to mention this but forgot! Normally you would offset the mount allowing for the right and down thrust so the prop would be in the centre of the nose - as I did here (approximately three quarters of the way down the page) with the Tucano last year, where I went into some detail on this issue and how to calcualte the offset. But both the right thrust and down thrust specified in this design of Lyndsey's is very small - I don't have the plan in front of me - but its only of the order of one degree! So, given how small the model is, the offset would be about 1/64" - not really worth worrying about! Also - unlike the Tucano which had a pointed nose that had to blend into the spinner - the Dawn Flyer's nose offers plenty of scope for a bit of "cosmetic surgery" to obscure such a tiny offset! BEB Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 1, 2014 Author Share Posted January 1, 2014 OK, pressing on,... First a trial fit of the motor to F1,... This revealed that the collet on the rear was slightly interfering with the clearance hole at the back,... No big deal - just enlarge the hole a little and all is well. While we are at the back - never trust these captive nuts completely - especially these small ones, they can easily fall out. While we don't anticipate removing the motor frequently it as well to be sure. Danny Fenton showed me a really neat solution to this over on the Tiffie thread - but I'm a bit of a savage so I tend to just lay a pool of epoxy around them that overlaps them - being careful not to get epoxy into the thread of course,... Sorry Danny! Not so neat I know, but it works and no one will see this bit! Now its time to add the longerons along the bottom of the forward fuselage,... And then we can start adding the formers - being very careful to be sure that they are square,.. The notch in the bottom of F2 had to be made a fraction deeper to accommodate the 6mm sq longeron. Now we add the rest of the formers and then the other side of the fuselage,... Normally I would use a fuselage jig here to keep everything square - but the "coffin shaped" fuselage with sloping sides makes that a non-starter! So we just have to be very careful and line everything up as best we can. The square rebates to take the landing gear mounts are not deep enough and so had to be altered a bit - again not a major problem. The front mount is a sandwich of two pieces while the rear is just a single piece. These were epoxied it for strength, note the groove, which will eventually hold the U/C wire obviously goes to the bottom! Here's a view of them in place,... When set they will need to be sanded flush to the fuselage sides. OK that's this mornings efforts, off to drinkies at a friend's house now - just coke for me as I want to get on with this later! (The sacrifices we make!) BEB Edited By Biggles' Elder Brother - Moderator on 01/01/2014 14:49:05 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 1, 2014 Share Posted January 1, 2014 Slow down BEB, you're making me giddy building at this rate. I need the smelling salts. Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 1, 2014 Share Posted January 1, 2014 Good to see you're cracking the whip Teddy Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 1, 2014 Author Share Posted January 1, 2014 Yes, teddy is a slave driver! Better fasten your seat belt Colin and keep the smelling salts handy! Well I've hit the first snag - fitting the motor in! I seem to be destined to have this problem with Mass Build models! I must pick one with a bigger cowl next year. First I fitted the cowl (FC) and then tried trial fitting the motor - it interfered with FC. The only solution was to start sanding away at FC (the motor has to go where the motor has to go!). But there isn't a lot of "meat" on FC - so I decided to fit the top longeron to stiffen things up a bit,.. The picture shows the arc I have had to sand in FC. When I tried the motor next though,...more bad news, it interfered with the longeron I'd put in so I could remove more from FC!! There was nothing for it - the longeron needed to be "trimmed",... Eventually I got everything in and all was well - phew! A couple of strategically placed washers gives us the 1 degree right and 11/2 degrees down thrust. This is difficult to show in pictures - its so small - but here goes; first the down thrust,... And now the right thrust,... But the position of the drive shaft from the front still looks fine - as predicted,... We now need to take some precautions - I'm not taking that motor out again! - but it needs to be protected from glue, balsa dust, biscuit crumbs etc.,.... Now now chaps - no inappropriate comments please - we all know what you're thinking Now its time to apply the top sheeting. Its from 1.5mm sheet - which feels like tissue paper after sheeting the Tiffie! The trick here is to make a card pattern, you can cut that about and bend it until it fits perfectly, then cut out the wood. You should aim to reach halfway across the central longeron - leaving the other half for the second sheet on the other side. First I chamfered the outer side of the sheet so it would butt up against the fuselage side, I then tacked the sheet to the outside edge with a spot of CA and finally ran a thread of CA right along the joint. So I now have the sheet fixed at the outer edge and sticking up in the air. We wet the outside - I use a sponge sort of 3/4 wrung out. The outside expands and so the sheet starts to curve. Apply aliphatic (or PVA) to the formers and one half of the top longeron, bend the sheet and tape down, job done,... That's where we are up to - more tomorrow. BEB Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 2, 2014 Author Share Posted January 2, 2014 We often get posts from people asking what sort of tool kit you need to build from plans so in the spirit of the Mass Build, and assuming that someone who hasn't built from plans before looks in on this, I thought I'd just catalogue what tools I've used so far; To cut stuff like the 6mm square strip I use a razor saw: You can manage the stuff we cut here with a knife - but the razor saw does make life easier. Talking of knives I use one of these: Th trusty Swan-Morton. Get loads of blades you need to change them frequently as the only point of using it is how sharp it is! Blunt knives are one of the main causes for people cutting themselves. We need to be able to sand and dress. Sandpaper on a block will do the job, but while I'd heard about Permagrit ages ago I have actually only recently discovered the joy of using them,... Above is a general sanding block (medium and coarse sides) and a slotting tool - great for easing the fit of 6mm sq. And talking of square(!) we need to be sure many bits and pieces are. So we need one of these,... I like these engineers squares, nice and heavy so very stable in position. I've used a couple of clamps and a light file,... These mini sash clamps are great - B&Q and the like do them. I have used a hex driver on the motor installation. You could done the job with a Allen key - but the motor body means you can only get a half a rotation in at a time! And of course a good 12" straight edge is indispensable,... I used some standard wood drills (2mm and 3mm) and a 12mm hole cutter - again not essential but a damn sight easier than the alternative,... For adhesives I have used Aliphatic to join F1 and F1A and attach the doublers. PVA would have done just as well. I also used Aliphatic to fasten down the sheeting. The U/C bearers were attached using epoxy (for strength). All other joints used CA. Personally would not make so much use of CA - though it does have its place - but I want to progress quickly! BEB Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted January 2, 2014 Share Posted January 2, 2014 Not bad, you started the New Year with full speed Just a small hint - probably not too late. I have finished my Dawn Flyer - and it suffers slightly from COG problems (tail heavy) . I have seen you packed a lot of power into the nose - so this will help for sure - but I have also the battery problem. I cannot move the battery as far forward as I want to as there is not enough room between the battery hatch and the battery holding plate. In the early stage you are now you could probably think about the final battery position. With my model I will do some Dremel surgery to get the battery in a higher position... VA, back to work ... Quote Link to comment Share on other sites More sharing options...
David Tweddle Posted January 2, 2014 Share Posted January 2, 2014 Nice work BEB glad I have not started yet (can't find plan). Must add note for new builders, do buy Swann Morton or X-Acto, and not the pound shop look alike X-Acto they are a hazard I know. My choice is the Swann Morton No2 with 10A blades. Housework(to find plan) then follow you ten steps behind... I will use Aliphatic through most of my build as CA is now affecting me. David Quote Link to comment Share on other sites More sharing options...
