Nick Somerville Posted April 1, 2020 Share Posted April 1, 2020 With time to twiddle my thumbs a bit this last week I have been thinking about my next build project and somewhat to my own surprise seem to be narrowing towards a warbird. Something to do with watching YouTube videos of models on super sounding fly pasts at low level I guess. So I haven’t built a model with retracting UC before or one with flaps (scale glider aside) so plenty of new things to look forward to. I would prefer a kit with plenty of modelling but I am wondering whether it would just be a cheaper option to buy a proven artf like an ESM warbird. That said its still not going to be cheap as retracts appear to be almost as much as the model. Anyway, cost aside for the time being I would appreciate any suggestions for a first warbird that would suit a 30-40cc four stroke. Also suggestions for suitable retracts. So far a LA7 is on my list. Quote Link to comment Share on other sites More sharing options...
Scott Edwards 2 Posted April 2, 2020 Share Posted April 2, 2020 For a 30/40cc engine you're looking at a model around 80 inches span perhaps. That's around 1/5 scale, so lots to choose from ! Cut kits from Belair or Fokker RC particularly. For retracts, a lot of people are looking at the Electron range from France. A self built 1/5 warbird will add up to about £1500, it's surprising, but engine, retracts, electronics, wood, covering, paint, glue, spinner and all those little bits really add up. An ARTF will probably work out much cheaper, and be in the air quicker. A basic 1/5 scale warbird build is around 300 hours, a lot more if you go mad with it. The ARTF probably about 50 hours What you get with self build is creativity, you can select your own scheme, and preferred construction methods. You can also bask in that amazing feeling of self satisfaction and pride that YOU built that. Quote Link to comment Share on other sites More sharing options...
David Davis Posted April 2, 2020 Share Posted April 2, 2020 My experience in this area is limited to the Harvard trainer! That said, I'm informed that of all of the warbirds, the FW 190 is anongst the best. Quote Link to comment Share on other sites More sharing options...
Jon H Posted April 2, 2020 Share Posted April 2, 2020 Nick do you have any warbird experience already? I only ask as many come a cropper with warbirds as they require a different technique, different setup on the control and generally tend to be rather porky vs a sport model. I dont know your experience level so apologies if its all under control but in general if you cant nail every landing exactly the same and more or less perfect you are going to have trouble as retracts just wont wear it. If you have not flown a warbird before you might do better to start on a slightly smaller ARTF. Scott has the scale of the model about right. 80 inches is the 30-50cc sort of bracket and there are plenty of options available but as already discussed its a case of kit vs artf and all the rest of it. Its a shame the ESM La7 is not still available as i love mine and its a great intro into larger warbirds as it is, as these things go, very forgiving. However, if you push it too far there is a very steep cliff edge and it will gladly fall off it for you. Back to my point on retracts, i have only made 3 truly bad landings with my La7 in 10 years of flying it and the retracts have been out of it...3 times. In terms of warbirds that fly well the P47 has to be top of the list. Massive wings, a fuselage like a whale to get all the gear in, wide undercarriage and nicely proportioned. The P51 isnt bad either and Spitfires fly really nicely at the larger scales. The Jerry bates Hawker Tempest II is a great model as well and my ESM SeaFury is great but demands respect on landing as it weighs a ton. Hellcats tend to fly well but twist retracts are a pain in the backside. Corsairs are mixed bag. However, models like the early Spitfire, Hurricane, Fw190a series etc can be problematic with balance as they all have short noses. P51's and late Spitfires have longer noses which helps. Bigplanes in the nethlands happen to have a sea fury in stock. Price includes retracts which is not bad **LINK** You need a bigger engines though, mine has a laser 360 and that hauls the 24lbs around no problem. They also have an ESM P47. **LINK** never flown one but my other ESM models fly well. I would stick a 180 in this There is the seagull P47. Its big at 80 inch, needs a 40-50cc really. I would use a 300 or 360 if i got one **LINK** and finally there is the Hangar 9 P51 20cc. A 150 4 stroke would do very well and there are two of these at my club flying with laser 155's. **LINK** We could get into kits as well? Quote Link to comment Share on other sites More sharing options...
