Geoff Gardiner Posted November 3, 2019 Share Posted November 3, 2019 OK, so here we go with another build log! I wanted something that would be suitable to take a 'B' test with and also something that would be a good first model to build using my Home-made laser / CNC cutter. My first thought was The Ohmen, but decided on the Oodalally as it is a bit larger. Also, I have some 4s batteries that need a good home. Having obtained a PDF version of the plan, the first job was to trace out all the parts that I would be laser cutting. For this I used a program called InkScape. Each part was created on a separate layer, this makes it easier when you create the cutting files later. Next, I created a new document in InkScape and set the page size to a sheet of balsa. Then I copy all the parts that will be the same thickness and lay them out on the page. I then produce a cutting path and using the J Tech Photonics laser tool (a 3rd party extension that I installed into InkScape), I produce the g-code file. More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 3, 2019 Author Share Posted November 3, 2019 The g-code file is the loaded into a program calles CNCjs which controls the laser cutter. And the job is set going. And in next to no time we have this... More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 4, 2019 Author Share Posted November 4, 2019 Cut the fuselage sides and glued on the ply doublers today. Also made a start on the wings. More later... Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 4, 2019 Share Posted November 4, 2019 Looking good. That laser cutter sopunds a great time saver. Quote Link to comment Share on other sites More sharing options...
christophe dauvergne Posted November 5, 2019 Share Posted November 5, 2019 Hi do you have a file of manufacture of your laser machine that interests me strongly the section mechanical and electronic regards christophe Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 5, 2019 Author Share Posted November 5, 2019 Hi Christophe. I built the machine myself, printing parts for it with my 3d printer. See here for details. It also will hold a dremel for milling jobs - ideal for cutting thicker ply. The laser unit is a 5W diode laser from BangGood. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 5, 2019 Author Share Posted November 5, 2019 Bit more done on the wing today: More later... Quote Link to comment Share on other sites More sharing options...
Chris North 3 Posted November 6, 2019 Share Posted November 6, 2019 Looking good Geoff. I love the idea of a laser but just not sure I would get much value out of it given the amount if building I'm doing. Following your build Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 6, 2019 Author Share Posted November 6, 2019 Thanks Chris. I wondered that myself, which is why I built my own laser. Even if I don't use it much, I have had a lot of fun building it and getting it to work. Quote Link to comment Share on other sites More sharing options...
kc Posted November 6, 2019 Share Posted November 6, 2019 For those who don't want to spend time and money making and sorting their own laser cutter you can of course buy laser cut parts from Sarik! Edited By kc on 06/11/2019 11:26:17 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 6, 2019 Share Posted November 6, 2019 Or you can sit there with a power fret saw and a scalpel and cut your own out. Quote Link to comment Share on other sites More sharing options...
Torsten Spitzner Posted November 6, 2019 Share Posted November 6, 2019 Posted by Peter Miller on 06/11/2019 11:38:11: Or you can sit there with a power fret saw and a scalpel and cut your own out. And that we call 'scratch building'... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 6, 2019 Author Share Posted November 6, 2019 Very true KC, but where's the fun in that Quote Link to comment Share on other sites More sharing options...
Steven S Posted November 6, 2019 Share Posted November 6, 2019 I'm just finishing up scratch building a set of ribs for my Lil' Cub, just some holes to cut. It took most of the afternoon to cut 26 ribs so far, but I enjoy the time spent at little jobs like this. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 7, 2019 Author Share Posted November 7, 2019 Bit more on the wings: Sheer webbing going on Leading edge. The rest of the wing sheeting. Second half of the wing under construction. Sheer web going on the second wing half and L.E. cap strip going on the first wing half. More later... Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 7, 2019 Share Posted November 7, 2019 Looking good! Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 7, 2019 Author Share Posted November 7, 2019 Thanks Peter, so far so good. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 8, 2019 Author Share Posted November 8, 2019 Adding the cap strips. Joining the wing halves. I added the wing tip to the first half of the wing before joining - really must tidy the bench! More later... Quote Link to comment Share on other sites More sharing options...
christophe dauvergne Posted November 9, 2019 Share Posted November 9, 2019 Hi very good job 👍 i will make one as soon have you got the file to put the laser diode regards christophe Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 10, 2019 Author Share Posted November 10, 2019 Hi Christophe. I will send you the file when I am next on my other computer. Are you going to do a build log? Geoff... Quote Link to comment Share on other sites More sharing options...
christophe dauvergne Posted November 11, 2019 Share Posted November 11, 2019 Hi Geoff i don’t think build a log but why not I’ll would like make my laser machine in first time to cut parts of woods christophe Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 11, 2019 Author Share Posted November 11, 2019 As I am building the Oodalally for electric power, I needed to alter F1 so that the battery can pass through it to help with obtaining the correct CofG without (hopefully) having to add extra weight up front. I swapped out the laser for my dremel and cut out these parts: Here is the machine in action: I didn't get the measurements spot on, so it needed a bit of fettling to put together: More Later... Edited By Geoff Gardiner on 11/11/2019 11:37:04 Edited By Geoff Gardiner on 11/11/2019 11:47:07 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 11, 2019 Share Posted November 11, 2019 That is very neat. Beats my power jigsaw Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted November 12, 2019 Author Share Posted November 12, 2019 Thanks Peter. I'm still tweaking the settings but I think it is going to be very useful. Started on the fuselage this morning: More later... Quote Link to comment Share on other sites More sharing options...
christophe dauvergne Posted November 12, 2019 Share Posted November 12, 2019 Hi Geoff Have you forgotten me Christophe Quote Link to comment Share on other sites More sharing options...
