Andy Blackburn Posted March 7, 2014 Share Posted March 7, 2014 > have a think about how I've managed to get the wing dowel and hole locations so far out! Um... Sorry, I think that's a mistake either on the plan or the parts - it's not an issue, though, because the hole is about half a diameter too high and can be sanded oblong; that's what I've done with mine, everything still fits. I'll check the plan and parts over the weekend and report back next week. Please accept my deep and sincere apologies if it turns out to be my fault... Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted March 16, 2014 Author Share Posted March 16, 2014 Andy, No apology necessary mate, it's easily fixed! So, where were we? Well the next stage in my haphazard journey to Jet provost heaven was to apply the decking aft of the cockpit. Like Phil I elected to plank it and sand back. As I don't own a building board I elected to press the dihedral jig's into service to help align the fuselage as I set about gluing the back end former F7 into the fuselage. Whilst there I couldn't resist a dry fit of the fin to get a feel for how it's going to turn out! This then was a good opportunity to glue on the aft fuselage top decking using the fin itself to set a good snug fit. More to follow... Edited By Fly_Boy_Rez on 16/03/2014 20:44:23 Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted March 16, 2014 Author Share Posted March 16, 2014 Now to the tailplane. following someone else's lead I've gone down the route of adding a spar to the tailplane.I decided against simply trimming the tailpne short and adding the spar there as I knew getting the hinge slots in would be a nightmare. I also didn't want to make the spar full span so I cut a slot in the tailplane to take a spar. Into this I sunk a very carefully sized and shaped spar. However despite this careful shaping, or due to my haste to get it in I didn't push the spar in fully resulting in a spare that is sub flush one side and over flush the other... Hmmm! There's a lesson to be learned here! The elevators were carefuly aligned, marked up and hinged onto the tailplane with appropriate slots set into them for the torque rod. Unfortunately a test fit at this stage (having relieved the excess triangular stock in the tail region) revealed that my initial effort at a soldered up torque rod solution was simply way too long and was almost exiting the bottom of the fuselage! D'oh! Time for soldered torque rod Mk2... to be honest I was struggling with how to connect it to the pushrod so this was all actually a good thing! A the existing solder was re-heated until it oxidised and I was able to cut through the wire binding with a dremel wheel. The Mk2 variant is shorter plus has enough of an extension on one arm to epoxy on an M2 fitting. To permit a wide range of movement I've let in slots in the tailplane. So, time for a little bit of scale detail... following Phil's lead (He and Matt are my gurus!) I to have elected to add the elevator balance feature. I've most likely done this wrong (inexperience) as I've simply cutout a bit of the tailplane and glued it onto the elevator. Recognising after the fact that the wood grain is entirely wrong for this thin extension I've elected to bolster it with a mini spar courtesy of one McDonalds stirrer. As you can see it's a little fragile! More to follow... Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted March 24, 2014 Author Share Posted March 24, 2014 So, back to the fuselage... the sanding of the nose continues, though it's still not finished yet. To keep spirits up I like to occasionally fit pieces together... plus its a good check to make sure I've not dropped any clangers! Wow, will you look at that... it looks like an aeroplane finally! My attention then turned to getting on with the air intakes. As per Andy's thread I built up the laminates, roughed out the shape with saw and block plane and then set to final shaping it... I don't mind doing one but getting two the same shape but mirrored? The devil's own job I tell you! One intake is near completion whilst the other is in lamination waiting for the glue to dry. Next I decided to apply my wing bandage. As chance would have it I found an old wing bandage tape I bought years ago and never used... well this was just the ticket so white PVA and some careful trimming and we're away! Trust me, the PVA isn't nearly as noticeable when dried and all the ragged edges were tidied up with the trust Dremel drum sander bit! More to follow... Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted March 25, 2014 Share Posted March 25, 2014 Good progress! Good to see the airframe all put together too! Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted April 3, 2014 Author Share Posted April 3, 2014 Time for the next update... Having applied the wing bandage I set about building up the underside to blend in with the nose section. Sadly I seem to have neglected to capture all these steps so can only show you the finished product. The wing fairing has been largely shaped to size, here I have shaped and glued on some intake fairings. The trailing edge of the wing fairing didn't quite blend in right so I made up a thin trianglar section which I glued to the fuselage skin. This permitted me to better feather the wing fairing into the main fuselage. Looks OK in bare wood... time will tell if when covered it all looks pants! Next up was a turn at barrel making! I found that a D cell battery is just the right diameter for tailpipe so I cut two balsa discs. These were glued into slave spine feature and then the planking began. More to follow! Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted May 11, 2014 Author Share Posted May 11, 2014 Right, well it's time for a long overdue update to my build. Having completed the tailpipe 'barrel' I set about sanding it to shape and fitting it to the fuselage. Satisfied with the axial position to avoid interference with the elevator linkage I glued it in and then trimmed it back roughly Followed by a final trim back to be flush with the fuselage sides My next job was to follow the lead set by Andy and Phil and start bulding up some wing Trailing edge fairings. This is one such fairing part complete. I also started on the tailplane blend pieces. Unlike others (rightly or wrongly) I elected to make my pieces quite long to feather the fairing in more gently. The fuselage is now pretty much done... To cover I've decided to follow the lead set by John Hey and cover my fuselage in Tissue and Dope, then spray to the final colour scheme. Having experienced a bit of a nightmare holding my BAe Hawk wilst spraying I decided I needed a more robust solution, one that will act as a stankd for the model while the paint dries. To this end I came up with this. It locates in the winge LE dowel hole and the wing TE bolt location, the four bolts set to a length to aid in securing the handle to the aircraft and also to give me a set of feet to place the aircraft down onto. That's all for now folks... more as and when it gets done! Rez Quote Link to comment Share on other sites More sharing options...
