dirk tinck Posted March 9, 2019 Author Share Posted March 9, 2019 Flaps and ailerons : Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 9, 2019 Author Share Posted March 9, 2019 Now the real moulding can begin: When the paint is dry and hard,first thing to do is place every part (wings,flaps and ailerons)horizontal in a frame thatdevides the part in half. To hard to explane without pics so i will leave you guys here untill next session !cheers !! Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted March 10, 2019 Share Posted March 10, 2019 Great craftsmanship, Dirk. Can't wait to follow the 'moulding' part of your bird. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted March 10, 2019 Share Posted March 10, 2019 I'm really enjoying your build Dirk. I have used Chartpak graphic tape for panel lines in the past and it is a real pain removing it once you have painted over it. I think your Dremel router method is genius - might try that on my Harvard build. Keep up the good work. Geoff... Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 10, 2019 Author Share Posted March 10, 2019 Hi Chris,thanks for replying and sticking with me !Next week will be interresting!! Finally we're getting somewhere !! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 10, 2019 Author Share Posted March 10, 2019 Hi Geoff , i've tried various tapes :chartpak , 3M fine line tape , even ordered ''special''nylon tape in the USA , but they all have specific problems :some break when you try to remove them , some leave glue residu , to thick , to thin , ... With my little tool i can choose the dept of the lines,the width of the line(just take another dremel bit) but the great advantage is that i can make really tight curves by using templates. For curved surfaces i use flexible templates and hold them in place with double sided adhesive tape. An extrea pair of hands helps a lot too !!(Thanks Diana) I also found that practice makes perfect ! especialy for lines that end up in another line. Thanks for following Geoff !! Dirk. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted March 10, 2019 Share Posted March 10, 2019 Inspired by your Dremel router attachment I had a play with my 3d design / printer and came up with this: Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 11, 2019 Author Share Posted March 11, 2019 Wow ,Geoff !! That looks great ! And in record time ! I really regret i'm not into computers,and having no time to learn more of that stuf. Succes with the Harvard ! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 18, 2019 Author Share Posted March 18, 2019 Hi all ! I started last week with the preparations to mould the first flap.It's been a while sinds i have done some moulding so i need a little practice. I placed the flap in a supporting foam block and glued it with a little epoxy after protecting it with some tape.This needs to be easy to remove so i don't damage the surface.Then surrounded the flap with casting plywood wich has a glossy surface for easy loosening.The upper side of the plywood has to be right in the centerline of the flap.Again , this is glued to the supporting foam block with epoxy with a little gap to the flap. This gap has to be filled with plasticine,it's like childrens clay and doesn't get hard.Again this is nessesary for easy removal once the first ,,shell'' is hard.Arround this frame, there is a vertical border glued in place to improve strenght of the mould.All that's left to do now is polish 7,yes SEVEN times with demoulding wax,put on the demoulding film (PVA,NOT the glue! it's a water based transparent demoulding film) and then i can paint-on the epoxy and glass-cloth layers. that forms the first mould half.... I hope you guy's can follow all this better with some foto's. Before i go further with the process i will prepare the other flaps and the ailerons and the wings naturally.Guess we'll be at least two weeks busy !! There's lots of video's on the net , check out HP textiles on you tube. Please let me know when something isn't clear ! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 18, 2019 Author Share Posted March 18, 2019 https://www.youtube.com/watch?v=xBP3f48kTj0https://www.youtube.com/watch?v=xBP3f48kTj0 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 18, 2019 Author Share Posted March 18, 2019 **LINK** Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted March 18, 2019 Share Posted March 18, 2019 Sorry it`s all Double Dutch to me. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 18, 2019 Author Share Posted March 18, 2019 Please stay tuned,it will all be clear in a couple of ......weeks Quote Link to comment Share on other sites More sharing options...
SR 71 Posted March 19, 2019 Share Posted March 19, 2019 Hi Dirk, super build I'm watching every move as in had a go at moulding with mixed results Love the finish on the plugs, can you tell me what sort of spray gun and nozel size you use Tony Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 19, 2019 Author Share Posted March 19, 2019 Hi Tony, it's a Standard gravity feed automotive spray gun with a 1.4 mm nozzle. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 24, 2019 Author Share Posted March 24, 2019 Flaps and ailerons framed and ready to mould.On to the wings Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted March 29, 2019 Author Share Posted March 29, 2019 One wing done... Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted April 18, 2019 Author Share Posted April 18, 2019 Hi all ! With the two wings,flaps and ailerons all framed up,waxed 7 times they are ready to mould , finally!! While waiting for the products i took the time to get the tiptank-plug also ready for primer,panel lines,paint and again framing it up and ......waxing.The same for thefuselage nose cone and tip-tank nose cone.The moulds of my PSS fouga (for these parts)are suffering from gel-coat loosening so i have to make new ones. The moulding itself will start in the Easter weekend. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted April 28, 2019 Author Share Posted April 28, 2019 Hello all ! Just started this weekend with the moulding as promissed , well i was planning to start the Easter weekend but the products were late so i did some other work first.Later about that. Let's start with something small to warm up like a flap. First thing needed is to apply the release agent PVA.It's a transparent film that helps to demould and it resolves with water.This has to prevent that the next layers stick to the plug. It 's applyed with a sponge and dry's in half an hour. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted April 28, 2019 Author Share Posted April 28, 2019 Next step is to apply moulding resin.I used to do gel-coat instead but this should be better.I had problems with gel-coat loosening from the mould. It's applyed with a brush and is colored with black pigment. It has a working time of 30 min.The next layer must be applyed within this time to adhere.For big parts like the wings that's not enough time so need to put down a cuppling layer like glass shreds(cuttings).Later about that. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted April 28, 2019 Author Share Posted April 28, 2019 Next is laying down the woven glass fabric we allknow from glassing parts , only now i use first 1layer of 50grams, 1 layer of 100 grams and 5 layers of 200 grams. Now this has to dry 24Hrs before i can take away the foam and the casting frame.Time for a drink Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted April 29, 2019 Author Share Posted April 29, 2019 Second flap done ! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted May 10, 2019 Author Share Posted May 10, 2019 Flaps and ailerons done.Couldnt resist to try and take one out !Later i'll post more pics off this Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted May 10, 2019 Author Share Posted May 10, 2019 Earlier this week i took a shot at the first wing half. As clear in the foto this mould is too complicated to make in one pièce.You could try but it would be very hard to de-mould because off the vertical sides off the wing(root).So at the ends off the wing i placed a board to work against. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted May 10, 2019 Author Share Posted May 10, 2019 Quote Link to comment Share on other sites More sharing options...
