Winco Steve Posted July 19, 2019 Share Posted July 19, 2019 Hi all, Just finished the above kit ( Seagull PT -19 Fairchild ) and about to check it all over and set the C of G. However, the instructions state ‘ the centre of gravity is located 6.5 to 7.5 cm back from the leading edge of the wing measure at the wing tip’. Not sure why the inclusion of ‘wing tip’? Back from leading edge, sure, but wing tip? Any directions would be most appreciated as Sunday looms and club day for maiden flight! cheers all, Winco Steve Edited By Winco Steve on 19/07/2019 14:33:16 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 19, 2019 Share Posted July 19, 2019 That's not uncommon with Seagull. Run a piece of string from tip to tip and (easier if the fuselage top section is removable like my Yak?) to establish the datum and mark the C of G on the place where you'll balance it (normally upside down on a low winger) and dig out your C of G rig (or Mk 1 fingertips) to check. A piece of masking tape should protect the finish if you are using the wings as the measuring point. I suspect that you might be able to connect the wings together off the model with the joining tube to use the string "trick" more easily. If in any doubt, remember the old adage - a model with a too forward C of G flies badly but with a too rearward one flies once! It's often worth a Google for owners' experiences with recommended C of G positions which have been known to be specified incorrectly! Edited By Martin Harris on 19/07/2019 15:18:57 Quote Link to comment Share on other sites More sharing options...
Winco Steve Posted July 19, 2019 Author Share Posted July 19, 2019 Hi Martin, Thanks for reply. The wing sections are permanently joined by way of support rod (epoxy) . So, a line across the wing top surface from wing tip to wing tip. Line 6.5 to 7.5 cm in from leading edge? Have I got that right? Fix back on plane, upside down on C of G machine? Presumably, the balance points can be anywhere, equidistant, along that line? Using a Great Planes C of G machine as fingers fat and wobbly! Never do I miss this part out, too many early days mishaps. Cheers, Winco Steve Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 19, 2019 Share Posted July 19, 2019 These are very lightly built Steve Very stable in flight Suitable as a 1st low wing trainer And lovely colours I put Hobbyking Oleo Legs on mine to look the business Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 19, 2019 Share Posted July 19, 2019 I haven't any experience of your model but with my Seagull Yak, I used string to establish the wingtip position on the fuselage and measured the specified C of G position back from there. It worked fine for me on that model - which incidentally needed tail weight to balance the rather larger than specified engine. Bottom line, failing any response from someone with direct experience of the model is to err on the side of caution. One simple precaution might be to input the planform data to an online calculator (example) and see how closely it aligns with the method I've advocated. Edit: I see Denis has had one - any advice on the measurement method and behaviour at the specified setting? Edited By Martin Harris on 19/07/2019 16:37:24 Quote Link to comment Share on other sites More sharing options...
Winco Steve Posted July 19, 2019 Author Share Posted July 19, 2019 Hi both, Martin, thanks for that link it looks very interesting and will assist me I’m sure. I’ve given up for today as it’s 34 degrees and I’m starting to melt! Club day Sunday so hopefully will have it sorted. I will get back on this thread with results. Yes , Denis, a very light model but it does look pretty! I got it to add to my collection for something to sling in the van and get a bit of fun flying again. My other models seem to take an age to set up! I have another Seagull, the At Texan. That looks super too. Best wishes, Winco Steve. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 19, 2019 Share Posted July 19, 2019 Just seen Martin's C of G query this model has to be said, is very forgiving And like most Seagull models, if you install all the heavy bits in their cut outs, then the C of G is not far away With this one, the C of G was set 7cm from the tip LE, using 2 lads with a finger under each wing tip But to add, the PT19 is very like a small Astro Hog, and flys as such, and is very stable Edited By Denis Watkins on 19/07/2019 18:06:03 Quote Link to comment Share on other sites More sharing options...
Winco Steve Posted July 20, 2019 Author Share Posted July 20, 2019 Hi again, Hopefully Martin or Denis is about? Or anyone else who has a PT19 Seagull. Tried recommendations but way out. One way very nose heavy the other very tail heavy. Can someone give me the exact way Seagull are instructing you to locate the C of G? Leading edge at root is normal but where/ why /how at wing tip? I might just be getting thick in my old age or possibly suffering from sun stroke but non of this adds up. Using the C of G machine the balance, at wing root end , just out from fuselage, is about 90 cm?? yours, confused, Winco Steve Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 20, 2019 Share Posted July 20, 2019 9cm at the Leading edge, Yes Steve Goes through the Leading pilots head I measured The wing, as you know is tapered, so as advised, ran a string from one tip to the other At the field, without being inverted, one lad at each wing top lifts the model with a finger under the 6 -7 Mark That did for me and flys beautifully Quote Link to comment Share on other sites More sharing options...
Winco Steve Posted July 20, 2019 Author Share Posted July 20, 2019 Hi Denis, Thanks for your reply. I will have another go to see if I can sort it. Regards, Winco Steve Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 20, 2019 Share Posted July 20, 2019 Sorry - out flying this afternoon but Denis had the best info... Quote Link to comment Share on other sites More sharing options...
