Cheap Chinese Laser Cutter
ROBERT BURLACE
I recently bought an "eleksmaker" 2.5W laser engraver from bangood, partly for my wife to use for her wedding and personalised gifts business, but partly out of curiosity for model building.
The laser comes as a kit and parts are readily available to expand as necessary. I have built mine to accommodate standard sheets of balsa and 300x900mm sheets of ply from SLEC.
I have carried out a few tests so far and it has proved capable of cutting up to 4mm birch ply without too much fuss (although slowly), poplar, liteply and balsa with ease.
Now - I am USELESS with a scroll saw. The other day, I used the laser to cut out some fuselage formers for a Cap232 that I am building and the accuracy and speed that i came out with them was far, FAR better than i can achieve by hand. Using the laser has the advantage of no balsa dust and as well as ventilation is good, no fumes.
The full set up has cost me less than 250 quid and I have already cut parts for two sets of plans for winter build projects, so has probably paid for itself already.
I don't plan to design my own models, there are plenty of good CAD drawings around online to keep my busy for a while.
I will post some pictures and updates as they happen for anyone who is interested.
A balsa rib - cut before I installed the air assist which really helps clean up cut edges.58871355182__91ee32f2-7914-4564-8d50-524d9da617a9.jpg
Air assist - fed by a small pond air pump
Clean cut in some sample bits of 4mm ply - leaves a bit of a burnt edge but sands off easily enough and have had as bad on short kits purchased online before now.
And this is the setup - the bare aluminium rails are stock from the kit, i extended the cutting area using the black ones to 1100mm- giving a workable cutting area of about 400mm x 1000mm
In terms of preparing plans
I am currently working between two bits of software - although not a perfect solution, it seems to work.
The first is Inkscape - a free bit of relatively advanced CAD software which allows you to import your parts from a DXF (or other CAD file) and arrange parts onto sheets. I create a document the same size as a sheet of balsa, or ply that I am cutting on to, import parts, then arrange onto the sheet, making sure that they are oriented correctly for grain directions and as economically onto sheet as possible. Saving these files as .svg files allows the next piece of software to do its job...
The second piece of software, Lightburn isn't free, but think it costs about 40 quid - I am still on the one month free trial and exploiting a bug that stops it counting down if you don't close it ( I will buy one day but i like to test stuff thoroughly before committing). This software controls the speed and power of the laser cut and creates a g-code which is the instructions for the controller to give x,y coordinates to the stepper motors that move the laser.
Hi Robert.
I too have a nice size laser cutter, which is extremely useful.
However I must point out that it is imperative that you have good ventilation whilst using it. You are better using it in the shed than the house !
You may not think that there are fumes, but there are. Particularly when cutting any ply, which can be very nasty. This is why commercial cutters are fully enclosed with extraction units.
There is a free software program called Wintopo, which you might find useful. It converts drawings (jpg) into vector files (Dxf). It is very good if you struggle with CAD.
Hi Kevin,
Thanks for the tip on Wintopo - I had seen a piece of software called scan2cad which seems to do a very nice job, but it isn't cheap. I will give it a go. As I said at the top of the thread - there is already lots of very good cad drawings around, but the ability to convert jpg opens up even more possibilities - does it work with pdf too?
Yes, my post was a little inaccurate about the fumes - I should add that when cutting, I set the cutter up, set off on its way and leave the shed while it does its thing. I will build an enclosure that has extraction capabilities when I get chance to, allowing me to work while parts are cutting.
Thanks
Rob
Thanks for sharing James.
it looks like you use yours for exactly what I intend mine for.
I tried the Bencut software but just found that I got on better with the other two bits of software.
There is is an option to add z-axis now for cutting thicker materials- it would allow the focal point to move down between passes. It should make cleaner cuts on ply especially.
Posted by MAD Dave on 22/09/2019 19:22:10:
Is there any clue to the life of the laser?
How long is a piece of string.
Sorry Dave, but there are so many variables you can't get accurate figures. Let's just say if you are using it for hobby purposes, "a long time".
Robert, as far as i can gather Wintopo like jpegs. Acrobat files are easy to convert, but be careful. You may find that some files come out at a different size when printed / cut.
Another tip is to keep old cardboard boxes for practicing with. They are a lot cheaper than balsa ! Once you have cut a cardboard set, you can check against the plan before cutting wood. that way. rather than get "near enough" you can produce really accurate pieces that you can later duplicate, if necessary.
I can't comment on the life of the laser, but hopefully if I manage to keep the thread going, it will give you a good idea. I follow a group of users on facebook who give them pretty heavy use, some even in small businesses. They will, inevitably burn out I am sure. But all cutting tools go blunt... They are relatively inexpensive to replace like for like and the kit can be upgraded to more powerful diode lasers and have even seen CO_2 lasers used.
Nice tip with the card - it would allow a mock up before committing to wood. I am always careful to measure cad drawings against plans before cutting....its the same as making any cut...measure twice....you know the rest.
