Craig's first build Ballerina
Like kc says, if the spar is OK it just looks worse than it is. A couple of 'part rib's' and a bit of sheeting to rectify. As long as you can get it all back together straight and true it will probably fly fine, if a little heavier. Definitely quicker than building a complete new wing panel. A couple of hours 'midnight oil' to rebuild it and another hour to recover. I would give it a go at any rate. Good luck and have fun.
Hi Craig
One of the advantages of good old balsa is that repairs are always on the cards. I once crashed a Balsacraft Mustang in a vertical dive. It flew again and is still going many years later and is now with another owner. As long as the structural parts can be maintained all should be well. Good luck with repairs.
Peter
White glue and a bit of patience for gluing in spar repairs.   Cyano probably best for repairing small cracked sheet areas.
I suggest it's best to repair the rear spar first before stripping the LE apart and disturbing the front spars which might be broken. . Try to keep the wing straight and glue a new (bit) of rear spar in place whilst that wing half is flat on the board and the other half is supported to maintain any dihedral. Put the new part ribs in at the same time as the new rear spar. Let the glue dry whilst still flat on the board and weighted down as necessary. That should ensure no twist etc are introduced. Glue the servo support bits back in place. Then examine the front spars - replace or repair one at a time allowing glue to dry before starting next spar.
If the rear spar does not repair well and the wing is not straight either re-do until it is correct or think whether it is better to build a new wing half onto the good half.
Edited By kc on 01/10/2016 17:41:23
