Stuart Quinn-Harvie 1 Posted January 9, 2019 Share Posted January 9, 2019 Hi folks, I am about to start a Chilli Wind build ( I still have my free plan! ) and I am keen to do a built up wing. I am FAIRLY sure I could knock one up well, but I believe that you can never have too much knowledge or other people's experience :D I would be really interested to hear/see how anyone else has made one - how many ribs, material sizes used and so on. Thanks for any information anyone might be able to provide Quote Link to comment Share on other sites More sharing options...
Nigel R Posted January 9, 2019 Share Posted January 9, 2019 Mine is...10 ribs. Equally spaced. All 3/32. 1/4 square hard balsa spars. 1/16 webbing. 1/4 leading edge and trailing edge. 1/8 false leading edge and false trailing edge. Fully sheeted with 1/16.Solid ailerons as per plan. Joined with medical bandage and pva. Has survived a crash that totaled the fuselage!Hope that helps. Quote Link to comment Share on other sites More sharing options...
Stuart Quinn-Harvie 1 Posted January 9, 2019 Author Share Posted January 9, 2019 Thank you Nigel! That sounds lovely and simple. Two spars - one top one bottom and ten ribs per panel? I particularly like your joining method: I have always been very paranoid about wing joins and gone for epoxy and glass - I will try that. How did you cover it? Iron on or nylon? Gutted to hear of your crash, BTW Cheers again! Quote Link to comment Share on other sites More sharing options...
Stuart Quinn-Harvie 1 Posted January 9, 2019 Author Share Posted January 9, 2019 BTW, I am just going through your thread on the SCEN Puma - superb work Sir!! Quote Link to comment Share on other sites More sharing options...
Nigel R Posted January 10, 2019 Share Posted January 10, 2019 Thanks Stuart The Chilli was all my dad's work (as was the crash!). He liked it enough to make another fuselage, but then didn't fly it much and it's come my way since then. The usual glass/epoxy wing joining kit is somewhat overkill. I've never had issue with PVA and bandage, although these days I use PVA and glass tissue. One wide layer and one narrower layer, on a Chilli size build that would be around 12" and 6". It's covered in Solarfilm, no extra strength needed with a fully sheeted job. Must get the Puma out of semi-retirement and back in the air. Quote Link to comment Share on other sites More sharing options...
MikeQ Posted January 10, 2019 Share Posted January 10, 2019 Hi cant remember is it the smaller of the two ... Chilli Wind and ChilliBrezeze.. I've had two of the smaller ones with built up wings and they were superb flyers. I think I might have a copy of the original article for the bigger one. Cheers Mike Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted January 10, 2019 Share Posted January 10, 2019 Both versions are cracking models. Chilli Wind is the bigger of the two. My Breeze had built up wings while the Wind had foam core jobs. Edited By Adrian Smith 1 on 10/01/2019 15:59:35 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted January 10, 2019 Share Posted January 10, 2019 Chilli Wind plan and article are on outerzone: **LINK** The smaller one (Breeze) already had a built up wing shown on the plan. And, yes, 10 per panel (so 9 bays), and 1/4 sq hard balsa spar top and bottom at the thickest point of the rib. Quote Link to comment Share on other sites More sharing options...
Stuart Quinn-Harvie 1 Posted January 10, 2019 Author Share Posted January 10, 2019 Thanks everyone. Anyone know what issue the smaller one was in? Thanks again Nigel - again, nice and simple. Quote Link to comment Share on other sites More sharing options...
kc Posted January 10, 2019 Share Posted January 10, 2019 Chilli Breeze ( the smaller one ) was in RCME June 1994. A copy for sale here Note that if you have a free plan ( i.e. pull out plan from the magazine) it's the small one. The larger Chilli Wind was a plan to be purchased, not a pull out plan. Quote Link to comment Share on other sites More sharing options...
Stuart Quinn-Harvie 1 Posted January 10, 2019 Author Share Posted January 10, 2019 Cheers KC. I will have to check to see what I actually have - I seem to be a bit confused... about time for the dried frog pills, I think. Quote Link to comment Share on other sites More sharing options...
kc Posted January 10, 2019 Share Posted January 10, 2019 I seem to remember there was some confusion of the two sizes in an earlier thread and info was given incorrectly. If the build is of Chilli Breeze then build as per plan, but if the larger one consider spruce spars with a ply joiner and forget about bandages or fibreglass. Quote Link to comment Share on other sites More sharing options...
