Martyn K Posted July 24, 2017 Share Posted July 24, 2017 A bit of a lull in the build program. I managed to wreck my 61 powered Kwik Fli IV a couple of weeks ago when the tailplane failed in flight (again). Although the decent was quite gentle, the rock that final stopped the decent wasn't and the model (and engine - which took the impact) destroyed itself.. So I need a replacement. I have always fancied this, it was featured on the cover of Model Builder (American mag) back in 1982 and there were two things that immediately appealed to me. Sadly the young slim model was one of them.. <sigh> The other model is huge compared with other models of the era. But compare the outline with a modern F3A (monoplane) and you have - A highly swept back wing - A long moment arm The tailplane looks a little big but that will keep it stable, maybe a bit ponderous A plan was procured and the specs off the plan look like this. That 11lb AUW with a big wing and draggy fuselage - even powered by a hot 61 looks a little excessive, so my plan is to replace the Rossi with a Webra Speed 91 with pipe, which hopefully will make the performance more or less similar to other models of the era. I am also going to try and shed at least 2lbs off the weight with careful wood selection and removal of some of the excess. There is a lot of wood - especially in the fuselage in this model. One other change is that the wing ribs will be cut from 6mm Depron. Simply because I cant afford the amount of balsa required for the wing ribs.. There will be other lightening efforts as well during the build, but hopefully I will end up with a nice flyable model that is in character. So my first attempts with Depron and the tailplane I have never used Depron before so it was a case of taking things very steadily., clamping all parts together while the glue dries and constantly testing the strength of the assembly . Starting from the centre section, spars cut and pinned down and the first 3 ribs installed and allowed to dry. Using PVA for this which seems to be working well. The lower side of the tailplane is built flat so there will be a little effective anhedral So far so good One thing I did notice is that the Depron has springiness. So pushing the spars into a well fitting slot results in the Depron pushing the spar back out again... Hey ho.. Elevators are assembled in the same way except built directly onto the sheet. All going together well but a little more slowly as I am letting the glue dry thoroughly before moving to the next step. Tailplane and elevators just about completed after planing and carving and sanding the excess wood away. A little weight has been saved by using cap strips behind the spar instead of fully sheeting the tailplane. Hinge slots have been cut and its ready for covering. I have also cut out one set of wing ribs for the wing. To give some idea of the size of this here is a shot of the paper templates laid out on the Depron. That's a 1m rule at the back.. So far so good... More to come Martyn Quote Link to comment Share on other sites More sharing options...
John Timmis Posted July 24, 2017 Share Posted July 24, 2017 Hi Martyn That wing looks like an ideal candidate for a 'laser' construction. (Hybrid foam & balsa). Cheers John Quote Link to comment Share on other sites More sharing options...
Martyn K Posted July 24, 2017 Author Share Posted July 24, 2017 Thanks John Not sure what a laser construct looks like, but I am planning on building the wing the same way as the tailplane (foam ribs replacing balsa ribs). What is the difference? Quote Link to comment Share on other sites More sharing options...
John Timmis Posted July 24, 2017 Share Posted July 24, 2017 Hi Martyn It's a wing construction that combines traditional balsa construction with wire cut foam ribs. It sounds a bit complicated & it is a bit different, but it works very well. I tried it on a smaller wing & was well pleased. Google " laser method of wing construction by Patrick Mullen" for a full explanation. Cheers John Quote Link to comment Share on other sites More sharing options...
