Danny Fenton Posted March 28, 2017 Author Share Posted March 28, 2017 Thanks guys the re-count was a big surprise, I was chuffed with where I had finished but the error was made, so had to be addressed. I just hope John Bowerman and Eric Strefford will still talk to me next month when I see them at RAF Shawbury...... Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted March 30, 2017 Share Posted March 30, 2017 Well, Done Danny on coming 1st Could not find a trophy icon sorry, but you get a Gold Star from Me. Steve Quote Link to comment Share on other sites More sharing options...
onetenor Posted March 30, 2017 Share Posted March 30, 2017 Posted by Andy Sephton 1 on 28/03/2017 08:55:14: STOP PRESS - there was a major error in the result calculation and Danny did, in fact, get a well deserved FIRST PLACE. May I be the first to congratulate him on here: May also say well done. Blimey you couldn't make it up could you One Tenor Quote Link to comment Share on other sites More sharing options...
bouncebounce crunch Posted March 30, 2017 Share Posted March 30, 2017 A belated Well Done from me. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted March 30, 2017 Author Share Posted March 30, 2017 Thanks chaps Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 2, 2018 Author Share Posted January 2, 2018 I realise this is an old thread, but I thought you may be interested in a bit of re-work being carried out on the Cub ready for this years indoor RC scale Nats at Shawbury in early March. I felt the model would benefit from having ailerons, so I have made another set of wings and included ailerons each wing will have an aileron servo, again from the Parkzone Micro series. These little servos weigh 1.4g though my extensions have increased that weight slightly. The copper wire is 36AWG varnished motor winding wire, solderig the stuff stretched my dexterity that is for sure! Cheers Danny Quote Link to comment Share on other sites More sharing options...
Graham Moore 1 Posted September 21, 2018 Share Posted September 21, 2018 Hi Danny, I really enjoyed your artical when it came out and kept it for a future build. I have now started the build and would like to know what dihedral you used for rudder/elevator only control. Regards Graham Moore Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 22, 2018 Author Share Posted September 22, 2018 Hi Graham, really pleased that you are giving the Cub a go. The cub didnt need very much at all, even in just rudder elevator! A couple of mm under each tip is more than enough. I was able to shorten and lengthen the struts to adjust this.Look forward to seeing your progress, it's not an easy build but very sattisfying Cheers Danny Quote Link to comment Share on other sites More sharing options...
Graham Moore 1 Posted September 22, 2018 Share Posted September 22, 2018 Hi Danny, Thanks for your quick response. I am glad only a couple of mm is needed as I am building mine with "plug" in wings and I will be able to keep the pins horizontal, much easier. What first attracted me to the Cub apart from the appearance was the method of construction of the ribs and flying surfaces. So far this is going well. The cowl will be interesting as I have never attempted a fiberglass job before. If I have any problems I will be in touch. Regards Graham Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 22, 2018 Author Share Posted September 22, 2018 The cowl wasnt as bad as I thought it would be, but there is scope for the weight to creep up. However you might need the weight in the nose.....No problem ask away, cant promise to remember everything mind you Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted March 3, 2019 Author Share Posted March 3, 2019 A quick update, the Indoor R/C Scale Nats are scheduled for May 12th so still time if you want to enter in flying only, or even a quick scale build These little models don't take too long to put together I will be flying my Cub with the aileron wings in scale, and either my Champ or Se5a in Flying Only. Not had much practice so just making up the numbers really, but you never know How are you getting on Graham, did you finish your Cub? Cheers Danny Edited By Danny Fenton on 03/03/2019 12:20:43 Quote Link to comment Share on other sites More sharing options...
Graham Moore 1 Posted March 9, 2019 Share Posted March 9, 2019 Hi Danny, I have not been able to do much on the Cub since Xmas due to another couple of problems I have had. Work continues now and there is not much more to do. I am struggling a bit with the cowl. I made the pattern out of "blue foam" but it must have been the wrong type as the resin melted it. Managed to resurrect it with some filler and toi re glass it but I have a lot of grinding to do on the inner surface to get to the required thickness and lose some weight. What is the spec and supplier of the correct foam? Regards Graham Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted March 9, 2019 Author Share Posted March 9, 2019 Excellent, well done Graham, sorry to hear you have been distracted from the build. A nuisance about your cowl too, you may be as well to start again with some fresh foam. The blue foam I have was from Sheffield Insulations, a Dow Corning product I think, though it is no longer available If anybody knows of a comparable foam please let us all know. I have heard the larger B and Q are doing some thick boards of a similar material?? You must use epoxy resin around foam, not Polyester. you can tell as epoxy is almost odourless, polyester stinks to high heavens! And polyester is half the price of epoxy. If you need a small block of foam for a couple of cowls let me know? I don't have much but you don't need much so I can probably spare some Cheers Danny Edited By Danny Fenton on 09/03/2019 15:09:53 Quote Link to comment Share on other sites More sharing options...
