Tony Nijhuis Harvard - Build Log
Next up on the building board is the Tony Nijhuis Harvard. I am hoping it will be a quicker build than the Mosquito, which took me 2 years.
This will be built for electric power and possibly with a sound system.
I am still pondering battery position - will try and get it as far forward as possible.
Cut the parts from the laser/cnc sheets.
Then started with the fuselage.
More later...
hi geoff,
ok, i am using the 4max set up as recommended 595 kv on 4 cell lipo, 14x7 prop
i have built in to the front of the fuz a sloping tray for the lipo and a removable cockpit as well see the pictures below , the all up weight at the mo is bang on 3.5 kg and the c of g is not far out but i haven't fine tuned it yet as need to put the wing servos in so will need a bit of weight in the front yet
hope this helps
regards jez