Martyn K Posted July 24, 2017 Author Share Posted July 24, 2017 Hi John Yes, I am aware of that method. The way I saw it written, it involves gluing strips of blue foam at the correct rib spacing then cutting as normal using a bow with templates at each end, build the top half then cut the lower section, flip the wing and complete (IIRC) I did think of doing that with this model but I didn't have any blue foam. I may try that on my next slope soarer though Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted July 24, 2017 Share Posted July 24, 2017 Martyn K That all looks very sound. The only thing to be aware of is the fact that Depron is much weaker than the same section of even the lightest balsa so using Depron ribs you have to be careful that the spars are adequately supported. I note the tail plane has balsa shear webs between the inner pair of ribs but beyond that there is only the soft Depron rib keeping the spars apart This could represent a 'weakness' that might not have occurred using balsa ribs. It would depend on the thickness of the balsa compared to 6 mm Depron. Most models are built grossly over strength so doubt it will really make any difference but it is worth bearing this sort of structural issue if you use Depron where the forces do become significant. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted July 24, 2017 Author Share Posted July 24, 2017 Thanks Simon.. I am using 6mm Depron for the ribs. The plan shows no shear webs at all on the tailplane so these have been added to the 3 inner bays each side. No problem adding them across the full span - just trying to save those grams and the target kg will hopefully look after itself. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 22, 2017 Author Share Posted November 22, 2017 errrr. Apologies. I had forgotten I had started this blog. Spotted it yesterday while I was looking for another build blog. So there is a bit of a catch up. The fin. Its big - very big for a classic F3a. Quite simple construction and built directly off the plan except I have used Kevlar cloth as my hinge material That's a 300mm rule to give some idea of bigness. As expected, there were no real problems with this, a simple cut and glue exercise. The Fus - despite my misgivings was almost built as per plan. It is still stupidly wide and boxy but I have increased the depth of the 1/6 ply doublers so that the whole of the inner fus to behind the wing has extra reinforcement. the plan only shows a 30mm or strip which seems to be asking for trouble. All the formers except the firewall are built up. The upper side has a 1" Triangle which doe its length is in 2 pieces. I am using harder wood at the front - lighter at the rear which as you can imagine caused a few problems when I pulled it together at the rear. Lines up in the jig and overhanging front and back.. Note the tailplane has been aligned level at this stage with the top of the fus. All very simple and typical build method of the boxy models of the era. Now with the 12mm top deck added and the fin and tailplane fitted. I added extra triangulation around the side of the fin for strength but also to improve the airflow over this area. The elevator push-rod is a length of 6mm C/F tube with two M3 steel push-rods epxied then bound with Kevlar thread and more epoxy. It seems quite stiff strong and light. These terminate with some decent horns on the elevators. The rudder will have a closed loop cable system. More to come Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 22, 2017 Author Share Posted November 22, 2017 The wing was fairly straightforward except it didnt fit either my building board or my bench.. Not the span, but the 20" root chord.. Apart from the use of Depron ribs and additional ply reinforcement around the retract bay its fairly straightforward. Again - its not complex, just big To make sure that the TE was straight. I aligned it vertically. The plan shows two separate halves joined with FG bandage - as you would use for a foam cored wing. I have used a 3mm ply dihedral brace The fus sits in the gap at the LE - you can see the 1/16 ply doublers for the UC blocks here Sheeting the wing was very straightforward, surprisingly not that much was used as many of the cutoff pieces were reused Wing fitting was entertaining. It was at this point I spotted another error on the plan. The LE gap for the fus fitment was about 12mm too wide. So additional thick ribs were added to fill in the gap. There are lots of errors on this plan. None insurmountable but it looks like Joe passed the model to the draughtsman and said "draw that". Just fundamental errors all the way through where basic reinforcement is missing for example. I gather that this was not as the top of the Bridi 'Must Fly' list. The ailerons were laminated from 1/2 and 3/16 sheet balsa (seriously), glued then planed to shape.Very satisfying when you can plane accurately like this Aileron servos have been exercised and I have fitted them internally. One thing I did notice was that they tended to flex the ribs so the two adjacent ribs were linked with 1/8 balsa which stiffened them up nicely. The servos are screwed to a ply backing plate that is glued to the ribs. The wing bellypan area was fitted with wing attached. It uses a M6 bolt at the front and 2 x M4 steel bolts at the rear. Needs quite a bit of interpretation regarding wing mounting plates etc. The front bolt is guided into place down a length of 12mm internal diameter brass tube. Otherwise it would likely get lost in that bellypan area More to come Edited