Graham Moore 1 Posted March 9, 2019 Share Posted March 9, 2019 Thanks for the prompt reply. I think the answer must be the resin. I will try again with epoxy. Regards Graham Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 14, 2019 Author Share Posted May 14, 2019 Just a quick update: The 2019 Nationals took place on Sunday 12th and i once again entered the Cub in the scratch built class. I also entered flying only, but instead of my regular foamie, I used my newer Jack Savage Se5a. It is harder to fly, but the comp gave me the hall all to myself for the four rounds. I knew i couldn't win but great opportunity to test fly. Needless to say it was a great day with a good atmosphere. A great deal more tense than in previous events, but there were a few new entrants with some lovely models and serious flying skills. I pride myself on the Cubs docs and accuracy, having had some very good advice to start your build with the docs! I was well ahead after static on this basis. However my flying is not so good. I realise the problem and will spend some summer evenings flying outdoors to get the model properly trimmed, it is much too nose heavy. Something Jon from laser said hit home some time ago and I think he is right. We often confuse over sensitive controls to a rearward c of g and I think that is what I have done. Anyway the Cub finished in Silver, which is really very pleasing, especially considering the opposition this year. Eric Streffords Lancaster, it is just like a flying version of the Airfix kit we all built as kids Ian Pallisters Veron Tiger Moth, this model is nearly thirty years old and is converted to electric. Ian flies this in flying only Graham Smiths lovely Vickers FB8 with rudder via throttle. You could crawl faster than this could fly Rob Wardales lovely Hercules, uses vectorboard in its construction My Cub Andrew Whites torpedo dropping Blackburn GP Seaplane Graham Smith flew this glorious Vimy in scratch built My Se5a, it could have flown in scale, but I elected to use the Cub, so the Se was flown in Flying only, it went well but needs a lot more trimming to get it flying right. I guided it 50% of the time the other 50% it went where it wanted! Another view of Graham's glorious Vickers Vimy A big thank you to Sean Fitzgibbon for snapping the pics, I hope he doesn't mind me sharing them here. It was great to meet you Sean, hopefully see you on the flightline next year We are having a really big push to try and get more involved next year, We are desperately trying to find a better venue with better lighting. Shawbury has been excellent, but if we want to grow the event then we must increase entries. Adding the competitive edge is great fun and really sharpens up your flying. It is not as easy as you think, and having watched videos of my flights you cant do worse! We are also not as serious as the outdoor flyers, but that isn't to say we aren't trying as hard. We have Internationally aclaimed judges and everything is very well run and organised. Please please please, if you want to get involved then get in touch. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Martian Posted May 14, 2019 Share Posted May 14, 2019 Well done Danny congratulations ,lovely set of planes Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted May 14, 2019 Share Posted May 14, 2019 Thank you Danny. The top guys in this game set the bar very high indeed! Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 14, 2019 Author Share Posted May 14, 2019 Thanks chaps Quote Link to comment Share on other sites More sharing options...
Brian Seymour Posted May 18, 2019 Share Posted May 18, 2019 Great to meet you and the other folk on Sunday, it was truly inspirational seeing your models, they look so good especially flying. I'll second Danny's comments on the competition, the flying only is easily accessible with an off-the-shelf micro model. I entered the flying only with my Micro Aces Fokker D.VII, it's a bit more effort to get flying than Parkzone or E-Flite micros but it's a nice intro to depron models and flies well. It was my first scale national, although I read the Scale Rule Book I was't entirely sure what to expect but I got plenty of helpful guidance from the organisers and fellow fliers. The judges were very good, helping settle my nerves and really getting the best out of my flying. My Dad and I took a load of videos, we aren't too au fait with videos cameras but here is a compilation of clips from the scratch build modes:- **LINK** I'll get the clips of the flying only models put into a compilation and posted over the next few days. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted May 18, 2019 Author Share Posted May 18, 2019 Thanks for posting the video Brian. Its great to the models in the air. And great to meet you and your Dad. Congrats on the win, well deserved! Cheers Danny Quote Link to comment Share on other sites More sharing options...
Brian Seymour Posted May 22, 2019 Share Posted May 22, 2019 Thanks Danny. I finally got round to finishing off the flying only clips:- Flying Only I didn't get much usable footage of some models as the anti-shake feature on the camera seemed to focus on the roof structure and the models came out very jerky. I only got a few usable clips of your SE5a, she looks gorgeous in the turns and it's great the way the registration on the underside of the wing shows when she banks away. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted May 22, 2019 Share Posted May 22, 2019 I just watched the videos, thank you Brian. The light isn’t good there and I know it isn’t easy. Brilliant, the standard of the scratch built models is amazing. Graham Smith was an awesome scale modeller when I knew him nearly forty years ago and he clearly still his. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 12, 2021 Author Share Posted December 12, 2021 (edited) Just a shameless bump on this thread: I am organising the 2022 British Scale Indoor R/C Nationals and we have managed to get Wolverhampton Universities Walsall campus on the 23rd of April. So if you want an opportunity to fly in a friendly competition against a friendly bunch then this is the chance. If we do not make a success of this weekend we may not get another shot, and we will be back to RAF Shawbury, where it is dark, and cold. I really hope that if you have a hankering to try indoor scale then you will join us. Three classes, and you can enter them all to get more flights! Flying only - eligible models are your foamy ARTF's, Micro Aces excellent range, Ares models, E-Flites etc. It must look like the full size. Kit scale - a free flight scale model modified to take radio, the surfaces can be movable, but structure must follow kit/plan. Open - This is the F4c of indoor scale. Full docs are required including three views and colour photos. The pinnacle of scale indoor R/C. We will also be having some scale pylon racing during lunch for fun, classes are: Kings Cup - Civilian aircraft Reno - Meaty warbirds copying the Reno unlimited classes F1 - scale models of the Midget Mustang, Shoestring and Cassutt etc 3 x 3 minutes races. Entry for the racing is a pound which will all go to the RAFMAA If you are interested, search for the British Scale Indoor R/C facebook group, click on the poster for the event, then scroll down to the buttons where you can say you are going. Cheers and really hope to see you there Danny Edited December 12, 2021 by Danny Fenton 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted February 10, 2022 Author Share Posted February 10, 2022 Just a nudge on this: The entry forms are now live on the BMFA website If you want to enter, especially the scale R/C on Saturday get your entries in quick as places are at a premium. Cheers Danny Quote Link to comment Share on other sites More sharing options...
