cymaz Posted March 29, 2020 Share Posted March 29, 2020 Brian has finished the centre section. He is one of the population on a 12 week lock up... Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 29, 2020 Share Posted March 29, 2020 Cabane struts Rear skid bracket Pilot Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 6, 2020 Share Posted April 6, 2020 More done today, top wing tomorrow Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted April 6, 2020 Share Posted April 6, 2020 She's looking bigger 🙂 Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 16, 2020 Share Posted May 16, 2020 Brian is in quarantine until mid July. He continues to build the Giant Mannock, centre section is complete. Brian has done a sensational job so far Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 21, 2020 Share Posted May 21, 2020 Brian continues to work his magic Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 31, 2020 Share Posted May 31, 2020 It’s hatch time! Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 13, 2020 Share Posted June 13, 2020 More nose work done... engine cooling, baffles, entry and exits have been thought about. Edited By cymaz on 13/06/2020 11:32:03 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted June 13, 2020 Share Posted June 13, 2020 Blimey Cymaz, Brian certainly knows his stuff, he has made a beautiful job of the model so far, well done from me. You will certainly enjoy flying it, once you have taken a deep breath. 😉 D.D. Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted June 13, 2020 Share Posted June 13, 2020 You're right there Dwain, I love flying my little one but this one is something else 🙂 Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 13, 2020 Share Posted June 13, 2020 Don’t put me under any more pressure than I’m feeling already.....and it’s not finished Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted June 13, 2020 Share Posted June 13, 2020 Honestly, imagine the easiest trainer you've ever flown ... it's easier than that, especially if you add all the dihedral that mine has 🤔 Quote Link to comment Share on other sites More sharing options...
Richard Clark 2 Posted June 13, 2020 Share Posted June 13, 2020 Posted by J D 8 on 23/09/2018 11:33:34: ….....The upper wing was originaly held on by saddle clamps and 8 screws and took an age to put on,however a couple of years ago modified it with hooks holding the leading edge to the cabain and two wing bolts up through plate at the the rear. Edited By J D 8 on 23/09/2018 11:34:26 Of course. It's just another Boddington mediocrity. He turned them out like supermarket sausages. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted June 13, 2020 Share Posted June 13, 2020 Do not think Boddo did anything different to the many other kit makers of that time, just the way things were. Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 18, 2020 Share Posted June 18, 2020 And so it goes, Quote Link to comment Share on other sites More sharing options...
J D 8 Posted June 18, 2020 Share Posted June 18, 2020 Good looking rocker covers. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 6, 2020 Share Posted July 6, 2020 Brian has been working on the dashboard, the picture had a fit and span around Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted July 6, 2020 Share Posted July 6, 2020 What a splendid way of integrating a switch or two Cymaz. Impressed. D.D. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 6, 2020 Share Posted July 6, 2020 Posted by Dwain Dibley. on 06/07/2020 20:30:07: What a splendid way of integrating a switch or two Cymaz. Impressed. D.D. And the ignition light ! He’s good is Brian Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted July 6, 2020 Share Posted July 6, 2020 You're not wrong.. D.D. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 19, 2020 Share Posted July 19, 2020 Glued all the surface pin hinges in yesterday, all 20 ! Wheels are done. Next job is to secure the tail to the fuselage. This will be bolted on and Mick Reeves rigging to secure it in. More photos soon, hopefully next week Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 26, 2020 Share Posted July 26, 2020 Forgot to take a photo of completed tail with accompanying closed loops...sorry We went through the plans and build instructions but could find no mention of surface throws. Does anyone have any info about these for the Giant Mannock please ? Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted July 26, 2020 Share Posted July 26, 2020 Can't be much difference to the small one Cymaz I wouldn't have thought, plenty of rudder, bit less elevator and about the same for the ailerons, dial in some expo and all will be good. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted July 26, 2020 Share Posted July 26, 2020 I pretty much agree with Cliff, as much rudder movement as you can get [ mostly used to try and keep straight on take off ] It is the most sensitive control and may benefit from a bit of expo Having said that mine is flown with no expo on anything [ when first owned the TX used did not have it and that's the way it has stayed ] Elevator does not need 3D type throws, it is quite powerful at the end of the long fuzz. Mine has about 25 degrees max. As you will have 4 ailerons I expect a better roll rate but need lots of differential to counter adverse roll. Cheers John. Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 26, 2020 Share Posted July 26, 2020 Thanks gents, I will go with ... 15’ low , 25’ high on elevator and aileron...I generally use up to 30% expo for rudder/aileron and 40% on elevator. Does this sound about right for starters? I can do an aileron differential mix on my Tx. Quote Link to comment Share on other sites More sharing options...