ASH. Posted April 2, 2020 Share Posted April 2, 2020 As Jon says, Thunderbolt P-47 fly very well. No nasty vices! Seagull do one in 20cc size, it's a manageable size. Fit a good 120 4st or Laser 100. There is an excellent thread on here by Tim Flyer. A Chipmunk is classed as a warbird and was a trainer in full- size. Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted April 2, 2020 Author Share Posted April 2, 2020 Thanks for the replies, all very helpful indeed. In answer to Jon's query re my experience....... Well not much really in power as after becoming a fairly competent power flier in the mid 80's I moved on to building large scale gliders. A mixture of 1/4 scale glass ships and plan and scratch built 1/4 scale vintage gliders, which I competed with around the country for 15 years or so. Anything but a well judged landing is not an option with those big gliders, though they don't fly that fast with the airbrakes deployed. Have had a long break from model flying due to being fully absorbed by cross country paragliding but have now rekindled an interest in powered models. I have a Slec 1/4 scale Stampe and a Pilot Extra 330sc, both with laser 180's. Barely flown them much though as prior to the lockdown the weather was pants. So yes the step to flying a warbird will be more of a leap, but by the time I have one built I hope to have polished my landings with the two models I have. I have seen quite a few ESM warbirds listed on the YTinternational.co.uk website. Anyone brought from them? Quote Link to comment Share on other sites More sharing options...
kc Posted April 2, 2020 Share Posted April 2, 2020 LA7 - have you seen the David P Andersen free plans? Lots of good stuff on this website. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted April 2, 2020 Share Posted April 2, 2020 Hi Nick ,I too would like to build a warbird with trepidation. I decided to lower my sights and build Peter Millers Werewolf instead. Cheaper, easier to build, and paint, plans and wood, canopy etc readily available, and as all Peters models, guaranteed to fly well. Just a suggestion. Cheers Quote Link to comment Share on other sites More sharing options...
Jon H Posted April 2, 2020 Share Posted April 2, 2020 Posted by Nick Somerville on 02/04/2020 12:20:22: I have seen quite a few ESM warbirds listed on the YTinternational.co.uk website. Anyone brought from them? If you are well versed in gliders that will help as rudder control is important on warbirds. The thing that is likely to come as a shock is the weight, drag and sensitivity on the elevator. Very low elevator rates are needed and i can loop my sea fury on probably 3mm of movement. As for YT, they are no longer trading as ESM shut down. Bigplanes.nl have a few scraps left but once they are gone thats it. The ESM models fly well but need a little work to tidy them up. If you expect to shake the box and have it build itself thats not going to happen! I have 6 ESM models in total with 3 flying (la7, P39 and Sea Fury) and 3 (a6m, Fw190, Bf109) waiting their turn. They all fly well and big planes price of about 650 quid for an 80 inch sea fury with retratcts is not a bad price at all. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted April 2, 2020 Share Posted April 2, 2020 T-28 Trojan is a good warbird. Also, as said, many are quite good, P47, I have quite a few of them and can't think of many problems, but the T-28 is ideal if your field is not perfect, as had many problems getting off long damp grass. Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted April 3, 2020 Author Share Posted April 3, 2020 Well after plenty of thought and helpful advice I have decided on a P47. Ironically the only plastic kit I have had since a boy, given by my son some years back, is a P47 1/72 Revell kit. Been lost at the back of a cupboard and unmade of course. Unless someone has a better suggestion I am going to order a Belair Nick Ziroli plan pack for his 70” sized version that should suit one of my Laser 180’s. He has plans for a larger one but that is well over 12kilos so not very practical. I have looked hard for a 80” p47 as I would like a v twin fourstroke but can’t find a plan pack or wood kit and am not after an artf model. If anyone has experience of this build I would be grateful for any advice. Particularly re which type/make of retracts to choose. Quote Link to comment Share on other sites More sharing options...
Jon H Posted April 3, 2020 Share Posted April 3, 2020 topflite used to do an 80 inch job as a kit but they are rare now. We used to sell 300v's for them and they flew well at 20lbs. The next step up for ziroli is 92 inch and thats a real whopper! A friend has the old hangar 9 80 inch artf thunderbolt and the fuselage is already like a beached whale at that size. For the 70 inch version i think belair list some retracts for it. My preference has always been air retracts as i have had/seen way too many problems with electric retracts. I am told by a customer that electron retracts are good, but as they are made in spain i suspect it will be all quiet due to lockdown. Be aware that you might need 85 degree units and not 90. And i know its getting ahead of the game but there is no need to go mad on the radio fit either. If it were mine i would use a single subc 6v nimh battery through the beefy switch futaba do. I would then use probably nice quality 3.5kg servos on the ailerons and rudder, perhaps 5kg on the elevator and flaps. To be fair standard futaba 148's would do for rudder and ailerons. Warbird control surfaces are quite small and you dont move them much so there is little need to go crazy with servos. Just doing some window shopping i would be happy with savox 351 4.1kg (11 quid each) servos on aileron and rudder, then savox 352 6.5kg servos (16 quid) on elevator and those barn door flaps. I already use the 351 as my P39 rudder servo and have 352's in my Sea Fury, Acrowot XL...something else...I dont remember. I just know i have lots of empty boxes in my drawer so they must have gone into something! Quote Link to comment Share on other sites More sharing options...
