Michael Adams 3 Posted February 23, 2017 Share Posted February 23, 2017 HI, can any one please explain why the Radian glider folding props are so different to any other make, the fixing is 2 brass rods instead of screws or threaded bolts, also very difficult to obtain. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 23, 2017 Share Posted February 23, 2017 https://www.sussex-model-centre.co.uk/prop-blades-12x4-radian-xl-2-6m Quote Link to comment Share on other sites More sharing options...
Michael Adams 3 Posted February 23, 2017 Author Share Posted February 23, 2017 HI Denis, the model I have is the 2 mtr wing span Radian, the blades are 9.75x7.5. I have managed to get a spare set but it was quite difficult, thanks for your reply. Mike. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 23, 2017 Share Posted February 23, 2017 My favourite plane Mike, and colour, The Grasshopper in your pic, I dig the utility. I see now your prop problem, and agree, but this runs true with many fittings on ARTF when they " reinvent the wheel" to make it difficult for us to buy elsewhere, and then you get greeted with "no stock" Our problem is that the Radians are great flyers, Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 23, 2017 Share Posted February 23, 2017 hello Michael...why not swop the whole lot prop adaptor and blades for something over the counter -save having to search high and low for the specific radian one's... ken Anderson..ne...1 high and low dept. Quote Link to comment Share on other sites More sharing options...
Michael Adams 3 Posted February 23, 2017 Author Share Posted February 23, 2017 Hi Ken, thank you for the info, I had thought of that, if I do break the ones I have found then I will sort some thing out like that, I suppose it just means sizing the motor shaft to get the right ones so long as the blades are the same size. Many thanks. Mike. Quote Link to comment Share on other sites More sharing options...
Michael Adams 3 Posted February 23, 2017 Author Share Posted February 23, 2017 Hi Denis, yes I am lucky to be able to fly from a full size landing strip, this plane is a full size it was taking off when I was there to have a fly, Ken is right as well, saying to change the lot so as being able to buy off the shelf, if I do brake another then that is probably what I will do. Many thanks for your reply. Mike. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 24, 2017 Share Posted February 24, 2017 hello Michael...have a look here-sure you'll get sorted.... ken Anderson...ne....1 folding prop dept. Quote Link to comment Share on other sites More sharing options...
Michael Adams 3 Posted February 24, 2017 Author Share Posted February 24, 2017 Hi Ken, thanks for info, I did have a look but no joy 9x6 was the closest to the originals, 9.75 x 7.5 I expect they would be ok but Gliders models have been able to source some for me so I will use those. I did have a look to see what the motor shaft size is but boy did I have a job to get the prop nut off, some one missed the flat and damaged the edge of the flat where the grub screw goes, still I did get it off and the shaft size is 4.03mm. Typical RTF I suppose. If all else fails then I will do away with this and use some thing off the shelf from a model shop. Thanks again and it is nice to know that there is some one out there who is willing to help others. Mike. Quote Link to comment Share on other sites More sharing options...
