Christian Hollyer Posted September 27, 2018 Share Posted September 27, 2018 I've got a Kingtech K-80 turbine with the 'old-style' ECU and I'm using a Hitec Aurora 9. I've set the radio up per, and configured the ECU for diesel in accordance with the instruction manual. Problem is, as soon as I power up the ECU (with all batteries plugged in), the engine starts to spool up and looking at the peak revs during that spool up, I think the ECU is in cool-down mode (the engine has not been run so far). I live in Florida and the ambient temperature is quite high (30C at the time) and that is above the 28C cool-down threshold for the ECU. I cannot alter this value, nor can I, incidentally run the pump to prime it or test starter. The spool up only stops when I disconnect the starter battery; in other words, throttle stick and trim position make no difference. One other potential problem, perhaps, is, that while the radio appears set up on the ECU, the Hitec 9 throttle trim cannot be moved when the stick is over 50% position. I have to set the trim full up and then move the stick full up to set up the 'trim highstick high' mode; I can't do them at the same time. I wonder of that is 'confusing' the system. Any ideas? An internet search finds nothing about it and the manual is...challenging. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 27, 2018 Share Posted September 27, 2018 hello Christian,i know little about turbines but do own a Hitec A9...……….. have a look on the link I've posted...there may be some info that is helpful on there.. ken anderson...ne..1...hitec dept. Quote Link to comment Share on other sites More sharing options...
Christian Hollyer Posted September 27, 2018 Author Share Posted September 27, 2018 Thanks Ken. Looks quite comprehensive. It may answer another question about allocating the throttle trim to a left or right slider or a two-position switch. Quote Link to comment Share on other sites More sharing options...
