Tim Ballinger Posted February 9, 2017 Share Posted February 9, 2017 So I have plans, wood and the critical item - straining fluid so I had better get started. The CNC pack I had yesterday still has the fuzz cut short so better fix that to start with. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 9, 2017 Share Posted February 9, 2017 Welcome aboard Tim, looking forward to following your build. John Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 9, 2017 Author Share Posted February 9, 2017 interestingly even though the fuzz sides were cut short in the wood pack the actual length of the wood was just right. So I undid the cnc cut with some thin cyan , extended the lines and hey presto. Join looks good enough for now. will pay more attention later. Doublers glued on , flush top and bottom as per plan not with the 6mm gap at the top as indicated in the original build log. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 11, 2017 Author Share Posted February 11, 2017 Really love the building jig. Might never have found that without you guys. Certainly looks wide when you stand it up. Nothing glued as yet just wanted a look see. Tim Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted February 11, 2017 Share Posted February 11, 2017 Glad you like it Tim. Make sure you read and understand the instructions and use the grid to full effect! Don't forget to mark the center of the formers for alignment too. The jig uprights aren't as stiff as they could be so use a square to check the fuselage sides against the base board. If you need to you can use elastic bands across the top of the black uprights to pull them in a little. Looks good sitting there. Make sure you do a dry assembly run first before glue. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 11, 2017 Share Posted February 11, 2017 You fitted the outer stringers yet or left them till fuzz has been joined ? John Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted February 11, 2017 Share Posted February 11, 2017 Clever to fill the laser cut and extend the fuselage sides! The plastic angles of the jig are a bit weak, resulting in the sides only being pressed in near the bottom. Often this does not matter but where it does I use rubber bands at the top. (see some pictures in the Gentle Curves thread if this is unclear). Good luck Tim. Lucas Edited By Lucas Hofman on 11/02/2017 13:17:47 Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 11, 2017 Author Share Posted February 11, 2017 Yes John the outer stringers are on. I intend to talk nicely too it to it when bringing the tail together; perhaps with a whiff of ammonia ! Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 14, 2017 Author Share Posted February 14, 2017 F1 back to F7 all glued. Motor appears to point in the right direction. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 14, 2017 Share Posted February 14, 2017 What motor/esc/lipo set up you gone for Tim ? Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 14, 2017 Author Share Posted February 14, 2017 John, its an overlander 900kv,770W 3548/05, 60A ESC and a 4s Lipo. Spec says an 11x8 but thats is a bit of testing yet to do. Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 15, 2017 Author Share Posted February 15, 2017 Not sure had the building entered knife edge . Better this way up. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 15, 2017 Author Share Posted February 15, 2017 The power of ammonia? Admittedly it did not take as much pressure as I had been expecting but having clamped the tail posts together I gave each side, inside and out, below the tail seat a coat of ammonia. Left it couple of hours and took the clamp off to find it had pretty much set in the right position. Hopefully no dramas after it has been glued. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 15, 2017 Share Posted February 15, 2017 Looks perfect Tim. looks like i'll be buying some strain remover then side thrust is very noticable, the camera making it look more pronounced ? Your lecky set ups very similar to mine, what mah you gone for with lipos ? Joh Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 15, 2017 Author Share Posted February 15, 2017 I think the spinner makes it look more.Calculated to cross the centre line at the prop driver which looks to be about right. we will see. Well currently i have a 3200 that I use in the the Riot XL so i may just get another if the setup works ok. Tim Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted February 17, 2017 Share Posted February 17, 2017 Sound more then enough. With 900kv on 4 cell a 11x7 prop will give you more then 500W already. With too much power on tab you have to be careful with the throttle: Lots of power gives lots of torque and when that is applied at low speed you may stall the left wing. I witnessed a crash on our (ice)field a few weeks ago where I think this is what happened. The pilot pulled the plane off at too low speed and went steep up. When things became unstable he jammed the throttle and a split second later he spiralled down anticlockwise. Since he was only 5-10 m. up he had no chance to correct. Lots of damage. But then, you can always set the throttle endpoint under 100%. That gives you added flightime too. Lucas Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 17, 2017 Author Share Posted February 17, 2017 Bit like applying rapid full throttle with full flap, a thing to be avoided. Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 18, 2017 Author Share Posted February 18, 2017 Made up the cabane struts. All seem to be in the correct plane. There were two failures on the way. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 20, 2017 Author Share Posted February 20, 2017 So while musing over hatch latching (still not decided which method, perhaps both) I put in the control runs and then the rear stringers. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 20, 2017 Share Posted February 20, 2017 Now it looks the business Tim Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 20, 2017 Author Share Posted February 20, 2017 Little irritating. Added the underside sheeting as per the plan in 2mm sheet forgetting the tail plate was 3mm ply. Now I have a 1mm ridge. I say the original build had used 3mm sheet, perhaps that where the glitch came from. Ah well not too serious . Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 20, 2017 Author Share Posted February 20, 2017 I made the u/c plate a bit thicker by using a 6mm ply plate inset between 3&3a. Then a 3mm ply plate on top. The 6 mm inset sits just clear of the wing dowel. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 20, 2017 Author Share Posted February 20, 2017 Not sure if anyone else has noticed but the 6mm cowl underside is drawn 20mm to narrow at the 'wide' end. That is 10mm each side. Hence the cnc part is also too narrow. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 20, 2017 Author Share Posted February 20, 2017 So being frugal I returned it to its cut out, applied cyno to the join and re-made the part. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 21, 2017 Author Share Posted February 21, 2017 Now for the ammonia trick. Certainly clears your sinuses! Quote Link to comment Share on other sites More sharing options...
