Martyn K Posted June 29, 2018 Author Share Posted June 29, 2018 Thanks Peter. Looking at the 3V, it appears that wing was fully sheeted with only the elevators, aileron and rudder having exposed ribs. The close up of the rudder above (at the top of the page) doesn't seem show any tapes. . TBH, I am inclined to leave them off although I am very surprised I can't see any. Its never going to be a contest model but I do want it to look 'right' for things like scale fly-ins. It feels much heavier than 1.6kg so I was quite surprised and pleased when I saw the weight on the scales last night. Stuart. I am trying Acrylics (using a spray gun and compressor) for the first time on the 1/4 scale Foka. I am actually finding it far more difficult than using rattle cans because the paint takes much longer to dry. It does dry very smoothly though and the coverage and density is very good. I am using Valspar acrylic paint from B&Q. (They can colour match for you). I did originally try thinning it but it was far too runny but leave run stains rather than lumpy runs (if that makes sense). This mornings job was to make and add the trim tabs using litho plate. Epoxied and in this heat it will be dry by lunchtime. The non functional spoilers will go on after painting. They were light grey as well Martyn Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted June 29, 2018 Share Posted June 29, 2018 Martyn Thanks for the information on paint selection and technique. I was thinking of using Vallejo acrylics (haven’t checked the colour charts yet!). I have both airbrushes and an HVLP gun running off a compressor so was not looking to use rattle cans. I agree spray paint can take it’s time to dry, depends on how thin you can spray it, thinner the better, but you have to still get coverage. Very much a learner with spraying, but getting somewhere with it. Usually, if it’s the right consistency to get through an airbrush (milk-like) it will dry reasonably quickly. At least it doesn’t turn the air in the work room paint colour, almost no overspray. Given I haven’t got any Solartex to use as a base, I might be looking at Oratex or similar. Oratex is pricey but don’t know of alternatives at this stage. S Quote Link to comment Share on other sites More sharing options...
Martyn K Posted June 29, 2018 Author Share Posted June 29, 2018 Have a look at Diatex. Cheaper and lighter than Solartex but not self adhesive, Martyn Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted June 29, 2018 Share Posted June 29, 2018 Hi Stuart, Martyn proposes a good alternative there with their range. But they also have an iron-on version called Diacov 1000. You could Google that one. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted June 29, 2018 Share Posted June 29, 2018 Thanks guys, I”ll look into those. S Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted June 29, 2018 Share Posted June 29, 2018 Regarding the Solartex, I was surprised to see quite a bit of it for sale at W&W. A while ago, I did an aileron conversion on a Bistormer for a club mate and he provided some covering material which resembled Solartex but was transparent and very much lighter. Went on a treat. Unfortunately he cannot remember what it was or where it came from. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted July 18, 2018 Author Share Posted July 18, 2018 A bit more progress. Nearly all paint although I have added anti-spin strakes and trim tabs. and and and However, looking at bit more closley. I clearly cut the masks a but too quickly because the edge is a bit jagged The lettering on the right side didn't come out too well although I have managed to tidy it up a bit I have spotted some of the small letter centres and tidied some of the black with a 0000 sized sable brush but that really was a bit too big Next jobs are. Add a bit more scale detail, the instrument panels, a dummy engine and fins, klasskote clear and then a maiden. The graphics for the panels have been done, just need to get them cut. New blades please! More to come Martyn Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 18, 2018 Share Posted July 18, 2018 THat is really impressive Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted July 18, 2018 Share Posted July 18, 2018 Splendid outcome, Martyn. Well done. Cheers Chris Quote Link to comment Share on other sites More sharing options...
David Foley Posted July 18, 2018 Share Posted July 18, 2018 Well done. Looking foward to test flight report. Dave Quote Link to comment Share on other sites More sharing options...
Martyn K Posted July 18, 2018 Author Share Posted July 18, 2018 Thanks all It will still be a while before it gets flown. Hopefully completed and maidened before the Ashborne October Scale Day. Lots of fiddly bits to do yet Certainly the biggest Mass build effort I have done so far. I normally finish them within 2 weeks Martyn Quote Link to comment Share on other sites More sharing options...
