Barrie Dav 2 Posted August 12, 2015 Share Posted August 12, 2015 Any suggestions for a substitute motor, perhaps H/King for the Permax BL-O 3516-0850 (Heron Glider). I can't seem to get a match. Has anyone built the kit version and used a subsititute motor? Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted August 12, 2015 Share Posted August 12, 2015 Might be a decent alternative : **LINK** The stats I can find for the original are: O-3516-0850 Kv - 850 Max Current - 35A Max Voltage - 4S Weight - 130g Diam - 36mm Length - 37mm Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted August 12, 2015 Author Share Posted August 12, 2015 Thanks Dave, that looks about the right dimensions except for the short (5mm) prop shaft. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted August 12, 2015 Share Posted August 12, 2015 Would the prop adaptor for the other end fit? Quote Link to comment Share on other sites More sharing options...
Bill_B Posted August 12, 2015 Share Posted August 12, 2015 I have the slightly smaller Solius (same fuselage and tail feathers), and I'm using the Airtek Apex AX/3548/900 (900Kv) to great effect. This has a 5mm shaft and I'm running a Graupner Cam Folding 12" x 6" on a 1800mAh 4s LiPo. It churns out about 675 Watts (in) and will literally take the Solius vertical from level flight. It's cheap too at £24. LINK Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted August 12, 2015 Author Share Posted August 12, 2015 Thanks for your interest Dave but it needs to have a folding prop so perhaps this won't work. That motor looks to have about the right dimensions too Bill. I'll have a 'gander'. Ta! Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted August 12, 2015 Share Posted August 12, 2015 4Max offer a number of powersets for MPX products. **LINK** If one is not posted for the Heron, I am sure a quick phone call will soon produce one..... Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted August 14, 2015 Author Share Posted August 14, 2015 Problem sorted. Thanks chaps. Quote Link to comment Share on other sites More sharing options...
Bob Bertram Posted February 12, 2021 Share Posted February 12, 2021 Conrad, your previous post was lost due to the website changeover. I replied that I used an Emax GT2820/07 motor in mine, Robotbirds have them in stock at £24.99 I think. Someone else replied and had used a motor from 4Max but I can't remember which one but only about £4 more and probably easier to get spares. Quote Link to comment Share on other sites More sharing options...
