Darran Posted February 13, 2014 Share Posted February 13, 2014 Hi I am new to model flying and building having only started in the hobby in August 2013. I started by assembling a irvine tutor 2, joined a club and started with Some flight training before the weather started getting in the way. I decided that I would join in the fun of the mass build and choose the Dawn Flyer as I liked the look of it. So with a CNC and wood pack obtained I am writing this blog from a beginners perspective. So enough about me and on with blog Quote Link to comment Share on other sites More sharing options...
Darran Posted February 13, 2014 Author Share Posted February 13, 2014 First up I have been reading and following the other blogs on the Dawn Flyer builds and these have been a great help to a beginner like me in particular BEB's blog which is very detailed. Having obtained plans and wood packs my first decision was what to use as my building station. Given that I do not have a garage and my shed needed a good tidy out before it could be used I came to the conclusion that the build would be indoors and that limited my space. After some ideas and information from the people on here I decided to create a building surface that I could move / store in as necessary. The base of my surface is a DIY workbench, I then provided a 600x1200mm flat surface in the form of a 18mm think melamine board which I attached a 70mm deep wooden support to grip in the workbench. This provided a sturdy flat surface to place my balsa building board I purchased from SLEC. So now I have a building surface which is really flat and just the job. Quote Link to comment Share on other sites More sharing options...
Darran Posted February 13, 2014 Author Share Posted February 13, 2014 Next I sourced some tools to assist with the build and some glues. I used BEB's blog for a list of tools I would need, and visited several web sites to locate some good quality model glues, again thanks to people on here I ended up ordering glues from deluxe materials. so my shopping list started with Swann and Morton scalpel and blades, Razor saw, balsa stripper, permagrit block, engineers square, several size grips and clamps I already had several rules and straight edges so no need to get them. I added the following glues to my shopping list super phatic rocket hot aliphatic resin 30 & 5 minute epoxy Now I sat back and waited for all the goodies to arrive. Edited By Darran on 13/02/2014 20:25:22 Quote Link to comment Share on other sites More sharing options...
Darran Posted February 13, 2014 Author Share Posted February 13, 2014 So where to start, I decided on three places so I could be doing something whilst waiting on others to dry etc. So I picked the rudder to start and created the shape with blocks of balsa and glued them together at this stage i did not have the exact shape but shaped after the glue had dried. This is what I ended up with. Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted February 13, 2014 Share Posted February 13, 2014 Hi Darran, that is looking good so far Quote Link to comment Share on other sites More sharing options...
Darran Posted February 13, 2014 Author Share Posted February 13, 2014 The upper part of the back end of the fus was next. Following BEB's example I added a triangular fill at the end where the 6mm strips joined to add strength and make the join easier. Edited By Darran on 13/02/2014 21:22:53 Quote Link to comment Share on other sites More sharing options...
Darran Posted February 13, 2014 Author Share Posted February 13, 2014 And then the main fus itself with the longerons, strengtheners, and f2 glued in place. Quote Link to comment Share on other sites More sharing options...
Depron Daz Posted February 13, 2014 Share Posted February 13, 2014 Clamps, clamps and more clamps. When you've got enough clamps, go get some more! Honestly the more you have the better. Don't forget the good ole elastic band and masking or sellotape, they both have their uses. Get a set of French curves, invaluable especially when extending or making new ribs etc. One tip with straight edges and the use of scalpels, glue some balsa strip on your straight edges as a finger stop. This way when you are holding the straight edge on the piece you are cutting, the finger stop stops your pinkies hanging over the edge of the straight edge, and stops you removing the tips off your fingers when you rune the scalpel along the edge. Trust me, been there and done it hundreds of times. With a fresh blade you don't even know that you have cut the tips until you see the blood on the work piece. All of my straight edges have this balsa strip now. Superglue is ok, but it is best to use aliphatic glue when building with balsa. Yes it takes longer to dry, BUT, superglue joints are brittle and can give way after time. Also longer drying time allows for spot on positioning. I use Titebond yellow, that's the bottle with the red label as there are a couple of different types used for different woods). Avoid bog standard PVA as it is rubbery. You may also find use in polyurethane glue. This is also excellent for a strong bond but it does foam up and expand, so use ever so sparingly and make sure you clamp any joints as the expansion will push an unclamped joint apart. If you do use this type of glue, lightly moisten one part with water, and by that I mean dip you finger in water and just rub it along the where you want to glue, or use a model brush. It only has to be a tiny amount of damp to help speed up the curing process. It is excellent glue, don't dismiss it from your arsenal. Epoxy is great, but can be heavy if used in large amounts, so use ONLY where necessary. Quote Link to comment Share on other sites More sharing options...
Darran Posted February 13, 2014 Author Share Posted February 13, 2014 Posted by WolstonFlyer on 13/02/2014 21:13:50: Hi Darran, that is looking good so far Thank you, this is both exiting and daunting at the same time. I hope to be a little more detailed in the rest if the build but decided to create this blog after already starting the build so playing catchup. Quote Link to comment Share on other sites More sharing options...