Winco Steve Posted July 21, 2019 Author Share Posted July 21, 2019 Hi all, Last update! Measured 7 cm in from leading edge at wing tip just before it curves. Piece of wooden batten to join dots each end. That gave C of G about 9cm just outside of wing root/ fuselage. Placed machine points here and nose dipped a little too much. Added some weight ( 20 gm I think, small weights used for balancing cycle wheels ) to tail and just dipping nose down. That’ll do for me. Will give it a try Wednesday! TTFN Winco Steve Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 21, 2019 Share Posted July 21, 2019 Quote Link to comment Share on other sites More sharing options...
Winco Steve Posted July 26, 2019 Author Share Posted July 26, 2019 Hi all, Just an update. Whilst conversing on this forum I also sent an email to Seagull . They responded quite promptly and confirmed the measuring technique/ position that was suggested and employed. See my previous reply. They also sent a diagram of how to measure C of G which they stated that they will include in future construction instructions. Unfortunately, I am unable to download this as it is a pdf. I tried, several times, with photos etc but no joy. Anyway, test flight didn’t go well as model kept going nose down during taxi. Problem, weeds and stones on grass runway. Solution, I hope, much larger wheels? Retry Sunday! Regards to all, Winco Steve. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 26, 2019 Share Posted July 26, 2019 Progress Steve, At least some progress This site works on jpegs So I screenshot the pdf to my gallery as a jpeg, then post, I overdo freeing off wheels on axles, for the reason you state Most of mine are tube brass bearings on the piano wire Or more recently using Dubro Low Bounce wheels are a tight fit on standard size diameter piano wire So, said wire is taken down with wet and dry paper and polished, until the Dubro wheels run free Laborious, by there are only two wheels Edited By Denis Watkins on 26/07/2019 07:55:30 Quote Link to comment Share on other sites More sharing options...
Winco Steve Posted July 26, 2019 Author Share Posted July 26, 2019 Good morning Denis, I did try the photo trick to convert from pdf to jpeg but this failed also. I attempted this first on IPad then on my Mac computer. No joy, just would not upload. Gave all the right signals it would work, but when upload button pressed, failed to appear in album. Even started all over with deleting all, open new album and try again. Nothing. Better spending the time on my models! Ha Ha! Guys with front wheel tricycle undercarriage don’t suffer quite the same as the ‘tail draggers’. They seem to bounce along easier and, of course, have the nose support. Replaced the PT 19 wheels with a set from an old Wots Wot. They should be up to it. All the best, Winco Steve Quote Link to comment Share on other sites More sharing options...
aidan mcatamney Posted November 30, 2021 Share Posted November 30, 2021 On 26/07/2019 at 09:05, Winco Steve said: Good morning Denis, I did try the photo trick to convert from pdf to jpeg but this failed also. I attempted this first on IPad then on my Mac computer. No joy, just would not upload. Gave all the right signals it would work, but when upload button pressed, failed to appear in album. Even started all over with deleting all, open new album and try again. Nothing. Better spending the time on my models! Ha Ha! Guys with front wheel tricycle undercarriage don’t suffer quite the same as the ‘tail draggers’. They seem to bounce along easier and, of course, have the nose support. Replaced the PT 19 wheels with a set from an old Wots Wot. They should be up to it. All the best, Winco Steve Hi there, I am thinking of buying this plane, would you recommend it? Quote Link to comment Share on other sites More sharing options...
aidan mcatamney Posted November 30, 2021 Share Posted November 30, 2021 On 26/07/2019 at 08:54, Denis Watkins said: Progress Steve, At least some progress This site works on jpegs So I screenshot the pdf to my gallery as a jpeg, then post, I overdo freeing off wheels on axles, for the reason you state Most of mine are tube brass bearings on the piano wire Or more recently using Dubro Low Bounce wheels are a tight fit on standard size diameter piano wire So, said wire is taken down with wet and dry paper and polished, until the Dubro wheels run free Laborious, by there are only two wheels Edited By Denis Watkins on 26/07/2019 07:55:30 Hi there would this plane fly well with a 62 fourstroke? Does it have a low stall speed in turns? I was thinking of either buying this plane or a Boomerang trainer arf. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 30, 2021 Share Posted November 30, 2021 (edited) We have 3 of these at the field now, and all fly well, 1 .46 2 stroke, 1 .52 2 stroke, and 1 .52 4 stroke. Have flown all 3, all well behaved, and the .62 would be ideal. This model is very lightly built, but always keep moving no matter which model in the turn. Get used to using throttle into the turn, in readiness for your future warbird, and even now, touch the rudder too, to keep the wing flatter in your turns. Much to think about, but practice rudder down On the ground when it is quiet.I Also in the air, at good height, practice rudder/ elevator flying, without touching the ailerons, as this model will forgive you, and fly. Edited November 30, 2021 by Denis Watkins Quote Link to comment Share on other sites More sharing options...
aidan mcatamney Posted December 1, 2021 Share Posted December 1, 2021 9 hours ago, Denis Watkins said: We have 3 of these at the field now, and all fly well, 1 .46 2 stroke, 1 .52 2 stroke, and 1 .52 4 stroke. Have flown all 3, all well behaved, and the .62 would be ideal. This model is very lightly built, but always keep moving no matter which model in the turn. Get used to using throttle into the turn, in readiness for your future warbird, and even now, touch the rudder too, to keep the wing flatter in your turns. Much to think about, but practice rudder down On the ground when it is quiet.I Also in the air, at good height, practice rudder/ elevator flying, without touching the ailerons, as this model will forgive you, and fly. Thanks Dennis. ? Quote Link to comment Share on other sites More sharing options...