Dylan Reynolds LaserCraft Services Posted January 2, 2014 Share Posted January 2, 2014 Very nice BEB, once I have managed to clear all my models out of the house and back into the shed (after losing the roof), I will be restarting mine. This is the inspiration I have been looking for! Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 2, 2014 Author Share Posted January 2, 2014 Thanks for the "heads up" on the tail weightiness VA - I shall certainly be keeping that in mind and seeing if I can the battery as far forward as possible. David - totally agree about cheap knives - the blades are made from some special material - cheese I think - which holds its edge for about 2 cuts and then will never take an edge again! A pukha Swann Morton handle is not expensive - neither are the blades, especially if you buy them by the 50 as I do! Hi Dylan, good to hear from you again mate. Glad you are enjoying the blog - but I've still a way to go to catch up with you! OK, most of today I was on "family duties" so I didn't get in the workshop until about 5:00pm - but I did in the end get a decent session. As you can see in the photo below I have added the second piece of sheeting over the nose and trimmed it all to size,... As you can see I have also sanded the hardwood U/C bearers flush with the fuselage sides. Here I am gluing the wing mounting plate in place having cut two 3mm rebates in the fuselage sides so it will sit flush with them. Am I the only person who thinks that it looks like I'm building a canoe? Now we can add the wing mounting supports to the top face of the sides - outside faces flush. Well as it definitely looks like a canoe I better make a paddle,... The plan refers to this part as a "keel plate" - there's no doubt about it,...its a canoe, Lynds is having us on! Seriously, this will form the bottom spine of the open rear end. A word here about wood choice. The plan says to use 6mm sq spruce or very hard balsa. I don't have any spruce that size in stock, so its going to be balsa. But what exactly is "hard balsa"? Well what I do is gather together all the 6mm sq balsa I have and start sorting it. Pick each piece up and flex it a bit in your hands - then put it into either the "wet spaghetti" pile or the "promising" pile. Then put all the "wet spaghetti" back in the store and start working through the "promising" candidates sorting them into two piles; the "Could be better" pile and the "oh that's got body" pile. Then work from the latter. This is your "hard balsa"! So we use that to make the "keel" and then to make the upper part of the rear end,... This is built over the plan as can be seen. Lots of pins to hold it in place - it is pretty stiff, which is what we chose it to be! The piece over top, held in by being pieced through by two pins either end, is just there to hold the side pieces flat to the board. Now we can glue in the cross pieces, I use aliphatic here as we want a really strong tough joint and a good aliphatic joint is stronger than the wood itself,... And a view from above to show the curvature,... I've added a fillet at the end on my own initiative - otherwise I can't see whats holding the ends together! Don't be afraid to use your own initiative - even if its wrong we can always cut it out. Remember, "its only wood"! OK, back to the canoe; we need to add the bottom sheeting,... Note the direction of the grain. This is then cut an sanded back,... So, there's me canoe so far,...(or perhaps its a toboggan?) Onward and upward! Splice the mainbrace! More rear half tomorrow! BEB Edited By Biggles' Elder Brother - Moderator on 02/01/2014 22:38:58 Quote Link to comment Share on other sites More sharing options...
AJ Posted January 2, 2014 Share Posted January 2, 2014 At this stage you might think about adding a pair of thin ply doublers to the rear end of the fus. Where the sides rise behind the wing seat is a real weak spot as the two top rear longerons attach on top of these. The rear end relies on just these two and the lower hard longeron to remain attached. At the first hard landing the rear end will split these off and snap the lower longeron just where it attaches to the keel plate. Guess how I know . I added a pair of 1mm ply triangle doublers to match the fus sides on the inside behind the rear former and also doubled up the bottom longeron with about 4 inches of 6mm flat carbon. Negligable weight added but strong enougth now to use as a cricket bat. Nothing visible without very close inspection. I also found it very tail heavy, i have a 2200 3s upfront tight againt the back of f1 but still had to add a bit of extra in the nose. Andrew Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 3, 2014 Author Share Posted January 3, 2014 "Houston, we have a problem"! I came into the workshop and removed the tail end I had made yesterday from the board. Very pleased with it, nice and stiff and flat. Here it is next to the plan drawing of it,... Here it is placed back over the plan drawing of it,... Perfect, right? So imagine my surprise when I offered it up to the back of the canoe,... It's too wide - about 1/4" too wide!!! How on earth did that happen? So I started measuring things - as the tail fits over the plan it must be that the body is too narrow. Check that - yes it is. But the width of the back end of the body is totally determined by the width of F4 - surely that can't be wrong? So I measured F4 at its widest point,... And tested that against the plan,... Ah, well it looks like