Jonathan M Posted December 30, 2016 Share Posted December 30, 2016 I've finally decided to start the Middle Phase with aileron wing as my first proper build. (I do a bit of regular DLG thermal hunting with a 1m Elf and a soon to be completed 1.5m Blaster 3, and have cut my teeth on the slope with a lightweight Libelle... which is otherwise floppy and certainly useless for DLG!). Although I've garnered much from various MP threads here and elsewhere, I have a few residual questions before I commit to butchery or spending any more money! The supplied snakes look a bit basic and I've got a spare gold-n-rod to use for the elevator, but would a closed-loop be superior for the rudder on this model? Will tape and glue micro-servos in the wing at the centre of each aileron, line the cutouts with 1/32 ply, and run the extension wire forward into a channel behind the LE strip. Will a budget servo like a HS-81 be up to the job, or a mid-price HS-85BB or a dearer HS-85MG? (I'm happy to spend my ill-gottens on quality, but only if really necessary.) What servos would I then need for the rudder and elevator? When I originally bought the kit my LMS originally bunged me a couple of Futaba S3003 servos (but I later diverted these for use in my Acro Wot ARTF). The two marginally dearer options are the S3004 and S3001 units, the latter being a bit heavier still. I suppose bearings are good, metal is good, both is even better... or overkill? What are the equivalent Hi-Tech servos? Going for maximum strength and longevity, I'll be inserting a couple of ply braces in the wing before applying the fibreglass belt, and I'm also inclined towards rubber bands rather than nylon bolts to secure the wing, but with a nylon bolt for the stabiliser. Also, in the event that I wish to experiment with ballast on windier sites (6 to 10oz), I intend to fit in a ply-box at the fuselage CG. Covering. This is where I'm really in the dark. I want a tough fuselage (including at least fibreglassing the underside as far back as the rear wing seating), but don't want to overdo the overall weight. I'm attracted to using Poly-C rather than epoxy, but don't know in the slightest what weight of cloth to use for this or the whole fuselage? Could I then glass the wings and tail structures using lighter weight cloth (what weight?) then spray paint? Will this all add up to an elephant-full of weight, so should I use iron-on film for everything - and then what type and/or different products on different parts? Cheers, More-questions-than-answers-Jon Quote Link to comment Share on other sites More sharing options...
Andy Blackburn Posted December 30, 2016 Share Posted December 30, 2016 My two pennorth, based on owning one for years... I think the snakes will probably be OK, although better snakes are always a good idea and I'd use a metal clevis on the elevator. You can use a closed-loop setup but it probably won't be necessary. I think I had HS80s in mine (it was a long time ago!). If you don't use metal-geared servos for the ailerons then you can guarantee that you'll bang it against a door frame at the start of a good flying day, breaking a gear set. I'd go for an HS-85MG on the elevator, personally, but anything similar will do. I think 4 oz glassfibre bandage & epoxy will probably be fine for the wing, without the extra braces. Mine never broke. Ballast box - good idea. See below. Covering; mine started out covered in film, then after a few years it was re-covered with Solartex and came out heavier. Amazingly, it flew better at the higher weight, and this seems to be common with Foss slope kits; I shouldn't worry *too* much about the weight. If you want to glass it then I'd recommend 0.6 - .75 oz (16-20 gram) / sq metre glass cloth, maybe a little heavier for the fuselage (say 1 oz sq metre). Poly-C/EzeCoat/B&Q Satin Varnish and the like will probably need about 8 coats (rubbed-down when completely dry) to get a finish similar to glass & epoxy, and the weight will probably be similar. If you've not used water-based varnish before then a) watch it because some of them shrink a lot, and b) if you put too many coats on too soon, the wood expands underneath the glass, wrinkles, and then dries like that.... Had you considered Solartex (or similar) for the fuselage and film or Glosstex for the wings and tail...? HTH. Edited By Andy Blackburn on 30/12/2016 14:03:51 Quote Link to comment Share on other sites More sharing options...
