John Davies 14 Posted July 12, 2020 Share Posted July 12, 2020 Hi Following some very useful advice previously from this forum, I have now completed the building of a Gentle Lady sail plane as my first entrance into electric powered model planes. I have searched the many forums on suggestions for the right motor/ battery/ESC combos and have to confess am more confused particularly with some of the USA suggestions. So this is where I am today. I am looking at the 4Max PO-2826-1046 motor with its 1040 Kv with a 30A ESC using either a 9x7 or 10x6 folding prop but not sure about battery. Would a 3S-1500mAh suffice or do I need something bigger? I can see cooling may be a problem as everything is enclosed in a small space. Any help or suggestions appreciated. Plane has come in at 22ozs with its 6ft wing span as spec'd. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted July 12, 2020 Share Posted July 12, 2020 Max continuous current for that motor is 15A so a 3S 1500mAH battery should be fine. For comparison, my Radian draws 17 amps and runs on a 1400 mAH battery, I can get multiple 30 second full power bursts to climb to height followed by several minutes gliding between power runs. A good quality 10x6 folding prop and spinner (Aeronaut or Graupner) should be a good starting point and you are right about cooling, make sure that there is adequate inlet and egress area for cooling. It would be a good idea to check current draw on full power with an ammeter/wattmeter, you may find that you need to go up or down a prop size. Quote Link to comment Share on other sites More sharing options...
John Davies 14 Posted July 12, 2020 Author Share Posted July 12, 2020 Many thanks Shaun. I'm starting to appreciate the differences and requirements for electric motors compared to my old nitro engines. Quote Link to comment Share on other sites More sharing options...
robert chamberlain Posted August 17, 2020 Share Posted August 17, 2020 Hello all,--Many years ago the folks who made the gentle lady( Carl Goldberg?) also made a clone called the "Electra" -basically a GL with a much wider fuselage . I still have mine but gave up trying to fly it on 7 NiCads and a car motor. Master Airscrew made a 3 to 1 gear box witch snapped onto the front of the bat (which raised the thrust line somewhat) but by that time I had gone back to IC engines, never having tried that combo. After having messed around with a GL, I decided it would just be easier to go find my dust covered Electra. I have heard that so many have easily convert a GL to electric I guess I could go either way. Nah, I'm going Electra! I have not seen the Electra kit in a long time but did see a GL kit for $65 recently in a Hobby shop last January-------Bob B. Quote Link to comment Share on other sites More sharing options...
