Lucas Hofman Posted March 7, 2017 Share Posted March 7, 2017 Hi Tim, This is one of the mistakes on the drawing. A straight line from L.E. to T.E is not much from the bottom of the profile. It would even be quite difficult to build it as drawn. Regards, Lucas Quote Link to comment Share on other sites More sharing options...
Martin Dance 1 Posted March 7, 2017 Share Posted March 7, 2017 Hi all. with reference to the wing tips. If you go to Lindsay's original build thread, look on page 4 and there are photos of the underside of the wing tips. There is distinctly a semi symmetrical appearance to them. I found one of the issues with the wing tips is that the underside of the ailerons are flat bottomed extensions from the underside of the wing. I found that however you do the wing tips there are some challenges. Putting the wing tip flush with the lower surface of the wing would seem to cause some problems at the leading edge. I compromised and positioned the tip core about 3mm up from the lower wing surface and then added the triangular pieces top and bottom. A total of some 18 pieces to make up each wing tip. On reflection Lucas's laminated tips would probably have been a better option. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 7, 2017 Share Posted March 7, 2017 Thanks team, I must have missed any comments on this in the blogs. I went for a fly while you sorted me out. Will have another look later. Perhaps a 1 bay shorter aileron would help the te fixing? Tim Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted March 7, 2017 Share Posted March 7, 2017 The laminated tip is also in a straight line from LE to TE. My NACA 3414 has the forward point a little higher up so the tip rests on the lower spar. I would say lift it up to the most forward part at the LE, and add triangular pieces to suit top and bottom (will not be much on the bottom). Do not bring the aileron inward! The outside part is the part doing the work. Lucas. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 7, 2017 Share Posted March 7, 2017 True Lucas but depends how much it needs to come off to get a fixing. Certainly a whole bay would be too much you are right. I will have a closer look later ..... Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 7, 2017 Share Posted March 7, 2017 Looked at the original blog again. See what you mean Martin. Definitely some 'ribbing' underneath as well as on top but not symmetrical by a long shot. Sounds like your solution is closest to the original. Tim Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 7, 2017 Author Share Posted March 7, 2017 Here's mine, i went from center of l/e to center of t/e. John Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 7, 2017 Share Posted March 7, 2017 Thanks all, I have a plan now. Tim Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted May 4, 2017 Share Posted May 4, 2017 I found a great article on how to find the appropriate CG for biplanes: http://www.rc-airplanes-simplified.com/scale-model-rc-airplane.html Not yet applied to the Ballerina, and curious to see how/if it matches with the drawing. Lucas Quote Link to comment Share on other sites More sharing options...
Simon Feather Posted July 19, 2017 Share Posted July 19, 2017 There doesn't seem to be much life in this mass build - has anyone managed to complete a model yet? Any models flying yet, and if so with what power plants? I've just updated my build blog, I have the end in sight now! Simon Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted July 19, 2017 Share Posted July 19, 2017 Simon, Mine first flew on 19 May. You can check out my build log for details and flight video. Had the cg too far back on first flight so they were a bit exciting. The plan cg is just about right. Lesson there ! Mine is electric so can not help much on ic power. I do know mine is well overpowered so flight times are around 15 mins on a 4s battery which is a bonus. Saw your log looking very neat and tidy. What finish you going for ? Tim Quote Link to comment Share on other sites More sharing options...
Simon Feather Posted July 19, 2017 Share Posted July 19, 2017 Tim - the round tip, constant chord wings and the rounded tail feathers remind me somewhat of the Hawker Nimrod, so I'm basing my scheme on what may have been used on the Nimrod or Fury - see my build thread for some examples, it'll basically be silver with roundels and yellow flashes and/or black and white checks. Simon Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted July 19, 2017 Share Posted July 19, 2017 Should look the part. You obviously have younger eyes than me, I would loose silver against the clouds. ,! Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted September 26, 2017 Share Posted September 26, 2017 I guess some more Skywriters will take to the air soon........ Mine has survived the summer and is still providing much fun as well as teaching me a lot. Some pics from today's session. Tim Quote Link to comment Share on other sites More sharing options...
Martyn K Posted September 27, 2017 Share Posted September 27, 2017 That looks very nice. Very distinctive as well Quote Link to comment Share on other sites More sharing options...