Darran Posted February 13, 2014 Author Share Posted February 13, 2014 Posted by Depron Daz on 13/02/2014 21:24:07: Clamps, clamps and more clamps. When you've got enough clamps, go get some more! Honestly the more you have the better. Don't forget the good ole elastic band and masking or sellotape, they both have their uses. Get a set of French curves, invaluable especially when extending or making new ribs etc. One tip with straight edges and the use of scalpels, glue some balsa strip on your straight edges as a finger stop. This way when you are holding the straight edge on the piece you are cutting, the finger stop stops your pinkies hanging over the edge of the straight edge, and stops you removing the tips off your fingers when you rune the scalpel along the edge. Trust me, been there and done it hundreds of times. With a fresh blade you don't even know that you have cut the tips until you see the blood on the work piece. All of my straight edges have this balsa strip now. Superglue is ok, but it is best to use aliphatic glue when building with balsa. Yes it takes longer to dry, BUT, superglue joints are brittle and can give way after time. Also longer drying time allows for spot on positioning. I use Titebond yellow, that's the bottle with the red label as there are a couple of different types used for different woods). Avoid bog standard PVA as it is rubbery. You may also find use in polyurethane glue. This is also excellent for a strong bond but it does foam up and expand, so use ever so sparingly and make sure you clamp any joints as the expansion will push an unclamped joint apart. If you do use this type of glue, lightly moisten one part with water, and by that I mean dip you finger in water and just rub it along the where you want to glue, or use a model brush. It only has to be a tiny amount of damp to help speed up the curing process. It is excellent glue, don't dismiss it from your arsenal. Epoxy is great, but can be heavy if used in large amounts, so use ONLY where necessary. Yes I brought loads of clamps but think I still need more. At the moment I have only used aliphatic resin for my joints. It takes a while to dry but seems very strong. I did some testing on scrap balsa and the balsa breaks before the glue joint. some good tips for keeping the ends of my fingers, etc. this is why I like this forum I have learnt so much already. Wished I had known about french curves before I started shaping the rudder probably would have made it easier. Must get some to add to my toolkit. Edited By Darran on 13/02/2014 21:33:56 Quote Link to comment Share on other sites More sharing options...
Darran Posted February 13, 2014 Author Share Posted February 13, 2014 Ok things to overcome already are Problem with my F4 former being cut at least 3mm short How to determine the position of F1 what are all these bits that came with my motor Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 13, 2014 Share Posted February 13, 2014 Hi Darran, Keep the pics coming. Re F4, I think it's drawn correctly so I'd suggest gluing the upper rear longerons to your fuselage sides and then laying this over the plan inverted and building the rest of the back end to the plan, you may need to pin some balsa blocks to the plan to keep it in shape.. Re F1 this is based on the distance from the back of your motor mount to the face of the prop driver which could be from 6 to 10mm from the the front face of the furthermost part of FC including the balsa cowl. Lay your motor and prop over the plan to see what it looks like. Hope this helps. John Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 13, 2014 Share Posted February 13, 2014 Darran, Can you post a picture of you motor bits to see what you have. John Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 13, 2014 Share Posted February 13, 2014 Nice start Darren - well done! yes F4 too narrow is a common problem. Lots of ways around it. John's mentioned one, if you look at my blog I do another. Yet others have trimmed the last cross piece of the tail upper. One thing about building - there is definitely more than one way to skin a cat! Put another way,....an old aeromodelling motto,...Ask 6 modellers how to do something and you'll get 7 opinions. 8 of which will be right! BEB Quote Link to comment Share on other sites More sharing options...
Vecchio Austriaco Posted February 14, 2014 Share Posted February 14, 2014 Not to give a 9th opinion I just say it looks good so far! The more Dawn Flyers the better! VA Quote Link to comment Share on other sites More sharing options...
Darran Posted February 14, 2014 Author Share Posted February 14, 2014 Well here's my motor and the other bits this is the first electric motor I have seen, so I guess the grip end of the bolt goes on the motor drive shaft.and the prop in between that and the washer and bolt. tightening up then closes the grip to hold the bolt on the shaft. Is this correct or do I need something else Quote Link to comment Share on other sites More sharing options...
Depron Daz Posted February 14, 2014 Share Posted February 14, 2014 Yes Darran that is correct. The nut will push the prop downwards and thus the lower collet will squeeze the bell end and grip the shaft. Quote Link to comment Share on other sites More sharing options...
Darran Posted February 14, 2014 Author Share Posted February 14, 2014 My next challenge is working out how FC actually fits at the front. My first thought and looking at BEB's blog was that it fits at the front of the fus inside, however if I offer this up straight with the bottom notch on the longeron it appears to be way to big. do I need to deepen the notch to bring it down so that the top notch rests on the top of the fus looking again at BEB's fitted FC I am now not sure that it is fitted in this way as from some photos it looks like it fits on the front of the fus and not inside. also if I offer the fus up to the plan without FC fitted on the end it looks to be a little short. Can someone advise on wether it fits inside the fus or on the front of the fus. Quote Link to comment Share on other sites More sharing options...