flight1 Posted April 3, 2020 Share Posted April 3, 2020 If you don't know already there are a couple of builds on the rcscale builder site you would need to register to access buts it's a very good site for scale builds and info Also there is the Brian Taylor version (better i think) a bit bigger but I still think in your engine range 35cc see sarik Edited By flight1 on 03/04/2020 18:22:01 Edited By flight1 on 03/04/2020 18:23:53 Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted April 3, 2020 Author Share Posted April 3, 2020 Yes I’m registered for the rc scale builder forum so that’s the evening read sorted. I’ll be looking at the B Taylor plan too. As Jon mentioned Belair do specific retracts for the Ziroli build so will have to see what is available for the Taylor P 47 Quote Link to comment Share on other sites More sharing options...
flight1 Posted April 3, 2020 Share Posted April 3, 2020 I would get the Brian Taylor plans and have a look as £25 for them is not a big loss against £70 for the other. I do believe Unitracts International do retracts for the BT plan also some build info here Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted April 5, 2020 Author Share Posted April 5, 2020 Well I have read some great build threads this weekend and have decided that the above suggestion for the B Taylor build will best suit me, especially as I already have a laser 180 sitting in an Extra 330 sc, I bought 2nd hand, for the purpose of honing my flying skills. By the time the P47 is built enough to be ready for its engine I can swap it out. i will be aiming for a sport scale model that can be flown regularly and not a B Taylor masterpiece, or like some of the incredible models I have seen in the build threads. With the short noses of warbirds I know that adding considerable weight up front is often needed. Would it be sacrilege to add a few centimetres to the front to help mitigate this? Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted May 3, 2020 Author Share Posted May 3, 2020 So after a bit of a frustrating wait my plan pack arrived 10 days ago and a start has been made on The Brian Taylor P47. Nice looking plans on 3 sheets and a decent pile of wood and laser cut time saving parts. Almost a kit, less the hardware. The plan shows an upright Laser 150, but as I have one it will be a Laser 180 going in that will be inverted. Still bags of room at the front to relocate plan shown tank position. I am going to work on the fuselage till its about 60% planked and then make a start on the fin rudder and wings. Electron retracts going in and am considering having a go at making the tailwheel retracts as per the plan, unless someone has a cheap ready made suggestion suitable for a 2 inch wheel. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 3, 2020 Share Posted May 3, 2020 but that workbench is way too tidy......................... Quote Link to comment Share on other sites More sharing options...
Jon H Posted May 3, 2020 Share Posted May 3, 2020 You didnt hang about! Its looking really good, and to answer your earlier question i would leave the length of the nose as is. The P47 has a good nose on it (vs a 190 or spitfire) and with the big 180 it should be ok. What you could also do is mount the servos where the tank would normally be as your tank will be much lower it opens up this space. I did this on my little Hurricane Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted May 3, 2020 Author Share Posted May 3, 2020 Yes had abandoned the extra length idea after receiving the plans. Brian’s notes say he didn’t need any ballast to achieve the correct c of g so with the extra weight of the 180 should be fine. There certainly is bags of room up front compared to your Hurricane Jon. Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted May 10, 2020 Author Share Posted May 10, 2020 ” but that workbench is way too tidy...............” Well it was for a while. Looking a bit more normal now 😂. Somehow mess = progress though. That razorback is a challenging shape with multiple compound curves... and the section by the back of the canopy took more than one go to interpret the plan correctly. Quote Link to comment Share on other sites More sharing options...
Jon H Posted May 10, 2020 Share Posted May 10, 2020 Once its fully sheeted and has the horizontal stab on its likely to resemble moby dick. Dont be worried, just try not to harpoon it Quote Link to comment Share on other sites More sharing options...
Gary Clark 1 Posted May 10, 2020 Share Posted May 10, 2020 Following along Nick. I have the parts for this tiny loft waiting to go so this could be the motivation I need to get going! Gary Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted January 29, 2021 Author Share Posted January 29, 2021 I have all but finished the 'First Warbird' and have much enjoyed the process so am thinking of a second one to follow. I am thinking of a Sea Fury as I really like the shape of the aircraft and as I live just up the road from Yeovilton, I have the full size nearby to help get it right. Looking around I have seen a 81" span Sea Fury plan from Jerry Bates but all others plans are much bigger beasts that won't suit my budget, workshop size or local flying site. If anyone has any knowledge of the Bates offering and can comment it would be appreciated. There are a few build logs on RCScalebuilder but I was a bit surprised at the engine sizes being used for a model of the size. Perhaps that's the American way. One even had a Kohlm twin 100 which had been put in as a replacement for an inline twin 80cc Rotomotor four stroke that was apparently marginal!!! Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 29, 2021 Share Posted January 29, 2021 The Fury has a short span compared to its length 1:5.6 - 80" span and a length 68.75" They certainly fly well Jerry suggests 45cc + Check Out Sep Uiberlacher plans, very similar style to Brian Taylor. Cheers Danny Quote Link to comment Share on other sites More sharing options...