Matt Jones Posted May 11, 2014 Share Posted May 11, 2014 Nice work Rez, I particularly like the tailpipe you've made. Looking forward to the tissue and dope, get cracking as it'll take longer than you think! Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted May 12, 2014 Share Posted May 12, 2014 Looks great Rez! Like the wing fillets and your spray mount idea is a good one! Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted May 15, 2014 Author Share Posted May 15, 2014 Well... this Tissue and Dope stuff is certainly an 'Experience'! Not sure why but the tissue is rippling after having been applied... not a biggie, just a bit more sanding to correct but puzzling nontheless! This is an example of the rippling Anyway, the ripples on the fus have been dealt with and it's time to crack on with the rest of the aircraft. Here they're all laid out ready to go. The parts have all had their initial coat of dope, been sanded smooth and ready for the tissue to be applied. Tissue on the top surface applied More to follow... Quote Link to comment Share on other sites More sharing options...
Matt Jones Posted May 16, 2014 Share Posted May 16, 2014 Looking good Rez. Best get a move on though, the event's in two weeks Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted May 17, 2014 Author Share Posted May 17, 2014 I'm on it Matt! The tissue work is all done and I've just given everything the second coat of talc loaded dope. Tomorrow I'll get onto the wet & dry and see what's what! Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted May 17, 2014 Share Posted May 17, 2014 well you've got a good day/weekend for sanding outside!! I'm offline for a week now on hols but I look forward to seeing your progress upon my return!! Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted May 17, 2014 Share Posted May 17, 2014 Looking good Rez. Quote Link to comment Share on other sites More sharing options...
John A H Posted May 17, 2014 Share Posted May 17, 2014 Rez, did you try dampening/wetting the tissue before laying it on. Some tissue works fine and some gets "wrinkels" in it like you have. Almost tempting to try shrinking dope but because it "shrinks" I avoid it unless covering an open structure with tissue - I had a nasty disfigurement moment with a sheet fin once using shrinking dope, it create a permanent left rudder deflection.... unfortunately it was on a 2 channel Aileron/Elevator model Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted May 18, 2014 Author Share Posted May 18, 2014 Thanks John but not having any shrinking dope to hand I persevered... all done with the tissue for now! And so, after a weekend of doping and sanding... and doping and sanding I finally went for it and started on the primer. First up were the tip tanks... the oh so not round in section tip tanks. Then onto the control surfaces And finally the fuselange and the wing The primer stage is where all the failures of the previous stage come to light... and so on with the little dabs of filler here and there to try and correct for lack of skill and patience at the early stages One thing to note about this aircraft is... it ain't gonna be a Matt Jones Lightweight! More to follow soon... I hope! Rez Edited By Fly_Boy_Rez on 18/05/2014 20:15:17 Edited By Fly_Boy_Rez on 18/05/2014 20:16:33 Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted May 18, 2014 Share Posted May 18, 2014 Looking good Rez, can I ask - before the primer went on, did your tissue and layers of dope/talc generate the egg shell like finish we are after before the paint was applied?? I like the tip tanks - they look really good and defo a lot easier way to generate the flawless finish we are after than covering them with film!! Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted May 20, 2014 Author Share Posted May 20, 2014 Well, it's slow progress as all the little flaws and blemishes are sorted. The pinkish filler I applied on Monday was far too hard so I've now bought an alternative, a finer grade easy sand detailing filler. Oh my word... what a difference! This is how she looked partway through the very messy wet sanding. And here she is with a second coat of primer applied. Slowly but surely we're getting there... might even be ready for the 31st! More to follow... Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted May 21, 2014 Author Share Posted May 21, 2014 Finally, some paint has been applied! First up were the tip tanks... Then a splash of colour (not) for the fuselage... and the same again for the wing... ...and now everyone can see how badly I've made the wing... sigh! More soon! Quote Link to comment Share on other sites More sharing options...
Matt Jones Posted May 22, 2014 Share Posted May 22, 2014 Looking good Rez, just in time too! Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted May 22, 2014 Share Posted May 22, 2014 Looks just fine to me Rez, I like the gloss grey, will be very nice this scheme Im sure!!! Quote Link to comment Share on other sites More sharing options...
Andy Blackburn Posted May 22, 2014 Share Posted May 22, 2014 Looks fine, Rez... Is that the grey & dayglo orange stripes scheme (1967?) you're going for? Quote Link to comment Share on other sites More sharing options...
Andy Blackburn Posted May 22, 2014 Share Posted May 22, 2014 ...and as a supplementary question, can you please reveal what sort of paints you're using? Car spray cans? Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted May 22, 2014 Author Share Posted May 22, 2014 Andy, No that's not the colour scheme... Not nearly as exciting as that! All will be revealed soon! The paint is Halfords cellulose car paint, yes. Rez Quote Link to comment Share on other sites More sharing options...
Matt Jones Posted May 25, 2014 Share Posted May 25, 2014 Where'd ya go Rez? Tick tock, tick tock. Quote Link to comment Share on other sites More sharing options...