Trevor Posted December 30, 2016 Share Posted December 30, 2016 The Middle Phase is a pretty tough bird as designed, and a well thought through design too, so resist the urge to change it too much. If you use rubber bands on the wing, you don't need the additional braces. I did use the original snakes but replaced the inner of the elevator snake with piano wire. The geometry of the rudder linkage is horrible but it works well enough. For covering, I'd stick with film but apply carpet tape to the underside of the fus if there's any likelihood of landing on gravelly surfaces. Whilst a bit of extra weight won't hamper you in good lift, if you want to maintain the model's light wind capability then I'd vote for keeping the weight down (so no glass or heavy coverings), especially if you are fitting a ballast box. If you have cramped landing areas and want to do semi-stalled or side slipping approaches, extra weight will make this more difficult - unlike the Phase 6, the Middle Phase will tip stall if really provoked. A bolt on tail may well be a good thing. Certainly the banded on arrangement is not good - it's too easy to end up with the tail in a slightly different position each time you rig the model so messing up the elevator trim. Mine was glued on and never suffered more than a bit of damage around the tips. Whatever you do, it will fly - and fly well. Good luck with the project. Trevor Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted December 30, 2016 Share Posted December 30, 2016 Earlier this year I refurbished a Middle Phase 2 that had been in my loft for at least 5 years. I acquired it for £18 on e-bay. However it had never flown by the look of it, and it needed radio plus servo's (I used cheap metal geared standard servo's from the Component shop)and re-covering which I did with Solarfilm having removed the original Solarfilm. I have always found this covering satisfactory and used it over 30 years ago on my Flair Heron which still survives.The idea of a ballast box is good but rather than a box I have a bolt fixing for ballast on a Bluebottle glider built by my nephew over 30 years ago. Also on the Middlephase I used small snakes,metal clevices and nylon control horns. At my last IC flying session I had trouble with my 35 MHZ radio so I have dumped all my planes in the loft. Nobody from my club has mentioned slope soaring yet but if we get south westerlies something may happen and the Middlephase could have it's maiden flight? Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted December 30, 2016 Share Posted December 30, 2016 Interesting Thread . I .would love to see build photos. I am considering one as a tow glider Quote Link to comment Share on other sites More sharing options...
Andy Blackburn Posted December 30, 2016 Share Posted December 30, 2016 Trevor wrote: [ ... A bolt on tail may well be a good thing. Certainly the banded on arrangement is not good - it's too easy to end up with the tail in a slightly different position each time you rig the model so messing up the elevator trim. ...] I seem to remember that the tailplane on mine was just glued straight on to the tailplane platform, and that worked OK. A. Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted December 31, 2016 Author Share Posted December 31, 2016 Thanks to all for the feedback! Yes, I might indeed do a build-thread. I'm still very much in the research phase (no pun meant!) but clearer now on the main issues. Plenty of time yet to decide on the covering: Solartex for the fuselage and film wings sounds do-able... just a question of learning to use an iron properly! Will fit Sullivan Gold-N-Rod snakes as I've used them on my recently-completed Acro Wot and do like them. Andy said "I'd go for an HS-85MG on the elevator, personally, but anything similar will do." Did you mean for the elevator? Same for the rudder? I'm happy to install HS-85MGs all round (a weight saving here can be traded for a more robust fuselage) but will these modern micro-servos have enough torque for the tail surfaces? Happy 2017! Jon Edited By Jonathan M on 31/12/2016 20:00:17 Quote Link to comment Share on other sites More sharing options...
Trevor Posted December 31, 2016 Share Posted December 31, 2016 Yes, the HS85MGs will be fine throughout. I can't remember the figures but I seem to remember once checking their torque rating against the old Futaba 128 that we used to use and being reassured by what I found. Quote Link to comment Share on other sites More sharing options...
Andy Blackburn Posted January 1, 2017 Share Posted January 1, 2017 Trevor wrote: [...I seem to remember once checking their torque rating against the old Futaba 128 that we used to use and being reassured by what I found...] Same here - and I had mostly HS 80s in mine, and having thought about it I think it was probably a JR NES-321 or similar on the elevator and that set-up was OK. I only mentioned HS85MGs because I like them, anything similar will do. Non-metal-geared servos are fine but liable to break if you hit anything putting it in the car or if you have a bit of a prang. Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted January 3, 2017 Author Share Posted January 3, 2017 Cheers guys Have checked the torque ratings and will fit HS85MGs all round. Weighing up coverings... as my eyesight is no longer 20/20, I want to avoid trouble with orientation and long-grass re-sighting, so thinking about black fuselage and fin/rudder, broad black and white stripes on each wing bottom, with fluorescent (neon pink or neon magenta) for the tailplane and the wing uppers... what colour choice leads only to the dearer Profilm/Oracover! Waiting for the SLEC jig and other bits to arrive and will then make a start. Jon Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted May 13, 2017 Author Share Posted May 13, 2017 Update: haven't actually yet made a start, but got all the bits delivered and have a colour scheme sketched out. It appears that something of a 'house-style' has emerged, as per the proposed black/yellow version in my Gangster thread, and the MP is lined up to be built as soon as the Gangster is done... I promise!! Edited By Jonathan M on 13/05/2017 07:57:59 Quote Link to comment Share on other sites More sharing options...
