Johns Skywriter....will it be spelt correctly ?
Posted by McG 6969 on 06/02/2017 17:47:44:
For the sake of my learning curve, may I ask you why you didn't 'soak' the LE balsa?
The radius of the stab leading edge is big, so the laminates bend around without problems. Wing tips are differrent though (when using 2mm laminates, 1 mm might go without soaking. But if one uses a water based glue the soaking to not detoriate the glue, it only takes somewhat longer to dry.
Lucas
John. Din't forget to include the balance on the rudder...... oops, too late! wink
Artistic license? Momentum taking over the design and build?
I'd go with "keeping the tail as light as possible" yes
Are you keeping it as it is or rebuilding? I don't suppose it makes a huge difference to the performance of the rudder does it?