By Martyn K on 22/11/2017 14:48:31 Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 22, 2017 Author Share Posted November 22, 2017 A bit out of step. The wheel wells have been a bit of a pain. I used a 3" dia jar as a mold and wrapped damp 1/16 balsa around them and glued them directly onto a piece of 3mm balsa That worked really well and I was certain I would get round wells. I didnt get them . They are not too bad but still look decidedly angular in places The canopy has been fun The canopy is a glass fibre item that contains the tuned pipe.A foam core cut on the bandsaw then covered liberally with three dollops of plaster of paris. What a mess. Great fun. When dry, a surform was used to shape it then finished with sandpaper. About 5 coats of polyurethane (not water based) varnish to seal it. A very liberal coating of Beeswax and a plug was produced using Fibre Glass Tissue and Mat This has turned out quite well but unfortunately the plug got damaged when I tried to pull it.I am also having a problem with blue PVA rel;ease agent not flowing very well - or rather condensing into clumps after application..I darn't try and make the final canopy unless I am sure it will release OK. The cowl is again fairly straightforward and formed from thick balsa sheet triangle etc and then carved to shape. My daughter came round at the weekend and this is what is currently looks like. Coming along nicely I think. I need to get a manifold for the exhaust next. More to come. Martyn Edited By Martyn K on 22/11/2017 14:50:40 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 22, 2017 Share Posted November 22, 2017 An interesting build. I was glad to see I'm not the only one to hoard apparently useless lead acid batteries to use either as weights or true 90 degree supports for fuselage construction. It must be quite a long fuselage to overhang both ends of a SLEC fuselage jig. As looked at your picture I had a glance at my own jig leaning up against the adjacent wall. I'm never sure whether it's best to build the entire airframe and then cover it or to cover before assembly. My Mew Gull looks a bit odd at the moment as the fuselage is incomplete (just a few small jobs) but the tail plane, fin, rudder and elevators are all covered because I chose the latter option. I assume you prefer the former from you photographs. I needed some carbon pushrods for my quarter scale Mew Gull and acquired some 5.5mm carbon tube at the recent LMA Gaydon static show. There were also some neat alloy ends that allow 3mm threaded rod to be epoxied into hole. It makes very neat and more than adequately stiff push rods. I can't remember which supplier it was unfortunately and, as I paid cash, I don't have card receipt. btw I hope you aren't going to press your daughter to reproduce the pose on the magazine cover Geoff Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 22, 2017 Author Share Posted November 22, 2017 Thanks Geoff My daughter would probably shy away at that although I wouldn't dare make her mind up for her. I have never been really happy terminating pushrods to the wire bits. Especially in this case they had to be done in situ or risk damaging the wood trying to fit them afterwards. I think (hope!) they will be strong enough though. Not especially neat, but secure. I tend to leave the covering until last. The next big job will be to glass the fuselage then I'll get the sealing iron out. The fus length now the cowl and rudder is attached is just less than 2m It dwarfs my Aurora which I thought until now was pretty big Martyn Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 22, 2017 Share Posted November 22, 2017 Very nice. And very large! What sort of prop/rpm are you seeing on the webra? I must admit I think you might want a bigger motor to make it go. Maybe a TT120Pro? They are routinely on ebay. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 22, 2017 Author Share Posted November 22, 2017 Hi Nigel The Webra 91ABC is actually BNIB but about 30yo. I bought it last year for the princely sum of £70. I still haven't run it. When I get the manifold, I'll bench run it and experiment to get a good combination. I am hoping to get 10k rpm using a 14x8 prop. I have a Graupner 90 sized tuned pipe for it, Anything in that area should be OK though Martyn Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 22, 2017 Share Posted November 22, 2017 Looking good Martyn, Webra, never owned a bad one. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 22, 2017 Author Share Posted November 22, 2017 Thanks John Sorry Nigel - your other point. I don't want to make this model too much out of character. It would probably take a petrol engine and I did consider a 120FS and a bigger prop. I am limited though by the size of the undercarriage retracts. 14" is about the biggest diameter I can go to with the current setup. If it too revvy on a 14x8, then I'll try a 14x10 or a 13x10. Martyn Quote Link to comment Share on other sites More sharing options...
Nigel R Posted November 22, 2017 Share Posted November 22, 2017 That should get it going ok. Perhaps I let myself fall into the 'fit too much power' camp a bit too easily. I'd go 13x10 given the choice, a bit of extra clearance, and would provide a bit more thrust at speed, for similar power/revs. Trike gear I presume? Edited By Nigel R on 22/11/2017 15:22:37 Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 22, 2017 Author Share Posted November 22, 2017 Too much power is never enough. SO I have been told. Quote Link to comment Share on other sites More sharing options...