David Davis Posted May 13, 2017 Share Posted May 13, 2017 I built the "ordinary" Middle Phase for a colleague some time ago. I used two small servos in the wing but otherwise the build was as per the kit with two standard servos actuating the the rudder and elevator. I never saw it fly though. Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted December 29, 2017 Author Share Posted December 29, 2017 So (a year on since starting this thread!) last night I got the boxes out, spread everything out, and re-studied both the instructions and what MP threads as could be found here. I have a week left before going back to work, and aim to get all the woodwork and mechanicals done. Basic plan: Build as light but as strong as possible (aiming to get as close as possible to CF's 34oz AUW, 11oz/sqft loading). Ballast-box at CG for up to 8oz of lead slugs (in 2oz steps). Bolt-on wings and tailplane. Servos in wings (got the aileron set from CF) using plastic SLEC servo-mounts. Hitec 85MG all round; Sullivan snakes for rudder and elevator. 2 layers of 1oz/sqft glass-cloth fixed with Poly-C on underside of fuse from nose to rear of wing-seat. Oracover all surfaces. A couple of questions or so: CF says to use PVA for main wood joints, but would Aliphatic be suitable? I assume I'd still then need to use epoxy with micro-balloons to beef up the former areas and the inside parts of the forward fuselage afterwards? I'd fit a square 4.8v Eneloop NiMh pack. Would the smaller AAA 800mAh pack be sufficient for a full flying session (say 2-3 hours), or would I need the heavier AA 2000mAh pack? Would there be any advantage or disadvantage to not having a removable hatch forward of the wing? Cheers Jon Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted December 29, 2017 Share Posted December 29, 2017 Still have not flown my Middlephase 2. Last two questions: ---To get the CG right without too much forward ballast I would fit the 4.8 v Eneloop battery. ---I would say that the removable hatch is essential , I had to re-build mine. Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted December 29, 2017 Author Share Posted December 29, 2017 Cheers for those hints Mike I've decided on a 1000mAh AA pack - as heavy as the 2000mAh version but more robust. Daft question maybe, but if your MP hasn't been flown, why did you have to rebuild? Quote Link to comment Share on other sites More sharing options...
Andy Blackburn Posted December 29, 2017 Share Posted December 29, 2017 In no particular order: I'd go for the largest Rx pack you can find; 800 mAh doesn't sound much for 4 x 3Kg servos and a receiver, and the voltage/capacity will reduce if you fly in cold weather. I normally use 2000 mAh eneloops if they'll fit. Yes to the hatch. I normally use PVA (e.g. SpeedBond) everywhere on models like this as it seems to dry quicker than Aliphatic. But IMHO Aliphatic would be fine and it's easier to sand (well, Titebond is). What is this "beefing up of the former areas" of which you speak? Oh dear. I never bother with any of that. None of my Chris Foss models have come apart so far... A. Quote Link to comment Share on other sites More sharing options...
