MattyB Posted September 2, 2020 Share Posted September 2, 2020 Posted by Allan Bennett on 15/08/2020 20:46:26: ...I like the idea of Matty's 'unknockable' switches too, though the need for a sequence of movements to lower the u/c on my landing approach is not very attractive -- I've got enough to do at that point in the flight! I'll have a look at it though, for I'm sure the 'unknockable' aspect could be applied only to u/c up, leaving u/c lowering as a single flip of the switch. I have updated my unknockable switches to offer the option above- you can download the OTX file for OpenTX v2.3 with documentation and all the sound files needed on RCSettings. The good news is I was able to simplify the logical switches to 3 per implementation which makes it much easier to setup Quote Link to comment Share on other sites More sharing options...
MattyB Posted November 25, 2021 Share Posted November 25, 2021 (edited) For future reference, a worked example of a throttle activated timer with reset for reference.... Edited November 25, 2021 by MattyB 1 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted November 25, 2021 Share Posted November 25, 2021 BEB is a miss...canny lad who i met a couple of times. ken anderson...ne..1...BEB dept. 2 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted August 15, 2023 Share Posted August 15, 2023 Open TX......this thread has some info on the setting up using OT. ken anderson...ne...1...Open TX dept. Quote Link to comment Share on other sites More sharing options...
PDB Posted August 15, 2023 Share Posted August 15, 2023 (edited) Missed this thread, thanks for popping it up @ken anderson. lot of great info in it. Toe dipping into the world of OpenTX having bought a second hand QX7S complete with 4in1 module for a fantastic price in comparison to other options. Been watching a bunch of YouTube videos from Painless360 and for my current simple 4 and 5 channel needs OpenTX looks straightforward with lots of capability to expand in the future. Edited August 15, 2023 by PDB 1 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted August 15, 2023 Share Posted August 15, 2023 (edited) As a long time Futaba (20) years and Hitec A9 user......I bought a Radiomaster T16s....it was a bit daunting OT.....but after while I started to understand it(just).....this thread was set away by BEB...RIP. Ken Anderson....ne...1 ...OT dept. Edited August 15, 2023 by ken anderson. Extra words of wisdom. Quote Link to comment Share on other sites More sharing options...
MattyB Posted August 18, 2023 Share Posted August 18, 2023 More interesting worked examples for reference - part 1... ...and part 2... Quote Link to comment Share on other sites More sharing options...
stu knowles Posted 17 hours ago Share Posted 17 hours ago I need a bit of help with a OTX Mixer. I have set up a twin engine (I.C.) mixer, Each engine has a separate channel. Using a three position switch I have 1. No Mix 2. Throttles mixed with rudder. Full rudder adds 5% to one engine and subtracts 5% to the other. 3. As 2 but 10% added / subtracted. This was added to the model because it has a tendency to swing to the left on take off but is also good for taxiing. The problem is when taxiing the engine which has the throttle reduced often moves into the zone where the engine stops. If I add a few clicks of throttle first all is well but in the heat of the moment this can be forgotten resulting in a stoppage. Is there a setting in OTX where if switch position 2 or 3 is in use it wont drop the throttle channels below a preset number or even the number used in the throttle trim setting?? Thanks Stu K Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted 16 hours ago Share Posted 16 hours ago I think if in the outputs menu you set the lower limit you want not to go beyond it should respect that, I stand to be corrected as I haven't used Open TX for a few years but that would certainly work in Ethos essentially written by one of the ex Open TX developers (Bertrand), worth trying though. Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted 16 hours ago Share Posted 16 hours ago Try something like setting a logical switch to a>x Thr -80 AND switch SCv then use this as the switch controlling the 10% mix. The rudder will then only be mixed in if the throttle is advanced far enough that reducing the output by 10% will not stop the engine. Mike Quote Link to comment Share on other sites More sharing options...
stu knowles Posted 2 hours ago Share Posted 2 hours ago Thanks Mike and Philip. I'll have a play regards stu k Quote Link to comment Share on other sites More sharing options...
