Timo Starkloff Posted December 25, 2018 Author Share Posted December 25, 2018 Then the lower stringer is glued in position and afterwards all ribs. The center rib has to be placed in the right angle, so I use a small template for that. Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted December 25, 2018 Author Share Posted December 25, 2018 The next task will be the center wing and I started preparations for that. It's 1220 mm long and so I have to lengthen spars and other pieces. Splicing (correct word?) spars is something new for me, but something usual in aircraft construction, so it's time to learn that. I made a flat parcel from all four pieces and sanded them to a certain angle (30 mm in my case, the spar height is 3 mm). Then they are glued and kept pressed together during drying. The result is really satisfying, straight and stiff and quiet easy to achive Edited By Timo Starkloff on 25/12/2018 12:32:29 Edited By Timo Starkloff on 25/12/2018 12:32:58 Edited By Timo Starkloff on 25/12/2018 12:36:22 Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted December 26, 2018 Author Share Posted December 26, 2018 First I place a balsa strip on the work bench, which guarantees the right washout of 2° (helps for much better low speed handling). Then comes the wing itself. Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted December 26, 2018 Author Share Posted December 26, 2018 Afterwards I install all neccessary pieces before planking the upper side. All I have to do then is cutting out the aileron of the finished wing. Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted December 26, 2018 Author Share Posted December 26, 2018 Spar is spruce 2x5mm, planking and the sheet between the spars 1.5mm balsa, ribs are made from 3mm balsa except some reinforcements for the tube from 3mm poplar plywood. Wing thickness at the center is 14%, 10% at the outer end. Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted December 30, 2018 Author Share Posted December 30, 2018 Little correction, wing thickness changes from 14 to 12% (14-10% is a different project The outer wings are nearly ready for planking and the inner wing also made good progress the last days. Timo Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted December 30, 2018 Author Share Posted December 30, 2018 Next model should have better dimensions It's not only the spar which has to be lengthened to 1200mm, also every other balsa strip and planking... Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 2, 2019 Author Share Posted January 2, 2019 I just had to put all parts together for a first look at the suddenly growing plane. Happy New Year everyone! Timo Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 2, 2019 Share Posted January 2, 2019 Looking good Timo Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 2, 2019 Share Posted January 2, 2019 That looks wonderful Timo. Happy New Year! Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted January 3, 2019 Share Posted January 3, 2019 Fantastic work Timo, you are indeed a master builder. Quote Link to comment Share on other sites More sharing options...
Chris Freeman 3 Posted January 3, 2019 Share Posted January 3, 2019 Very nice work, you are a true craftsman! Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted January 3, 2019 Share Posted January 3, 2019 Lovely Timo. Think that's a scarf joint on the spar. BTC Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted January 3, 2019 Share Posted January 3, 2019 ... this is becoming a real masterwork again, Timo. Such a precision is totally amazing ! Please keep on posting your progress. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 6, 2019 Author Share Posted January 6, 2019 Good to hear that you enjoy this thread I'm quiet confident with all wood work but it seems I have to get more used to other topcis, like landing gear, gear doors, cockpit... You don't care for all that when building small 1/12 models! There are certain details waiting for a solution for the Whirlwind. I'm still busy with the nacelle design and the tail wheel is another open task. That's why I'm also happy following other peoples building threads, it's just nice to watch and sometimes there is something to learn. Timo Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 6, 2019 Author Share Posted January 6, 2019 The wing tip is a bit of work, even if it's made from soft balsa. I'm working in small steps on both wings in parallel, to get two identical looking wings. Much dust from two small parts! Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 6, 2019 Author Share Posted January 6, 2019 Looking almost like a glider wing! Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 6, 2019 Author Share Posted January 6, 2019 For the center wing there are many small jobs left to do. Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 27, 2019 Author Share Posted January 27, 2019 More tasks on the center wing and no end in sight... Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 27, 2019 Author Share Posted January 27, 2019 Minor work on the outer wings and a quick check again on the looks Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 27, 2019 Author Share Posted January 27, 2019 Many hours went into the design of the nacelles, took me much longer than expected. The nacelles look huge, but at the important place there is no space to waste. Accumulator, landing gear and wing are quiet close to each other. In the end I had to redraw many parts several times for optimization. And when preparing everything for plotting at the copyshop I thought that I had drawn too many parts for those nacelles. But I will leave it the way it is now, maybe except some more hollowing of certain parts. A new redesign would take too long and even my patience is zero at one point. After all, the nacelles have some important jobs to do and have to be sturdy for that - holding the motor, a heavy accumulator and a long landing gear. So I started again ironing parts on plywood and cutting them out, but for the last time concerning that model Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 27, 2019 Share Posted January 27, 2019 Looks fabulous Timo, really tidy building. lots of work but well worth itCheersDanny Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 27, 2019 Share Posted January 27, 2019 This is going to be really special, what a great project. Just for interest, this is Petter’s next design and the Whirlwind’s bigger brother, the Welkin. I built this a few years ago but haven’t flown it. The kitchen has been refurbished since then! Petter’s life story is fascinating, through the Canberra, Lightning and Gnat. He had a very sad end through getting caught up with a fanatical religious cult in Switzerland. Hard to believe when you look at his designs from the Lysander onwards. Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 28, 2019 Author Share Posted January 28, 2019 It really is, Danny I found your Welkin pictures when I did research for the Whirlwind, Colin. Looking really good! What was the reason it never flew? The Welkin must be perfect for PSS, had anyone tried that? There are so many interesting planes waiting to be built. My plan is a 1929 racing biplane as next model, but instead in spare time I’m preparing a quick plan for some friends for a Ki-43 (for one of them it’s his absolute favourite aircraft). Not sure if I take part in that project. Could be kind of a small mass build project Timo Quote Link to comment Share on other sites More sharing options...
Timo Starkloff Posted January 28, 2019 Author Share Posted January 28, 2019 There’s also progress on the big Whirlwind. They started preparing the first metal sheets for the fuselage end and finally have the new website working **LINK** Quote Link to comment Share on other sites More sharing options...