Callsign Tarnish Posted December 29, 2017 Share Posted December 29, 2017 Having built and flown many over the years.....- Don't fret over making it super light, they all come out about the same. I used to ballast mine and it was fine.- 1000mAh is too small- Don't start beefing it up, all you do is move the failure point and add unnecessary weight. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted December 29, 2017 Share Posted December 29, 2017 On colour, I've has great success with a fluorescent span wise stripe on the leading edge. You see it coming towards you at big distances. Don't mess with Mr Foss's designs. He has a fair reputation a a designer and flyer. Build as instructed. Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted December 29, 2017 Share Posted December 29, 2017 Daft question maybe, but if your MP hasn't been flown, why did you have to rebuild? I got the plane from E-bay and just like a Super 60 I bought from e-bay I only noticed it's poor construction when I got it home. It was obvious it had never flown as the snake / clevis links to the fin and elevator were located badly, The aileron links were also poor as was the Solar film covering which may have been put on without removing the protective film ? The wing joint with Epoxy / fibre was only half complete underneath the wing, and the torque arm links to the ailerons were poor and there was no mounting for a servo. Other than the snake link to the fin none of the faults were evident on the e-bay photograph. Picture below prior to refurbishment , still not bad for £18: Edited By Mike Etheridge 1 on 29/12/2017 16:06:50 Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted December 29, 2017 Author Share Posted December 29, 2017 Thanks folks - will build exactly as Mr Foss (Sir! Yessir!) instructs! First epoxied the two halves of each fuselage side together at their 'scarf' areas. Used paper (rather than polythene) to stop the two superimposed halves sticking to each other (this easily scrapes or planes off when the glue has dried) and took care to ensure the front part was parallel to the back part. Its a bit weird not having a plan to study or work to, just a set of written instructional steps with a few detail sections and perspective drawings. I understand why CF has always done his kits this way, but I miss the 'visual' side of things which I'm used to with rubber FF etc. While dribbling 'orrible epoxy everywhere, I glued the ply formers to the sheet of 1/8" which then get cut to act as doublers. A quick flushing off and a buzz with the Dremel had the formers complete - including opening up the forward one to allow a 2000mAh AA pack to slide through. Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted December 29, 2017 Author Share Posted December 29, 2017 While waiting for the epoxy to dry, attention turned to the wings. I pencilled-in a position for the servos, based on 1/3 of the chord (roughly the fattest part and coincidental with the CG) and 40% from the root to the tip. I briefly considered angling the servo slightly so that the control-rod is fully perpendicular to the hinge-line, then decided it wouldn't make the blindest bit of difference so left it as it is. The covers are from SLEC and fit the Hitec 85MG servos perfectly. For foam-cored wings the packet was supposed to include a set of dowelling studs which get glued in to the corners of the excavated cutouts, then the plastic covers screw in, but these were missing. Ne'er mind, I had some 8mm dowels lying around anyway. I intend to run servo extension wires in shallow groove in the foam behind the LE of each wing. I already has some in my possession, so bought a pack of connectors - something else to do while waiting for glue to dry! I don't want to shorten the existing wire and connector from the servo (in case unforeseen circumstances require the servos to be re-cycled!), so I'll coil up the excess and plug beside it in the cavity. That's it for now. Off to the pub! Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted December 30, 2017 Author Share Posted December 30, 2017 Next up was to wrap my braincell around the fuselage longerons. The bottom one is 1/4" sq balsa, the top 1/4 x 3/8" spruce. These needed marking at 3/4" intervals, then sawing through 1/8" (half way) on the insides of the curves - which switches on the bottom longeron from inside at the nose to outside down to the tail. Talking of braincell - which is behaving particularly slowly at the moment - I've learnt the hard way to carefully pencil the orientation of each part and which side of what other part it attaches to, then figuring out and dry-fitting as much as possible before getting the glue-pot out. ...all of which revealed a slight issue with Former 8 (the foremost one), which appears to not be quite high enough for the notches to fit the bottom longerons! It is possible that it should position further forward, but the absence of a plan makes this difficult to fathom. But, if it does go where it should alongside the marked-out upright, then its no sweat to just glue on an extension piece when the time comes. Tomorrow will start gluing - and hopefully soon shift into second gear! Edited By Jonathan M on 30/12/2017 19:39:33 Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted December 30, 2017 Author Share Posted December 30, 2017 One more thing: I've decided to splash out and fit one of those switches that incorporate a battery charging/checking port - so the wings can stay bolted on from home to slope and back again. **LINK** Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted December 31, 2017 Share Posted December 31, 2017 Looking great Jonathan! I had a former that was smaller than it should have been on my Amethyst, it wasn't supporting the wing or anything so I just slid it back a bit until it did fit. I fitted a switch with charge port to my Wildthing, allows you to bury the batt and largely forget about it! Nice looking model the phase, are you still intending on your original colour scheme? Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted December 31, 2017 Author Share Posted December 31, 2017 Thanks Tom. At this point, the only thing that is set about my colour scheme is the Oracover in my possession: a black roll and shocking florescent pink one (much more intense than in my sketch), plus a roll of white trim. A mate suggested I might reverse the colours on the fin/rudder, so the base colour comes pink for better visibility and the number black. Aside from (avoiding) the extra work in cutting out all the lettering, I'd be interested to hear how the scheme can be made more visually effective. My Blaster DLG (albeit a different game to slope) looks like this in the air. Into a bright sky everything goes black, but otherwise the florescent orange sticks out well as does the broad white underwing stripe. Quote Link to comment Share on other sites More sharing options...