we have the culprit - F4 is 3/16" narrower than it should be! At this point I would use a naughty word - I did in fact use several naughty words in the workshop, hence the blue tinge on the photos! - but here it would only upset my fellow mods! So this shows the problems you can encounter with a CNC pre-cut set of parts - they are only as good as people who cut them! Thinking back I had a similar problem with F1 on the Tucano last year. OK so its no good good crying over spillt milk and all that - what are we going to do? Such problems are not unknown in plan building and sometimes you just have to adapt! I've considered three possible solutions: 1. Remake the tail section, but alter the plan to make it 3/16" narrower. This is undoubtely the best solution - but it will take time. 2. Cut the last two cross pieces out of existing tail section, trim them say 1/8" and 3/16" shorter respectively and reassemble. Messy and probably wouldn't end up being any faster than solution 1. 3. Glue on some 6mm sq "cheek pieces" to the sides of the body to effectively make it wider, mount to this and then try to "cover our sins" with a bit of shaping and sanding to blend everything in. Fast solution but is a bit of a bodge. Well the term "bodge" is much misunderstood in my view! I believe the term originated among the bands of itinerant carpenters that roamed the medieval countryside. They would move from village to village making simple furniture. One would make legs, another seats, yet another spindles etc. Obviously there was considerable variation in these components. The "bodger" was the member of the team who selected a set of parts such that ithey would need minimum modification in order fit well together, he then performed the necessary "fitting". So in reality he was possibly the most skilled of the troupe in many ways. Right then, "bodging" it is! But - a note to those of you with the CNC pack - check that F4! You might want to consider re-cutting a new one based on the plan! BEB Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 3, 2014 Share Posted January 3, 2014 There's a lot be said for "the Artful Bodger" BEB. I've always been heavily dependent on such techniques for getting the chestnuts out of the fire! Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 3, 2014 Share Posted January 3, 2014 Could you not steam the ends then clamp up to the right distance until dry, Quote Link to comment Share on other sites More sharing options...
Plummet Posted January 3, 2014 Share Posted January 3, 2014 BEB, I don't think that the cross members will be visible in the complete model. Widening the canoe stern might be easy, but the sandfoolery necessary to smooth everything out might be labour-intensive. Could you just do a diagonal cut in the frontmost cross member and then scarf joint it together again so that it is shorter. Do this while while using a bit of Cymaz's steam, and bend the sides in to fit the canoe width? Then add a little reinforcement to cross member. Plummet Edited By Plummet on 03/01/2014 15:36:41 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 3, 2014 Author Share Posted January 3, 2014 Just having a short coffee break.... Yes, steaming would be possibility number 4 and if I'd assembled it with CA a definite possibility - but I used Aliphatic - which (while I don't know for sure) I think, like PVA, is heat reactived - so when I steam it I'd run the risk of the whole thing coming apart in my hands - besides when I try to steam something I invariably scald myself Scarfing would be possible, and you're right Plummet these cross members aren't really visible on the final model as they are hidden beneath the top sheeting, but I think I'd have to do the first two - not just one - otherwise I would be asking a bit much of how much these rather stiff pieces of balsa would bend locally. In the end I've added to cheek pieces and indulged in the sanding - its turned out not too bad, piccies to follow later. BEB (still cursing CNC cutters!) Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted January 3, 2014 Share Posted January 3, 2014 BEB, you are not alone - but you could have easily worked around this little problem by reading what others have noticed before you. For instance Vecchio Austriaco... I left the former as it is - ripping it out without destroying everything is difficult - and changed the tail. Probably my Dawn Flyer will fly a little bit around the corner - but as I suppose it is a slow model it will not kill me to apply a bit of trim By the way - the only CNC/laser kit which I ever had that fitted perfect was the Bonanza (Jamara) - German precision - but they saved on the wood quality which was rather frustrating. So - nobody is perfect. Looking forward to your repair-solution VA Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 3, 2014 Author Share Posted January 3, 2014 Ah, very good point VA - yes it would have helped if I'd read that! But at least I didn't fall for the gluing the wing seats in first then wondering how the hell I was supposed to get the wing plate in! So, you win some, you lose some! I think I'll read more of the "clubhouse" to see what else I've got wrong! BEB PS Shed load of pictures later - well on today. Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted January 3, 2014 Share Posted January 3, 2014 forgotten wing plate - now you caught me.... but I am quite happy with my repair work. VA Quote Link to comment Share on other sites More sharing options...
