Martin McIntosh Posted November 12, 2017 Author Share Posted November 12, 2017 I did not spot that but thanks. Pretty sure that they are much more on the full size and other model versions I have seen but I have the option of half flap. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 13, 2017 Share Posted November 13, 2017 That looks great Martin. Can't wait for the flight report. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted November 13, 2017 Author Share Posted November 13, 2017 Thanks, depends on when I get the nose moulding done and how it fast taxis on wet grass. May have to wait until the spring but I hope not. Considering the idea of getting an 8S fan since I already have the much lighter batteries for one. Could lose 1lb by doing that but the extra cost is niggling me. If anyone wishes to lend me an uncut ABS nose cone I can take a mould and return it undamaged! Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted December 31, 2017 Share Posted December 31, 2017 Hi Martin. I have just been soldering all the connectors to my YEP 120 ESC so that I can test the EDF. I have the programming card for the YEP and wondered what settings you went with (I have the same EDF as you). I know this question was asked on Tony's thread but never really got an answer. Happy new year. Geoff... Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted December 31, 2017 Author Share Posted December 31, 2017 Hi Geoff, I asked that question also and got no response. I would need to reconnect the card and try scrolling through but am a bit reluctant in case I change anything. What I did was to google it and found a video easily enough showing how to prog. one for an EDF. Let me know if you find it or not. There are not too many settings to change. I have two YEP 100A as replacements in my Mossie when I get round to repairing it and will need to set these up when I get connectors soldered on. Just finishing re installing the gear in my newly repaired Lanc. and the Mossie will be on the bench next so will probably look at the YEP`s first. Seasons greetings, Martin Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted December 31, 2017 Share Posted December 31, 2017 The only Video I could find relating to EDF's was this one I am not sure how he manages to get two settings selected for the 'cut off type' option. Also I have noticed that if I switch off and back on, is does not show any of the settings (if you want to check them). I think this is because the YEP 120 has no BEC. Has anyone else noticed this? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted December 31, 2017 Author Share Posted December 31, 2017 Yes, that is the one I went by. Note that at the start he was recalling what had been previously programmed and I do not remember being unable to do that. I expect that you had both leads plugged in as he did. I shall look at my new ones as soon as I can. Martin Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted January 1, 2018 Share Posted January 1, 2018 nice model martin......looking forward to your flight report.....well done from me. ken Anderson...ne....1....hawk dept. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted January 1, 2018 Author Share Posted January 1, 2018 Cheers Ken. Just got to put the finish on the new GRP nosecone when I can get outside to spray it. I fear that the maiden will be way off now. Must wait for the patch to dry and be mown. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted January 1, 2018 Author Share Posted January 1, 2018 Hi Geoff, Another video followed this one and is a little better. Got nowhere with a 100A until I realised that I should have used 4S for testing instead of the 3S I was trying with, so here are my settings which work. Page 1 Timing - none Brake - off Cut off - slow down + lipo c/o voltage - 2.5-3.2 Cells - 4 Spec func - stop - 100m/s, full - 200m/s (low and high throttle, I used a servo tester) Auto timing. Page 2 Free W on, gov off P gain - none I gain - none Start up speed - plane fast Freq - 8kHz Start up power - auto Just set the cell count to whatever you are using and press enter after each change. I can now re power and scroll through the settings. Martin Quote Link to comment Share on other sites More sharing options...
Mark Elen Posted May 6, 2018 Share Posted May 6, 2018 Posted by Martin McIntosh on 05/05/2018 20:31:15: Took my version of the Hawk to the field today for taxiing trials. The grass was cut short yesterday but lots of cuttings left on and the ground underneath is still quite soft. Anyway, with those small wheels there was no way that it was ever going to reach take off speed assuming that the fan was running at maximum. One of the wheels actually fell off when taking the model apart because a grub screw came loose. The model was also leaning to one side due to an oleo leg sticking up. Easily fixed but this does not bode good for even a pristine grass field. I need some tarmac. Wish that I could transfer this post to my own Hawk build blog but don`t know how to do it. Edited By Martin McIntosh on 05/05/2018 20:34:04 Quote Link to comment Share on other sites More sharing options...
Peter Hammond 1 Posted August 22, 2020 Share Posted August 22, 2020 Hi Guys, This is an old thread I know, but did anyone have success wuith this model? I am thinking of building one as a 6s set up. Pete. Quote Link to comment Share on other sites More sharing options...