Darran Posted February 14, 2014 Author Share Posted February 14, 2014 Posted by Depron Daz on 14/02/2014 21:24:28: Yes Darran that is correct. The nut will push the prop downwards and thus the lower collet will squeeze the bell end and grip the shaft. So I guess that the backplate on the collet that the prop pushes against should be outside of gauze in the front cowl giving enough clearance for the prop. I plan to add a cowl similar to BEB's in his blog where he sandwiched a piece of gauze in between two balsa pieces. does the collet have to fit all the way down the shaft of the motor or is this design with the bell grip designed to allow a little adjustment depending on the exit through FC and the cowl. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 14, 2014 Share Posted February 14, 2014 Darran, I fitted my FC on the inside of the fuselage sides which looks right according to the plan. John Quote Link to comment Share on other sites More sharing options...
Depron Daz Posted February 14, 2014 Share Posted February 14, 2014 Ideally you want as much on the shaft as possible to keep everything in balance. If it's gripped on the end of the motor shaft then there is a chance that it may throw itself off centre and rip the prop and motor from the model. I've had it happen once, which required a lot of repairs. BEB has added an extra section on his nose section to make it slightly longer, which may help you get the prop closer to the model. This type of plane that the model represents, the prop is very close to the nose. Or you could drop the firewall back a little perhaps? I have this kit waiting in my model room, but haven't started it yet so cannot advise on the build. Quote Link to comment Share on other sites More sharing options...
Darran Posted February 14, 2014 Author Share Posted February 14, 2014 Posted by John Milne on 14/02/2014 21:46:11: Darran, I fitted my FC on the inside of the fuselage sides which looks right according to the plan. John Oh that's thrown me back the to the fact that it appears to be when sitting on the longeron to big with the flat lip at the bottom of the arch some millimeters away fron the top edge of the fus. This is assuming of course that I was correct in extending the longeron across the whole of the fus bottom front section from the undercarriage enforcer to the front tip of the fus. will go look at the other blogs again to see why it appears to be to big Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 14, 2014 Share Posted February 14, 2014 Hi Darren, the collet must go right back - as far as it will go. Do not assume you can adjust this forward you need the maximum "grip area" for safety. Position F1, with the motor attached, on the fuselage side such that the prop drive face of the collet is in the right position. What's the right position? Well the direction not to make an error in is to leave it too short. Position it about 7-9mm in front of the front edge of the fuselage side. Mark the position of the back of F1 on the fuselage side when the prop driver is in the position. Then you can glue it there at your leisure. Don't forget to use a square to get the alignment right. The 7-9mm give you room for your outer nose cowl added later. Regarding FC - it goes inside the fuselage side flush with the front edge. You can see this from the plan. A word of advice - the blog cannot replace the plan, the plan is your gold standard guide, the blogs just point the way and help you to avoid any gaffs! BEB Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 14, 2014 Share Posted February 14, 2014 Posted by Darran on 14/02/2014 22:11:02: will go look at the other blogs again to see why it appears to be to big Darren - check the plan - not just the blogs. Some of the formers are not quite right and do need a little fettling. But FC definitely goes inside the fuselage. BEB Quote Link to comment Share on other sites More sharing options...
Darran Posted February 14, 2014 Author Share Posted February 14, 2014 Posted by Biggles' Elder Brother - Moderator on 14/02/2014 22:58:39: Hi Darren, the collet must go right back - as far as it will go. Do not assume you can adjust this forward you need the maximum "grip area" for safety. Position F1, with the motor attached, on the fuselage side such that the prop drive face of the collet is in the right position. What's the right position? Well the direction not to make an error in is to leave it too short. Position it about 7-9mm in front of the front edge of the fuselage side. Mark the position of the back of F1 on the fuselage side when the prop driver is in the position. Then you can glue it there at your leisure. Don't forget to use a square to get the alignment right. The 7-9mm give you room for your outer nose cowl added later. Regarding FC - it goes inside the fuselage side flush with the front edge. You can see this from the plan. A word of advice - the blog cannot replace the plan, the plan is your gold standard guide, the blogs just point the way and help you to avoid any gaffs! BEB Thanks BEB I had studied the plan could see it called for FC to be inside it was just confusing that it is a little big for the gap. I will adjust FC accordingly. As for the motor fitting your explanation has helped a lot in explaining how to work out the position of F1 with my motor. I think I suffer from a lack of confidence in my own abilities, and as probably all beginners do a fear of getting it wrong. As the build goes on I will improve my confidence and learn to trust in what I am doing. As a beginner I check everything at least five times and then again before committing to it. I am sure this will get better. i have decided to fix my F4 issue by using the plan to cut out a correct sized one. Off to my local model shop tomorrow to get some stock wood for this. Quote Link to comment Share on other sites More sharing options...
