How many plan-built models have you made or started in the last year?
Suggestion for another poll allied to our existing one.
How many models do you have under construction at a time?
Personally, I have a rule that I only try to work on one project at a time as I find it all too easy to lose focus when jumping from one to the other. Doesn't always work out that way, of course, so often I find myself with two builds on the go, especially where you might hit trouble with one and it's best just to give it a rest for a while. Don't know how others manage to work on half a dozen models at a time (certainly not complex plans or kits) it would drive me mad.
Posted by Cuban8 on 25/04/2017 10:03:48:
Too many Red faces for me to answer that question...........5 under some stage of construction and some sitting for around dust covered 5 years too.
Most of models are now own design or scaled from other proven designs and then redrawn into CAD and I then build from my own plans.
In the past 12 months I have built from my own or others plans:
1 Electric Glider 100" span
1 Bungee Hi Start F3-RES Glider 2m span
2 Kwik Fliis 88% scale of full size
1 DH Hornet Moth 1:13.5 scale
1 O/D FF Glider in progress 36" span
1 Mystic 40 85% scale of standard Mystic
1 O/D Fun Flier
1 Slope Soarer from a kit (Does that count - just spotted that it doesnt)
1 Peanut sized Fred (Still under construction)
1 Peanut Andreasson BA4
If you add the plans that I am working on but construction not yet started
25% scale Foka4
22.5% scale Spinks Acromaster
F5J Electric Glider
F3-RES Glider
PSS FD2
I need a spare life..
Martyn
Edited By Martyn K on 25/04/2017 13:56:40
No plans for me thanks.
I think that's because I work to drawings every day and the only chance I get to be creative is when something goes wrong.
Everything comes off the top of my head so to speak. Though I do occasionally search through what's available on aerofred.com for clues on how to do something I'm not sure about. Even then I may ignore what I've seen. smile p
The general numbers are pretty much as i expected.
The down side is that at say 3 models per modeller, assuming that there are 60, 000 of us, say approx double the BMFA membership. That is not a lot of model aircraft, particualrly when it is not of one model/design. A total of say 180,000. at £200 each, that is in the region of £36,000,000, shared out across the UK LMS.
If we assume that the turn over in model aircraft things is *10 bigger still, the total is still only £360,000,000.
If I assume that there are at least 3 other model areas, such as boats, trains, we still only seem to be speaking of £1 million.
I must be omitting some things, as these numbers do not indicate a viable present, never mind a future.
Edited By Erfolg on 27/04/2017 18:51:02
  • 4 weeks later...
