Fouga magister 1/4.5 moulded from scratch
dirk tinck
Sorry to hear your news Dirk, I wish both you and Diana a quick recovery - I'm afraid we caught it too last month, the kids bringing it back in from primary school - so hard to manage with the little ones.  Thankfully with the double jab it was no worse than a head cold with headaches.  Stay strong and well.  Your fantastic fuselage will be there waiting for you when you safely return to the shop.
Thanks all !!
@ Paul : I had Pfizer twice...    No guarantee right ??!!??😷
While i'm still not 100% , i have to do something or i will go crazy from boredom !🥶
I started  with cleaning the new fuselage. After de-moulding there's still a film of pva that needs to be washed away with water.
I made a (long) list of things to do , and on top are the rudders and wings. Before i start these , and shelf the fuse , i need to know if everything fits .(Hathes,nose cone , tail cone ,thrust tube)
No problem with the nose and tail cone , Just some sanding to get even seams.
The hatches require a little more work...I realize just now , i made a mistake here...I can solve it , but it's a mistake.
When i was making the plugs for the hatches (and their openings in the fuse) , i didn't take the thickness of the paint into account...this resulted in hathes who are a little oversized.I can use them after a serious trim ,but it's far from perfect.When the time comes to paint them , they will "grow "again !!
The best solution is..make new moulds for the hatches ,but first i'll try to "tape" (or even double tape ) the flanges of the moulds. This way i "win"the thickness of the tape.(smaller hatches)
They fit for now (unpainted )but they don't "drop" in place...
On to the thrust tube : I cleared the exhaust openings with the dremel with some reserve to enlarge...
After a dry fit one side... i'm very pleased !
Thesame for the left side .
The best fit i could ask for !! Thanks again Andy for the perfect plug !
Glueing the tube in is for later , after the former for the rudder support is fitted.
That's it for today !🤒
  • Like 3
On 10/12/2021 at 22:27, dirk tinck said:
Thanks for the comments  all !
This must be the first time i did not see my workshop for 3 days in a row !!...Thanks to , Yes... Covid.
The virus has finally got me , and my wife Diana...We think we got it from the grandchildren.
We both have mild symptons but work is out of order. Ten days quarantine now ...
I hope i'm over this soon and can restart working !! No work  , no pay !
Keep safe  ! Dirk
Best wishes for a rapid recovery!
If it's any consolation, I would vote for you as the AMOTY!
  • 1 month later...
Hello all !
Sorry i kept you all waiting for a month but things here didn't go as planned .
Covid had me a little longer than normal out of the shop but that's behind me now.
Before we go on , i want to wish you all a very happy New Year  !!
Last thing i did  , december 14th , was fitting all the hatches and other things to the newborn fuselage wich is now on the shelf to make room for the rudder moulds.
I already made one rudder as a test months ago , remember ? It was usable but a little overweight at 320 gr. I will try to make it lighter without giving in on strenght.
I cleaned and waxed the moulds ,gave them a coat of pva and painted them with IMC , in mould coating.
After drying , they were layed up with 50gr of glass in the corners and a second layer overall. I got the airex parts ready together with the bleeder and perforated plastic to cover the layup and put everything in the vacuumbag.
After curing , the edges will be trimmed and cleaned.
This has to cure under vacuum for at least 10hours with the current themperatures. With a proper sealed bag , the pump starts every 2 minuts for 10 seconds . (aprox)
Next thing to do is cut and fit the internals.
When happy with the fit , glue is applyed on all contact surfaces (thickened resin ) and the moulds can be closed ,bolted together and left to cure.
Thanks for watching !
Before the moulds were closed , the contact area's were waxed to prevent them from sticking together when exess gleu finds his way out of the rudder.
I was carefully with the gleu and it paid off ! The new rudder parts left the mould very easy.
After a clean-up i was very pleased with the new parts ! 225 gr on the scale ! 95 gr less than the first one !
The seams look very good and the parts still feel very strong !
I just need to spend more time on the first layer of glass in the moulds as i find here and there some small defects in the surface , nothing that can't be solved with some primer.
I only have one set of rudder moulds so next week i'm doing the other side !
Stay tuned !
  • Like 2
