john stones 1 - Moderator Posted September 29, 2014 Share Posted September 29, 2014 He looks a bit of a lad Linds, looking forward to the video with this one John Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted September 29, 2014 Author Share Posted September 29, 2014 Looking more like Cleggy all the time now. Have added a control column and elevator bar as well to keep it all a bit vintage will add a dummy rudder bar below the feet later but for now I recon short of the scarf he's done. Next job is complete the tail linkages, the aileron servo's and a few more cosmetic touches but the maiden is probably not to far away. More soon Linds. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted September 29, 2014 Share Posted September 29, 2014 needs compo hanging on to the wing now. Quote Link to comment Share on other sites More sharing options...
Paul C. Posted September 29, 2014 Share Posted September 29, 2014 Might be a good idea to change his name from Mort, pretty sure it means dead in French!!! Mind you though first nose over on landing it might be an apt name after all 😂 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted September 29, 2014 Share Posted September 29, 2014 He'd love to fly this! It's right up his street. Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted September 29, 2014 Share Posted September 29, 2014 Looks like my dad! Black trousers & green cardi. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted September 29, 2014 Author Share Posted September 29, 2014 love the comments guys keep them coming Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 1, 2014 Author Share Posted October 1, 2014 A bit of time this evening has seen the rudder and elevator control rods made up and fitted. These are basically your traditional pushrods made from 6mm dowel and 2mm threaded rods both ends at one end and a z bend at the other to allow for some adjustment. The wires need just a slight bend towards the bellcranks due to the angle change in the fuselage but then run pretty flat to the fuselage side. The only issue is that the control rods being external have no support along there length so would be prone to bow so to cure this a couple of wire hoops bent from 2mm wire and glued into holes drilled in the outer structure help keep everything in line and minimize bow and slop in the linkage. The alternative of course would be snakes but I like the timber finish. Next job is to sort the aileron servos and linkages. More soon Linds Quote Link to comment Share on other sites More sharing options...
Nev Posted October 1, 2014 Share Posted October 1, 2014 Yes I like the timber too, it's going to look great. Quite a lot of building to do for a simple looking model, I think it's going to be a favourite. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 3, 2014 Author Share Posted October 3, 2014 Many thanks Nev. I think its all the angled bits that makes it look so complicated but like most things the trick is just one step at a time. I started writing up some build notes a few weeks back during the more complicated bits really just to keep track of the sequence and of course as always during a build you figure if you had done that bit first life would have been easier but I'm pretty pleased with how she has come together. I got the aileron servos into the wing last night so will update the blog further this weekend. Its getting very close now to committing aviation I think. Also thinking of changing the name to 'Flycatcher' - I'm thinking this is what the the pilot might well be prone too during the hot summer jaunts. Linds Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 3, 2014 Author Share Posted October 3, 2014 Bit more of an update, Hitec HS85MG servo's used for the ailerons and mounted directly onto 2mm ply plates with the output arm passing through a slot. The plates are screw fixed onto ply plates glued onto the inside faces or the ribs to secure. Photo shows just two screws but will have four of course before flying. Connection will be 2mm threaded rod with z bend and clevice. Decided to finish the battery bay and pilot fixing next and came across a little snag. I intend to use a 3cell lipo pack and made all my measurements based on one make of pack. Now since then I have bought a couple more of a new make and typically they are slightly deeper so I have had to make a small adjustment to the fuselage depth to get the batteries to fit beneath the pilot. This was done by simply adding a 6mm thickness to the front . To start with however a 2mm balsa plate was glued onto the pilot, this will allow the pilot to simply slide into a channel made up on the fuselage so that it simply slides into place from the front. I think in this case photos will explain better than words. The channel is made using a balsa section cut to the height required to clear the batteries with a 12mm wide 1mm ply plate fixed on top that sits within the gap between the forward strut and ply sides. Hook and loop straps used to secure the lipo cell. With the channel created the base of the pilot can now simply slide into place It actually turns out that the extra height required has the advantage of allowing some additional airflow to pass