Stuart Quinn-Harvie 1 Posted January 10, 2019 Author Share Posted January 10, 2019 Hmm, I have the plan for the big one ( wind) I have no idea where it came from, I just assumed it was the free one: It must have come from a load of stuff I bought a few years ago. Quote Link to comment Share on other sites More sharing options...
kc Posted January 10, 2019 Share Posted January 10, 2019 Well you could construct a built up wing in the same way as many aerobatic models of the same size. Or you could still get a foam wing cut by suppliers such as Bill Kits. Also a foam tailplane. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted January 11, 2019 Share Posted January 11, 2019 Posted by kc on 10/01/2019 19:43:09: If the build is of Chilli Breeze then build as per plan, but if the larger one consider spruce spars with a ply joiner and forget about bandages or fibreglass. The spars are not "in line", they sweep back, so a ply joiner would not be as simple. The Breeze structure is regular D Box with full sheeted centre section - so plenty of material for a glass or bandage joint to work on. Worth noting glass joins have a secondary bonus of reinforcing the surface around the point where the wing dowel and bolt are. The structure I listed is as per my larger Chilli Wind. Spruce 1/8" x 1/4" would be a good spar, as an alternative to rock hard balsa of 1/4" x 1/4". For what its worth, if I'd built it I would have used a liteply root rib, slotted at the front, to take the wing dowel. Many ways to skin the cat! Quote Link to comment Share on other sites More sharing options...
kc Posted January 11, 2019 Share Posted January 11, 2019 Well 3/16 sq spruce would be better than 1/8 by 1/4 because of greater gluing area for the webbing and the ply joiner. Actually I would prefer 1/4 sq spruce on an aerobatic model, save weight on other things not the spars. Getting really hard balsa for spars is not easy and spruce is not much heavier. If the spars are not in line then tapered infill pieces would be used to glue a straight ply joiner onto the spars. Or relocate the spars to be in line. I note that the instructions for the Chilli Wind suggest that it could use a flat 1/4 balsa tailplane instead of foam. Much easier! Quote Link to comment Share on other sites More sharing options...
alex nicol Posted January 11, 2019 Share Posted January 11, 2019 Hi Stuart, I currently have a chilli wind under construction, with a built up wing & also incorporated a set of electric retracts. Unfortunately its fully constructed so not much to see.. I used a full depth spar made of very hard 1/8th balsa Half slotted the spar & ribs & capped it off with 1/8th x 3/8 to form girder type section. I also added a 1/8 x 1/4 spars towards the TE. then built the whole wing & cut the ailerons out. I also decided to opt for a built up tail as opposed to the 1/4 sheet version I'll stick some pics up shortly Cheers Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted January 11, 2019 Share Posted January 11, 2019 I bought the Chilli Wind plan from Sarik (1648) and the MAY 91 RCM&E magazine build article from the internet. I will do a built up wing sometime, probably using 1/4in spruce and I am considering a laminated ply joiner. The model looks fast just standing still but is not at the top of my build list at present. Peter Miller's Little Miss Honky Tonk should be out in the next few days so that could be next. I will be following your Chilli Wind build with interest Stuart, if you are planning to do a build blog. Quote Link to comment Share on other sites More sharing options...
alex nicol Posted January 11, 2019 Share Posted January 11, 2019 Forgive the photography, pics of my build below Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted January 11, 2019 Share Posted January 11, 2019 Very Nice Alex, which retracts are you using? Quote Link to comment Share on other sites More sharing options...
alex nicol Posted January 11, 2019 Share Posted January 11, 2019 From memory they're Turngy from HK........they weren't that expensive Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted January 11, 2019 Share Posted January 11, 2019 Nice job Alex. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 12, 2019 Share Posted January 12, 2019 That looks great. Its a superb introductory model for Classic Aerobatics. Kept light, it would be fine with an SC46 or similar without a pipe although the SC46 does take a pipe very well. Martyn Quote Link to comment Share on other sites More sharing options...
Nigel R Posted January 12, 2019 Share Posted January 12, 2019 It does look good. I'd say it is one the best thought through designs I've seen. Flight performance is as good as any classic aerobat from the 90s. The airframe structure has also been carefully thought out to minimise build time, complexity and cost. No expensive glass bits needed, no difficult fairings to hide pipes, no canopy section to deal with, etc. Shaping work is kept to a minimum. All in, it was a brilliant package. I've still got a piped 60 size one on my bucket list of projects. Edited By Nigel R on 12/01/2019 13:09:13 Quote Link to comment Share on other sites More sharing options...
kc Posted January 12, 2019 Share Posted January 12, 2019 The 57 inch Chilli Wind wing that I have is foam and veneer weighing 1.2 pounds complete after tissue dope, paint and fuel proofer. So don't discount a foam wing on weight grounds. Quote Link to comment Share on other sites More sharing options...