Gordon Whitehead 1 Posted July 19, 2018 Share Posted July 19, 2018 Super job Martyn. I've always liked the Dalotel and I'm looking forward to seeing yours performing down at the field. Gordon Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 19, 2018 Share Posted July 19, 2018 Yep, that looks really good, I had one as a nipper, flew very well. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted August 9, 2018 Author Share Posted August 9, 2018 A bit more progress The airframe has been sprayed with KlassKote clear (2 thin coats). Seems to have gone on OK.. So mainly been working on the cockpit and the cowl installation Engine loosely fitted and this much protrudes. I can learn to live with that However, I do have a problem with the silencer. I think I will need a right angle knuckle join then short extension and I'll make my own silencer which will be heat insulated but screwed to the firewall and the exhaust venting from the centre. That will have to wait for a couple of weeks though as holidays are getting in the way From the front it looks like this. There are two dummy oil coolers. The original only had one on the LHS but I have added a second to fill an empty gap. The coolers are made from 1/32 balsa with 1/16 balsa spacers with the radiator bars angled very slightly. Quite fiddly. Painted Satin black then a little silver dry brushed in to give a bit of a highlight or two. The cockpit instrument panels have also been progressing The panels are cut from black art paper, the instrument faces are from the RCM&E download - reduced in size slightly and printed onto photo paper. Knobs and fuse holders are cut from the inner of push rods and mainly painted black. The key is a washer with a litho key glued into place. The gap is intentional. No instrument was fitted at that point. The instrument bezels were cut from thin single core instrument wire, wound as a spring and then circles cut off. Epoxied into place. Glass is 0.5mm PETG The 24 channel crystal controlled transceiver dartboard was a fiddle. I used mu Silhouette to cut the shape, tacked it down and then carefully removed the unwanted bit. The triangles are about 2mm long.. Took 3 attempts. It should look like this Mine now looks like this. Not too unhappy with that. It is a learning exercise after all I need a pilot Sadly, Ken is just too big even with 90% of his torso removed Seats and retaining straps fitted and the front windscreen with a litho border. I hadn't spotted that it kinked slightly. So - still to do. Find a pilot and dress and fit him/her. Stuff like seat belts and some cables that I missed need to be added and sort out the silencer. And I am away on holiday now for 3 weeks. Back in September More to come but there will be an intermission Martyn Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 9, 2018 Share Posted August 9, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted August 9, 2018 Share Posted August 9, 2018 Great progress, Martyn. Don't allow Big Ken to spoil your free time now... Have some enjoyable holidays. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Martyn K Posted September 14, 2018 Author Share Posted September 14, 2018 Back from my holidays and cracking along to get this finished All the control surfaces have now been fastened in and pushrods fitted. Trying to keep away from things like visible clevises which although convenient tend to detract on a demi scale model. The cockpit has been completed and things like joystick, seat belts etc have been added. brackets etc from lith and quick release from washers and pins. The pilot was a challenge. I eventually carved my own head (not literally) and produced Marvyn. Any resemblance to a person living or dead is entirely coincidental. Of course, he is a ginge, is there any other colour? Body is polystyrene with foam legs and arms. I didn't bother with hands, that was a challenge too far. Clearly a body builder but proportions look about right I compromised on the exhaust after prevaricating for a few days. I bought the 90 degree elbow from just engines and fitted the standard exhaust. A bit grubby underneath but it wiped clean. The exhaust isn't too obvious when sat on its wheels. Final jobs included fitting the curved section of the cockpit canopy and adding a lith frame and rivets and then suddenly, . . . it was finished. and and and (airbrakes are dummies, cut from lith, painted and epoxied to the wing surface) and Actually, there are still a couple of minor jobs. There needs to be a black seal that fits around the wing root and a little bit of clean up still required. The CG is just slightly on the safe side but I think I will need to move it back after the maiden, which is unlikely to happen this weekend Not much more to come.. Martyn Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted September 14, 2018 Share Posted September 14, 2018 Looks great Martyn. I thought that you originally intended it for classic aeros, not F4C. What is the AUW? What size prop do you intend to fly it with? 12x6 is good on that motor. Get those batteries charged and bite the bullet tomorrow. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted September 14, 2018 Author Share Posted September 14, 2018 Thanks Martin. The wooden prop in the photos is an 11x7. A 12x6 would probably be better. I did get a bit carried away with it. This is the first 'proper' scale model I have ever completed, the Chippie is now back on the bench so hopefully get some progress on that before the Fury build starts. I am also drawing up a 60 sized Mystic clone for next years UKCAA events. I'll publish details later Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 14, 2018 Share Posted September 14, 2018 A different type for a change, looks very good Martyn, pilot....selfie ? Quote Link to comment Share on other sites More sharing options...
Martyn K Posted September 15, 2018 Author Share Posted September 15, 2018 Thanks John. Marvyn - a dopplelganger? - nah - he is far too good looking to resemble me. Quote Link to comment Share on other sites More sharing options...
Maurice Dyer Posted October 14, 2018 Share Posted October 14, 2018 Sir, if it's Ok, could I have scoot of your scanned images of the Dalotel sections please ? Regards Maurice Quote Link to comment Share on other sites More sharing options...
