Stephen Jones Posted August 13, 2020 Share Posted August 13, 2020 Hi, Just thought i would share with you how i make my blades for Auto gyros. There are many ways to shape a blade i am sure, but for me i found it hard work sanding square spruce to the right profile and trying to get a even profile full length. So i found that B&Q sell 6mm pine beading just the same length as a sheet of balsa. So i glued two to the edges of a sheet of Balsa 4 inch wide. This was divided up into four blades. I also decided to try a all Balsa blade with a small 5mm x 1.6mm spruce Leading Edge. I used my router to make a slot into which i can glue the spruce strip. Then cut up into four Blade Blanks. Steve Edited By Stephen Jones on 13/08/2020 17:44:46 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 13, 2020 Author Share Posted August 13, 2020 The Profiler, So out of some spare wood i decided to make a slide bench to Profile my blade and all it cost me was some drawer runners . Of coarse you need a blade to start of with onto which i stuck some sand paper so that it`s profile could be sanded into a hard block of foam. And then i stuck some sand paper onto the foam profile. Steve. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 13, 2020 Author Share Posted August 13, 2020 And here are the finished Blades. Well sandes to shape . I have to balance them and add fixing hole Ect. Steve. Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted August 16, 2020 Share Posted August 16, 2020 Steve, Well thought out, have you tried the lighter blade with the hardwood under strip on the LE edge yet? Rich Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 16, 2020 Author Share Posted August 16, 2020 Posted by Richard Harris on 16/08/2020 14:26:42: Steve, Well thought out, have you tried the lighter blade with the hardwood under strip on the LE edge yet? Rich Hi Rich, I have not tried them yet. I will be trying them on my lidl auto gyro . As i have some damage on mine due to learning to fly as i guess everyone else has done during the learning process. My main reason for wanting to try the new Balsa blade is due to how hard it can be on the sandpaper i have resorted to using a file in the past to get the leading edge to profile as spruce can be hard as nails. Also it occurred to me that the leading edge needs to be hard due to blade strikes and hard balsa is easier to sand. After all it is only the top of the bade we are sanding. Hobbyking blades where made out of foam with a plastic leading edge, I could also use a wider strip of spruce on the under side if i want more strength . I have found sanding the new balsa blades much quicker or it could be new new Profiler. I will let you know when i have tried Them. Cheers Steve, Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted August 17, 2020 Share Posted August 17, 2020 well done Stephen, hope your going to show us how you balance them please. ken anderson...ne..1..blades/balance dept. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted August 17, 2020 Share Posted August 17, 2020 I don't know if it applies to their spruce but when using B&Q hardwood mouldings for anything structural, check for joints as they are often made up of short sections scarfed together (not to aviation standards) and may not be strong enough. Edited By Martin Harris on 17/08/2020 21:29:42 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 17, 2020 Author Share Posted August 17, 2020 Hi Martin, Thank`s for pointing out that B&Q do scarf wood over a given lengths. As wood is a natural product it would be very difficult to get a 3 meter lengths of straight wood. So they do this with wood that is over a given length. It is easy to spot. However the wood i purchase is only sold in lengths of 900 mm. Which i checked before hand. But i agree it is something to look out for. Steve Quote Link to comment Share on other sites More sharing options...
David Oatham Posted August 18, 2020 Share Posted August 18, 2020 Hi Stephen, I like your idea. How have you used a drawer runner in your shaper, and how do you ensure that the prepared blank blade remains in the correct position during the sanding process? Cheers, Dave Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted August 18, 2020 Author Share Posted August 18, 2020 Yes, i could of explained it a bit better so her goes. Above you can see i have a small piece of worktop onto which i have screwed some 3x2 and on top of that a small piece of skirting board that will remain stationary as both a guide and for my sanding tool to be mounted. Next to the stationary board is a white piece of skirting board and that is on two Drawer runners so that it will slide back and forth with no slop as it is butted up against the stationary board. I marked it`s center so i know where to position my sanding block . I now marked a perpendicular line from the edge of the skirting board as a guide. now i know where to place my working blade the one with the sandpaper on, i used 3 small pieces of double sided tape to hold the blade in place making sure the blade is lined up with my lines. Sliding the white board back and forth to make sure it is correctly lined up 1st it was stuck into position. I then mounted a foam block onto a hinged arm placed over the center line and Centre up with the blade. Now all that is needed is for me to draw lines around the blade i stuck to the board and for me to slide the board back and forth with the sanding block above the blade this would in turn sand the profile into the foam i would keep sanding until the foam block is in contact with the sliding board. I then remove my sanding blade as it`s job is done. I now stick sandpaper onto the foam block. Now to make a fresh blade i stick my blank blade carefully onto the white board making sure it is in the correct Orientation and in the lines i drawn on the board. Simply sliding the white board back and forth with the sanding block held over it . I best do a video to show how it`s done. I hope this helps my head is pickled at the moment. Steve. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted September 13, 2020 Author Share Posted September 13, 2020 Posted by Richard Harris on 16/08/2020 14:26:42: Steve, Well thought out, have you tried the lighter blade with the hardwood under strip on the LE edge yet? Rich Hi, I can confirm that the new lighter blades work just fine. Steve. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted September 14, 2020 Author Share Posted September 14, 2020 Posted by ken anderson. on 17/08/2020 19:14:53: well done Stephen, hope your going to show us how you balance them please. ken anderson...ne..1..blades/balance dept. I am working on that now. steve Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted September 14, 2020 Author Share Posted September 14, 2020 Just thinking if it would be better to start a fresh on this. To show how i made the Profiler and how it works or just jump into how i balance them Steve Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 15, 2020 Share Posted September 15, 2020 if you have the time etc...do both please. ken anderson...ne..1..blades dept. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 24, 2020 Author Share Posted October 24, 2020 Hi, I have done a video on the preparing of the blades. Maybe easier to understand. Steve. Quote Link to comment Share on other sites More sharing options...
