scott finnie Posted June 20, 2017 Share Posted June 20, 2017 So I'm currently using Model Technics contest 10 with a Os 32. The question is if have a gallon of Model Technics Gx-5 i have sitting here. Is it ok to use it? Will there be much power difference etc. Thank you. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 20, 2017 Share Posted June 20, 2017 Not enough to worry about. You may have to play with the idle a lttle but not necessarily. Quote Link to comment Share on other sites More sharing options...
Jon H Posted June 20, 2017 Share Posted June 20, 2017 The gx5 is full of castor though. that will make a mess! Quote Link to comment Share on other sites More sharing options...
DCW Posted June 20, 2017 Share Posted June 20, 2017 Hi Scott. Can I refer you to a previous latest post, 'Caster Oil', by ChrisH. Start to finish that says it all. Happy landings DW Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 20, 2017 Share Posted June 20, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 20, 2017 Share Posted June 20, 2017 Scott, if it was stored OK, mainly cool and in the dark then use it up. Don't mix it with anything else, And as has been said, there is little difference with the 2stroke power Providing the fuel is ok Try a tank full, but don't accept anything less than good running Quote Link to comment Share on other sites More sharing options...