David Oxilia Posted November 22, 2017 Share Posted November 22, 2017 Martyn, great to see the fast "all at once" progress on your MM! When your thread caught my attention some months back, I wanted to post my "interpretation" of the model as I also found that it was rather portly at 11 lbs and could easily shed 2 of them. In doing so, after sketching my ideas down on paper, I naturally gravitated to the plans and started to redraw the model shedding weight all around. I also found it way too wide so it became sleeker as well. Gone were the big blocks throughout on the fuse in favor of additional shaped formers and a 3/32" skinned top deck section. I also went with plugin wings as I couldn't see a model with a wing this large taking up space in my shop when being stored. You're a braver man than I am. If I can figure out how to post pictures here again, I'll post the drawings so you can take a look. A little late I suppose as they might have given you some additional ideas for your own build. The Webra 91 should make for a nice power plant. I originally set out with a Picco 80 RE in mind that I also picked up for a song but like some ST RE engines, sorting out the header (manifold for you lads across the pond) was a bit of a challenge due to the built in stub exhaust that these Italian engines have. It wasn't too hard to locate a vintage Rossi 90 RE though so that's what I will likely use when I get her cut and built. Current NovaRossi (Cesare Rossi's new company after separating in business from his brother who renamed the old company AXE Rossi) headers fit the vintage engines very well. Another very interesting option is the K&B 100 RE which is currently still in production. Maybe Father Xmas will bring me one this year as I was able to source some headers for it before Macs (our American header and pipe manufacturer) unfortunately closed its doors. I look forward to your ongoing fast progress. David P.S. I think I figured out the system for posting pictures. I renamed my version of the model "Mamma Mia!" using correct Italian spelling. Some nuanced differences to the design other than a rather different construction is the blended airfoiled vertical fin which transitions up from the fuse into the fin. Much like the Aurora does. Edited By David Oxilia on 22/11/2017 18:02:42 Edited By David Oxilia on 22/11/2017 18:04:53 Edited By David Oxilia on 22/11/2017 18:05:10 Quote Link to comment Share on other sites More sharing options...
David Oxilia Posted November 22, 2017 Share Posted November 22, 2017 For those interested in this model, you may find the following two links of interest: K&B 100 Aero: http://www.mecoa.com/kb/67/9500.htm K&B 100 Aero Review: http://sceptreflight.net/Model%20Engine%20Tests/K&B%20Aero%20100.html However..., I just noticed they are sold out. Too bad. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted November 23, 2017 Author Share Posted November 23, 2017 Hi David I was very tempted to slim the fuselage down. As you say its very easy to lose 30-40mm in width. However, to me that is not what Classic Aerobatics is all about. I think if you build a classic, you should stick to the outline at the very least - including any warts you may not like. When you deviate then quite simply, its no longer the aircraft that the designer intended. Anyway, last night I moulded the canopy. I gave up with the PVA release agent and reverted to good old fashioned beeswax. Several coats and lightly polished smooth. Canopy layered from 60g Carbon fibre in 5 longitudinal strips plus 1 additional edge reinforcement and two traverse bands and a little extra reinforcement where the inlet and outlet orifices will be. and after leaving overnight to set but before the resin was fully hard, I carefully removed it from the plug Its still a bit floppy so its gone back into the plug and is now sat on a radiator for a couple of days for the resin to fully harden. (Hopefully) Huge sigh of relief was heard 4 miles away. Martyn Quote Link to comment Share on other sites More sharing options...
Martyn K Posted March 20, 2018 Author Share Posted March 20, 2018 Quite a while since I updated this - mainly because I was building my little Fokker Eindecker. The construction work was mainly done, so it was a case of glassing the Fus, and applying 2pack paint and then covering and final fitting out. No photos on the glassing/painting but the engine was fitted A brand new Webra speed 91. The manifold came from Weston UK. They made a beautiful job of it too. The canopy is held in place by 3 screws into hardwood blocks. I may add a 4th at the front Tuned pipe exhausting through the rear of the canopy. Fitting out the radio gear was fun. I have never had so much space to play with... Air retracts gas bottle gives some idea of just how much space there is on there CF Elevator pushrod for the elevator and closed loop rudder control. The only problem I have is that the inlet NRV leaked so I have a replacement on order All I really had to do now was add a bit of decoration. You may want to close your eyes or squint a bit.. and and and and underneath - a slight contrast Its NOT PINK. Its heather.. Ready for a maiden I think (Edit - AUW 4.95kg but I still need to set the CG) Martyn Edited By Martyn K on 20/03/2018 14:32:49 Quote Link to comment Share on other sites More sharing options...
extra slim Posted March 20, 2018 Share Posted March 20, 2018 Drool.. lovely.. have you experience with the dynamix carbs?.. is the 91 pumped?.. Good luck with the maiden, it deserves to fly well.. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted March 20, 2018 Author Share Posted March 20, 2018 Thanks I have a Dynamix on my Webra 61 RE Redhead - its a superb carb. Sadly, this one isn't pumped. I wish it was, Quote Link to comment Share on other sites More sharing options...
Nigel R Posted March 20, 2018 Share Posted March 20, 2018 My gosh it's enormous in there! Looks great - and should fly really well at that weight too Quote Link to comment Share on other sites More sharing options...