through from the front gap and out through the back so all is good now I guess its the wheel skid rail and tail skid next . More soon Linds Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 3, 2014 Share Posted October 3, 2014 Pilot looks great Lindsay, it'll fly like he's on rails John Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 4, 2014 Author Share Posted October 4, 2014 Well after playing about various ideas for the tail skid, none of which really working well I went back to simplicity and simply add a couple of ply doublers and made a simple plug in 2mm piano wire skid. I may come back to this later but it will do for now. Also completed the radio installation with the speed controller sitting under he wing behind the motor, I added a couple of cooling air slots in the base of the structure which I had meant to do earlier. The receiver is mounted on the front face of the main former inside the cockpit area and all the leads tidied away as neatly as possible. Next came a quick set up on the radio to check all works. Crikey she has some power with the NTM30-35 via a 50amp esc and 10x6 Parkzone Trojan prop. I'll do a full watts power check when I have a bit more time just to check the loading. Also did a check on the CG position with the 3 cell 2200mah Lipo and she is just forward of my estimated optimum position so that is a result. I have also made up some graphics so short of a few little scale type details DF2 or as she is now known 'Flycatcher' is ready for her maiden flight. More when she fly's (if she fly's) I guess plus some video hopefully. Linds Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted October 4, 2014 Share Posted October 4, 2014 yay that's a real beauty. Quote Link to comment Share on other sites More sharing options...
Tony Richardson Posted October 4, 2014 Share Posted October 4, 2014 Interesting looking little model I really like it, any plan available? Looking forward to some video of the maiden. Job well done where the heck do you find the time Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 4, 2014 Share Posted October 4, 2014 Looks great good luck with the maiden John Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 4, 2014 Author Share Posted October 4, 2014 All being well and she fly's plan will be submitted up to the Ed after that. Linds Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted October 4, 2014 Share Posted October 4, 2014 I appreciate when someone supports the original modeling ... Thank you very much Sir ! All the best and many successful flights Jo Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted October 4, 2014 Share Posted October 4, 2014 She looks great Lynds - looking forward to seeing her fly. BEB Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 9, 2014 Author Share Posted October 9, 2014 Just a couple of added touches to prevent Mort the pilot from having a bad day with the addition of the skid to the undercarriage. Made up from a couple of lengths of 6x10mm spruce steamed and bent to shape and then mounted on a couple of wire frames. An axel bar between the main U/C passes through the skid and a forward V wire fixed with saddle clamps to the skid and forward U/C mounting plate. I will trim back the wire later when I get a chance. Batteries charged and waiting for a break in the weather. Maiden soon. Linds Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted October 9, 2014 Share Posted October 9, 2014 bet it flies well sir. it looks like it will. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 10, 2014 Share Posted October 10, 2014 Looks a real treat that Lindsay , I bet you had fun making that man . Steve Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 11, 2014 Author Share Posted October 11, 2014 Well early down the patch this morning taking advantage of the weather although the grass was still very wet. Some static shots first outside of the workshop Ok no excuses, the motor fitted is pulling about 210 watts and the model about 2.5lb so I figured should be ok. so here is the maiden flight. Ok initial reaction is that she has more drag than expected so more power is required than the 210 watts and 250 to 300 would be much safer so will investigate a change in prop or even motor. I had 3 degrees of down thrust in and this can be reduced by half as I needed a little up on elevator trim to compensate other wise very happy. Will post again after some changes and get some in flight pics. Linds Edited By Lindsay Todd on 11/10/2014 15:40:49 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 11, 2014 Share Posted October 11, 2014 Well done Linds, looks great, I like the scale power levels, though getting out of some strips may be awkward Cheers Danny Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 11, 2014 Author Share Posted October 11, 2014 Cheers Danny, very cartoon scale like but not much reserve. My options are to go for a three blade prop or up the kv with another motor as 10.5" diameter is the max. Result of a few tests and I think a 1400kv is the way to go so order just placed and will fit new motor during the week when it arrives. See you tomorrow at Ashborne? Linds Quote Link to comment Share on other sites More sharing options...
