Chris McG F-86 Sabre Dog build blog
Hija Dirk,
I just meant that the full size received a 16mm camera after its restoration in Chièvres. surprise
But on a relatively small model, you'd better use a light cam fixed on the wings close to the fuse or even better at the wingtips.
... and no, I'm not lazy at all... still very busy with the cockpit area details and 'your' canopy. cool
Cheers & stay safe all
Chris
Thank you for your kind words, Ade.
Partly due to that detailing, my progress is even slower at the moment.
But anyway, there's no reason to have a 'rush' at the moment, is there?
How are your builds progressing? Any updates concerning your canopy 'plug'?.
Chris
Posted by McG 6969 on 03/04/2020 12:12:46:
Chris
Canopy plugs under construction. Will post some progress pictures in due course. Just been spending time with the airbrakes hinge and actuation. Again, pictures of that pending.
Ade
Hi again,
Not an enormous progress, but for me some kind of a milestone anyway.
I had the definitive shape of the canopy adjusted to the Dogs fuselage with just a bit of sanding of the acetate at the back.
The front part was OK and I only needed to refine the transition to the front balsa triangles.
A bit of shaping and a smear of lightweight filler where needed.
As you might have noticed, Maj. Yvan Deprins started to get ‘mutilated’ a bit as well. More about him later on… angel
For those interested, when I have to use lightweight filler - mine is Red Devil Onetime - I always mix it with PVA diluted at 20 - 25 % as it sticks a lot better to balsa or ply and sanding remains a doddle. yes
Hakuna matata but keep safe
Chris
BRU - BE / CTR PVA Control
Hi Chris, I am very impressed with what you are doing Matey.
I have been off the scene for a while, had a seizure due to stress at work, but ok now, I could not drive for six months, so all activity was on hold, back in my van now and thinking of what I can build with the balsa stock I have as there is nowhere to buy wood except online.
Anyway, well done again so far. Keep up the Excellent work Dood.......thumbs upsmile d
D.D.
Hi Dwain,
Some time ago, I had wondered why you seemed 'vanished' from the forum threads.
So glad to see that you are back now and that everything is OK again. yes
If you fancy building a WW1 type monoplane, have a look at my Vicomte 1916 blog. No intricate parts, only one type of ribs and 1/4" sticks fuselage. An easy but rewarding build with not a lot of balsa required. smiley.
I'll get my Vicky back on the bench as soon as I finish the Dog.
Thanks for stopping by, young man.
Cheers & keep safe now.
Chris
Not sure if someone is wanting me to 'die', Dirk. surprise
I presume the word 'dood', that Dwain used, has no relation with the Flemish/Dutch 'dood' meaning 'death', but is just some (British?) urban adaptation of the American 'dude'... wink
Well, I don't know if Yvan is contaminated already, but for sure he had some major surgery recently...
Chris
Hello to all,
The ‘small bits’ duty goes on in La Grotte.
The main operation was a major surgery for Yvan, the driver.
As he came very cheap from Freewing, some details could/should be corrected. frown
He was looking straight in front of him. Full size pilots are continuously ‘scanning’ the sky from left to right - or the other way around if you prefer - even with slow Ultralight machines. First thing was decapitating him (gently) and twist his head for a few degrees. A lot more ‘natural’. cool
His oxygen tube was squeezed into his chest so was removed as well. Same with his sea life vest which is never used for demo flights by the BAF. Thanks Mr Dremel… yes
I made a new oxygen tube with a length of mains wire ‘spiraled’ with some thin board wire and held in place with a lick of epoxy and some heat shrink tubing.
For Yvan’s safety belt, I prepared some strips of artist canvas. They are too wide so far but the wave of the canvas is a perfect scale imitation for the belts.
Hakuna matata
Chris
BRU - BE / CTR Oxygen Control
Hello again,
‘Small bits duty’ part #2.
I started to concentrate on the cockpit furniture and had to have a careful introspective journey into my SHD - aka the Specialty Hoarding Drawers. cool
From left to right >
- the ‘backplate’ (styrene) behind the seat with the spare oxygen bottle (beech dowel) and the radio console (ABS & styrene bits)
- some wiring and connections (mains mono-strand)
- fixations (styrene tubing) for the different parts
- the ADF beacon/antenna (led) & its support (balsa & styrene)
- the camera mount (styrene) for the front console
All together, it took the same time to prepare those bits as building half a Dog wing… ppfff frown
Hakuna matata, but keep safe, gents
Chris
BRU - BE / CTR Furniture Control
Hi Phil and thanks for your posts.
Yep, I’m trying to give the cockpit a bit of ‘furniture’. angel
I have a few cockpit photos from various angles and I’m trying not to give too much credit to ‘drawings’.
The main problem I have is that there are not too much usable pics for the Dog. A lot less info than for the ‘normal’ F-86.
They are totally different animals in a lot of areas, including the cockpit. For example, the canopy ‘silhouette’ looks the same but the canopy ‘frame’ is totally different. Also, the F-86 canopy is sliding backwards where the Dog’s canopy is tilting upwards. Probably one of the reasons the frame is very different from the one to the other.
To make it even ‘funnier’, there are numerous differences between the Dog versions. They all seem to have the same ejection seat - different to the F-86 – except that some versions, like my ‘K’-version, can eject through the canopy in case of malfunction.
While trying to ‘sculpt’ Yvan’s seat belt buckles (5 by 3mm) today, I thought I have to stop somewhere… as I still have that second half wing to start building… frown
Cheers & just keep safe
Chris
Hi there,
Well still quite busy with those cockpit small bits.
With a lot of different paint layers to get dry resulting in a very slow process, I made a start with the canopy frame.
The fiberglass was first sanded back - using car shop Scotch Brite - on both sides as it’s a lot easier to do when still ‘complete’. smiley
It then received two layers of build up filler on the outside to stop the part being still ‘translucent’.
Time to find the ‘bisectrix’ (?) with the assistance of small parcel binders able to follow a convex curve very easily.
The only thing to remember is to trace the line on the correct side of the guide… angel
Hakuna matata, but keep it safe yes
Chris
BRU - BE / CTR Right Side Control
