Bustergrunt Posted June 12, 2016 Share Posted June 12, 2016 I've got the vintage bug, built myself a Tomboy (2 ch) and Cardinal (FF) and am in the process of further builds... If I were to programme my Tx so that rudder control was on max expo I.e. No proportionality, so simply left/right full throw each input, would this be 'frowned upon' if I were to come along to a S/C fly-in? Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted June 12, 2016 Share Posted June 12, 2016 just turn up with what you have got and fly it how ever you want. if then you feel you want to change your equipment then seeing how others fly may inspire you Quote Link to comment Share on other sites More sharing options...
Bob Burton Posted June 12, 2016 Share Posted June 12, 2016 Do you have a spring loaded momentary contact switch on your Tx ? If so you could possibly program that to provide the authentic single channel experience Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted June 12, 2016 Share Posted June 12, 2016 Depending how flexible your TX is, could you not have normal proportional rudder (on the stick) with a three position switch mixed in so that the rudder was also controlled by the switch (full left, centre, full right) - full vintage experience would be flying on the switch but with a safety net of the stick should you need it.... Quote Link to comment Share on other sites More sharing options...
Bob Burton Posted June 12, 2016 Share Posted June 12, 2016 Posted by Dave Hopkin on 12/06/2016 07:31:40: Depending how flexible your TX is, could you not have normal proportional rudder (on the stick) with a three position switch mixed in so that the rudder was also controlled by the switch (full left, centre, full right) - full vintage experience would be flying on the switch but with a safety net of the stick should you need it.... Full vintage experience would be a progressive rudder (left, right, left etc on each press and hold) or a progressive movement (left on hold then through right on release or press, release hold to give right via left) Add in "quick blip" and/or a third escapement position for extra fun. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted June 12, 2016 Share Posted June 12, 2016 Don't forget that back then going home with a model still intact was a good days flying  .To be really authentic you won't be able to use a black plastic bag ,instead you will need a vintage paper carrier bag  ...... just in case ☺. Edited By Engine Doctor on 12/06/2016 08:38:00 Quote Link to comment Share on other sites More sharing options...
GONZO Posted June 12, 2016 Share Posted June 12, 2016 BusterG, check out this site http://singlechannellersreunited.co.uk/phpbb3/index.php .Then get in touch with PhilG for a single channel coder. Connect coder to a FrSky 'hack' module and put the lot in a cheap plastic box to get yourself a single channel Tx. You use servos in the plane and the coder makes them respond like a single channel actuator in response to the Tx button push. Edited By GONZO on 12/06/2016 12:20:13 Edited By GONZO on 12/06/2016 12:21:52 Edited By GONZO on 12/06/2016 12:24:01 Quote Link to comment Share on other sites More sharing options...
Bustergrunt Posted June 13, 2016 Author Share Posted June 13, 2016 Cheers for the above....I'll get to a vintage fly-in and bring my planes...dunno if I'l go down the whole bang bang/escapement route, It wasn't part of my youthful experience and I feel no connection to it, however the planes of Vic Smeed, Veron, KielKraft etc are to my liking and of my past so it's the airframes and diesel engones I'll be concentrating on. Also just been informed I came 17th out of 40 entrants at the FF Nats Bowden comp at my first attempt....😊 Quote Link to comment Share on other sites More sharing options...
Don Fry Posted June 13, 2016 Share Posted June 13, 2016 Posted by Engine Doctor on 12/06/2016 08:37:02: Don't forget that back then going home with a model still intact was a good days flying  .To be really authentic you won't be able to use a black plastic bag ,instead you will need a vintage paper carrier bag  ...... just in case ☺. Edited By Engine Doctor on 12/06/2016 08:38:00 Doctor is going senile, twas not a carrier bag, precious things, twas a tater sack in Worcestershire. Quote Link to comment Share on other sites More sharing options...
Greg jenkinson Posted January 7, 2017 Share Posted January 7, 2017 Hi Folks, Like Bustergrunt the vintage bug has bitten! Have found myself building Cardinal (Mills power) and Super Sniffer (E.D.Bee mk1) Have single servo r/only, thought I might be the only person doing so, but glad to see many others doing same! Selling off some large petrol motors and buying small diesels, seems have done the "full circle" back to where I began some 45 yrs ago (albeit now with r/o radio) Don't think I have had as much fun in those years as now. cheers from "the land down-under" gregj Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 8, 2017 Share Posted January 8, 2017 The trouble is of course that nostalgia isn't what it used to be,.... BEB Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted January 8, 2017 Share Posted January 8, 2017 Posted by Biggles' Elder Brother - Moderator on 08/01/2017 13:50:33: The trouble is of course that nostalgia isn't what it used to be,.... BEB But might be light enough to get past the regulations ever looming? Quote Link to comment Share on other sites More sharing options...
