Tuned PipeMount
John Lucas 4
This my method of mounting a pipe/can for a 55cc petrol, I don't know if it's what you have in mind, but may give some ideas. Made from 3mm good quality ply, cut larger than the diameter of the pipe/can. The black supports are silicone tubing, and the two silvery things at the front are two cup hooks which I hook a spring inside a length of silicone tube over the front end of the pipe/can as seen in the second pic.. This makes it easier to fit or remove the pipe/can.
I used a tuned pipe back in the day, It consisted of a manifold fixed the the exhaust port, a length of heat resistant silicon tube to join it to the pipe & a terry clip fixed to the fus' to hold the pipe. That was on 40 to 60 glow engines. I remember I had a delta with an OS40 with a pipe, went like stink. The other one was a HP60 with a rear exhaust manifold, that also went like stink.
