911hillclimber Posted March 26, 2020 Share Posted March 26, 2020 Come over here from the Vintage Plane section having just finished a Standard Buccaneer. My next plane is a Dumas Supermarine rubber plane, 24" span as picture. I have the plane on my bench ready to build, but.. I want to convert the plane to electric and 3 ch radio using micro parts. That is my first problem, finding small servos/esc/batt and motor for this 200 gram plane. I have a Spekrum DX6 Tx so would like to use it and a compatible RX. I expect to get to the radio on the plane through a hatch under the belly of the plane/wing Can anyone guide me please to a source or spec for the above parts? Thanks, Graham. Edited By 911hillclimber on 26/03/2020 12:59:20 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted March 26, 2020 Share Posted March 26, 2020 That's a challenging model in larger sizes, I wish you luck converting that and flying it. I think you need to look at the equipment used in commercial micro models, especially the stabilised receivers - AS3X? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted March 26, 2020 Share Posted March 26, 2020 **LINK** **LINK** Quote Link to comment Share on other sites More sharing options...
911hillclimber Posted March 26, 2020 Author Share Posted March 26, 2020 Thank you both. Ref flying, there are 2 planes converted in the USA and videos of first flights look good (in still air) Stability 'control' would be good! Is there an RX with Stab control for the Spekrum DX6? Ref Vintage Aircraft. Denis, you have allowed me to see the tree in the wood! Looked several times at their Power Packs and you made me read the PackA spec closely. They use this kit in their Sharkface park sports model which has a heavy build (lots of sheet) and a 22" span. The servo's are really small, smallest I've found to date and the motor has the esc all there.' just needs a battery. I contacted them 2 days ago but no response, but it looks like their pack will be a good plan B so to speak. 4-Max are looking to pull a pack together for me as Plan A. Thank you both very much! Graham. https://youtu.be/9gT8vScKID8 Edited By 911hillclimber on 26/03/2020 15:23:20 Quote Link to comment Share on other sites More sharing options...
Stuphedd Posted March 26, 2020 Share Posted March 26, 2020 I go the way Bob Cosford suggests , UMX with AS3X I used an Sbach donor! Buy as used unit from ebay /? and just put the bits into you airframe . I did this with my Great Lakes and it flies likeit should . Quote Link to comment Share on other sites More sharing options...
911hillclimber Posted March 26, 2020 Author Share Posted March 26, 2020 Thank you, that plane looks really nice. I had contemplated using a 'foam plane as a donar, but I could not feel sure that the parts would work well or fit into the tight fuselage of the Supermarine. Did you find the servos small? You can get a new Sbach cheaper than the power kit from Vintage models. Very interesting! Quote Link to comment Share on other sites More sharing options...
BackinBlack Posted March 26, 2020 Share Posted March 26, 2020 Perhaps one of these or similar: Spektrum Rx with ESC and servo A new version with AS3X is due in a few months. Spektrum AR6410L Good Luck Quote Link to comment Share on other sites More sharing options...
911hillclimber Posted March 26, 2020 Author Share Posted March 26, 2020 Thank you BinB, that looks too good to be true! If I am right, the part will bind with my 5 year old Spektrum DX6, have stability control, all integrated in a tiny package, and at that price it is a gem! I'll ask them a few questions. Thank you for your help. Graham. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted March 26, 2020 Share Posted March 26, 2020 Posted by 911hillclimber on 26/03/2020 16:30:40: Thank you BinB, that looks too good to be true! If I am right, the part will bind with my 5 year old Spektrum DX6, have stability control, all integrated in a tiny package, and at that price it is a gem! I'll ask them a few questions. Thank you for your help. Graham. Look up DSMX by Orange and Lemon too Graham, just to appreciate that other makes can be driven by the DX6 Quote Link to comment Share on other sites More sharing options...
Stuphedd Posted March 26, 2020 Share Posted March 26, 2020 Hi hillclimber If you get a Used Umx like the Sbach it comes complete with motor, RX, servos , lipos were £3 for 5 !!!! from Hobby king last month 180 mha , and I use an OLD dms2 Dx7. no brainer really , , and new rxes were availiable direct from china for £23 post free The AS3X sort , bargain ! fleabay ! Lemon stuff is very good , if not excellent ! cheers Quote Link to comment Share on other sites More sharing options...
911hillclimber Posted March 26, 2020 Author Share Posted March 26, 2020 They look good, but the AR is the complete package on one card, so with the tight space in this plane ideal. Going to call about it tomorrow and see when the part with stability will be available. Quote Link to comment Share on other sites More sharing options...
911hillclimber Posted March 27, 2020 Author Share Posted March 27, 2020 Interesting call to them today with a good solution. will update as it materialises. Quote Link to comment Share on other sites More sharing options...
911hillclimber Posted March 31, 2020 Author Share Posted March 31, 2020 I am following the advice of getting a damaged small park flier and using the radio/motor/batt etc for 3 channel. One shop think they may have a plane or two damaged in postal transit, but awaiting a call back. however, in the same light, anyone on here who might have a donor plane preferably using the integrated sektrum servo/rec system, I would like the who lot to use parts from. Hope somebody can help? Quote Link to comment Share on other sites More sharing options...
911hillclimber Posted April 8, 2020 Author Share Posted April 8, 2020 Looks like the offer of selling me a donor plane has not made it, so awaiting 4-Max to finalise the list of micro parts, George is awaiting the servos. Quote Link to comment Share on other sites More sharing options...