I have a big order of wood from SLEC due tomorrow, so plan to get going with a lovely mk9 spitfire I have been wanting to build for a while now, but didn't have the patience to cut the parts!
Will keep you updated.
Rob
Hi Robert
I just wanted to say thank you to you for starting this thread. It is very interesting to see see your results using simple and low-cost equipment.
I have always hand-cut parts for my models, but I have had a CNC vinyl cutter that I use to make paint masks for over 10 years now, so perhaps laser cutting could be my next move.
I hope you do update this thread with future progress!
We used to use lasers as part of various measurement techniques at work (I've been retired nearly 25 years now). I was never very directly involved but several people in our department were and we had a Laser Lab where experiments and designs were tested. This was simply a partitioned room with no windows and a door lockable from the inside. The reason was to prevent anyone entering without eye protection when lasers were being operated. Lasers can cause serious (and permanent) eye injuries.
I just wonder how safe laser cutters are. At work, anyone dealing with lasers was required to have an eye test before they worked with them. This was to protect the company from claims that any eye problems were caused at work rather than for the benefit of engineers. Anyone operating a laser wore special goggles.
A laser cutter is an appealing idea but what measures do the suppliers suggest should be taken by users - particularly as regards eye protection?
Geoff
Posted by Geoff Sleath on 25/09/2019 16:22:08:
Geoff
Geoff,
the way way I see it, we have a hobby where we have spinning blades, carry highly volatile fuels in our cars and charge batteries containing lithium in our homes. Done safely, although they pose a hazard, the risk is minimal. The same applies to any form of cutting, including lasers. The kits I have did come with eye protection- I upgraded and bought a pair that I was sure we’re rated for the wavelength of the laser.
MrsB isn’t allowed in the shed, so someone walking in on it won’t be an issue. Setting up a simple set of procedures can manage that risk to a level where it is acceptable, as was done in your workplace.
I wouldn’t let the risk put you off- it can be managed quite easily.
Rob
Posted by Alan Gorham_ on 25/09/2019 15:25:44:
Hi Robert
Thanks Alan,
i looked around and couldn’t find a similar thread, so thought I would set one up. I’ll keep updating as I go!
Posted by ROBERT BURLACE on 25/09/2019 18:02:33:
Geoff
Geoff,
Rob
The difference is that we can see spinning drills, band saw blades and potentially spinning props but laser beams are not so obvious and the potential damage very serious and permanent. At least they appreciate the the risk and supply appropriate eye wear.
Geoff
I agree, but people still get stung by those things is when they don’t follow a set of safety rules. A friend of mine lost a finger using a table saw- it just so happened to be the one time he didn’t have the guard in place.
Same with a laser.
The beam points straight down so you can’t accidentally look down it’s length, having a non-reflective cutting bed cuts out the risk of reflection too. But I still wear safety glasses at all times! Even on low power!
An enclosure with extraction is a good idea and I will definitely be adding it soon.
Im just preparing some cut files for those who are interested. I will post some pictures later on.
The first image shows the plan on Inkscape. A useful bit of free software for dealing with cad plans. Here you can make simple changes very easily. I use the ruler tool a lot to check measurements against the plan which I have already had printed at 100%
The templates have already been nicely laid out, but not for the 300x900 ply I have.
I create a new document with the dimensions of the material and copy and paste plans into it - check orientation to grain and ruler tool to double check dimensions.
Below is Lightburn, which I use to control the laser. You can see my 300 x 900 material sheet and the outer black line is the bed of the cutter in plan view.
The controls on the right manage the power and cutting speed.
The laser is meant to be an engraver so it spends most of its time at 100%. I found the following cut settings work nicely so far:
poplar ply at 5mm/sec 1 pass per mm of material
birch ply at 2mm/sec 1 pass per mm of material
Balsa (medium) 10mm/sec 1 pass per mm of material.
This might seem slow, but look at the cutouts on the plan and consider the time taken to do them by hand or on the bandsaw/scrollsaw
I will set this sheet off tomorrow after work but I estimate about an hour for all fuselage formers in poplar.
I built a laser engraver from http://3dpburner.blogspot.com/p/main.html It is principally 3d printed with cheap threaded bar and ground steel bar frame/axes. I built mine to accept an A4 sheet, but you could easily modify the sizes to whatever you want (within reason). It will accept a z axis which I would recommend. I have a 5500mW fitted to it which will cut balsa and 3mm ply with ease (several passes needed but that is what cnc supplies with accuracy and ease) It is another nice toy to have in the toolbox!
I use Vetric Aspire for creating the cnc layout and files, this is really cnc router software but I just select the cutting a tool with a diameter of 0.1mm - close enough for me and I had the software already for my cnc router.
There are plenty of good free cnc file sending tools available now - I use either ugsplatform64 or OpenCNCPilot...
Eye protection AT ALL TIMES is essential (accidental reflections could be serious) and forced ventilation will help in not stinking the house out!
