Ridge Runt / Coyote
  • 2 years later...
New life for the Ridge Runt
devil
Flying my Ridge Runt with EDF for the first time.
Set up is a 13,20 euro 55 mm Hobbyking EDF and 50 Amp esc and 1300 Mha 4 cell battery.
I think it was ment for 3 cell battery, but at that prize I will run mine on 4 cell Let's see how long it will last..
It pull 25 Amp and 295 Watt on 3 cell and 36 Amp and 560 Watt on 4 cell.
On 3 cell it flew ok, but much more fun on the 4 cell.
The EDF can be removed again in less than 30 sec.
Ahhh, the Ridge Runt, a true blast from the past! Flew pretty well for it's size as I remember, though I'm sure now it would feel woefully dated given the mouldies I've flown since. A friend and I used to fly informal pylon races with ours back in the late 80s as schoolboys. Lots of fun and you learnt to repair stuff too!
Edited By MattyB on 05/02/2018 16:07:45
I still have my Ridge Runt after some 18 years and aside from having to recover it currently, it has had many flights off the slope or towline or aerotow. The Coyote always appealed with the electric configuration but never got round to getting one.
Fortunately I kept the plans and made templates when I built mine so I can always build another if I need to.
  • 3 years later...
Here's my BALSACRAFT COYOTE. I got the kit from one of club mates - it is probably 20yrs old.. Great little glider. I modified the design by moving the servos to the wing rather than a single central servo and fixin the wing to the fuse with a wing bolt.
Here it is on the maiden at Cairn O'Mount..
  • Like 3
  • Thanks 1
  • 11 months later...
I've just spotted the posts about the 'Ridge Runt/Coyote'. I'm in the process of building the SLEC Coyote electric version very much as a nostalgia trip. With gathering years and my old local slopes no longer readily available, this little project appears attractive. I still fly mainly electric gliders from a flat field with a few other 'old timers' so the Coyote appears to offer a trip along memory lane!
Great photos too.
SW
Hello Murat
Many thanks for the post and the video of the Ridge Runt/Coyote. I've almost finished the fuselage and the wings look to be quite straightforward. A nice simple and well presented kit from SLEC. The little motor (2822-1200Kv) arrived today and will fit perfectly at the 'sharp end'. I look forward to a maiden sortie in a week or two and perhaps it will evoke some happy memories from flying similar models sometime ago.
Best wishes
SW
5 hours ago, Murat Kece 1 said:
It is a great agile flier.. Good luck with your build.
