Nigel R Posted April 9, 2021 Share Posted April 9, 2021 On 25/03/2021 at 10:55, Den Moran said: I have a Super Tigre 2000 25cc 15 hours ago, Den Moran said: trying to find out what ignition battery to use I'm confused, surely it just needs a normal glow stick on starting up? Quote Link to comment Share on other sites More sharing options...
Den Moran Posted April 9, 2021 Share Posted April 9, 2021 No,it is not glo, it has a spark plug thingy! Quote Link to comment Share on other sites More sharing options...
Den Moran Posted April 9, 2021 Share Posted April 9, 2021 Thanks, Frank, but I still need to know what the battery is called etc. For example I use some 2200mah 3S batteries for my foamies. They are called '2200mah 3S batteries' - it's the NAME I do't know, please. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 9, 2021 Share Posted April 9, 2021 So your 2000 has been converted to run on petrol/oil mix and has a walbro type carb ? The ones I have seen only have a 4 cell receiver type pack to power the ignition unit. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 9, 2021 Share Posted April 9, 2021 3 hours ago, Den Moran said: Thanks, Frank, but I still need to know what the battery is called etc. For example I use some 2200mah 3S batteries for my foamies. They are called '2200mah 3S batteries' - it's the NAME I do't know, please. OK for the receiver and servos, unless the model is fitted with high voltage servos then you would need a 5-6volt power supply, either 4/5 cell Nimh (I only use sub C cells on large models), 2s Life (if servos are good for 6v) or Lipo and BEC. High voltage servos are OK on a 2s Lipo. You'd need to check what voltage the ignition can run on, some are 4.8v only (4 cell Nimh, AA cells are fine) some will also rated for 4.8 to 7.4v, so 4/5 cell Nimh, 2s LiFe or 2s Lipo. Quote Link to comment Share on other sites More sharing options...
Den Moran Posted April 10, 2021 Share Posted April 10, 2021 My apologies to all! Yes, I have a Super Tigre which is glo + stick as per. I also have a 30cc petrol engine from an ultimate that is petroil mix, and has a spark plug. I wanted to know what battery was suitable for the ignition system on the latter, is all. It's old age! P.S. anyone got any good tips for accurately mixing 25:1 petrol:two-stroke ol mix, please? Thank you, everyone, I am getting there, honest! Quote Link to comment Share on other sites More sharing options...
Chris Channon Posted April 10, 2021 Share Posted April 10, 2021 Good morning Den, i use a fuelmixing bottle from ebay , has all the markings/scale on the side for the correct fuel mix. Have a great day Chris.C Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted April 10, 2021 Share Posted April 10, 2021 It might help if you could let us know the details of the ignition system. Some of them can be sensitive to the type of battery used - voltage and/or power delivery capability. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 10, 2021 Share Posted April 10, 2021 Re fuel mixing, most garden machinery shops sell mixing bottles marked to give various ratios, also some oil bottles have the amount of oil required for a given mix on the rear label, the deluxe materials one has. As for the ignition battery, if in doubt just use a 4 cell Nimh battery, while the older ignition units were only rated for a 4 cell Nimh battery the more modern ones are fine with both 4 cell Nimh and 2 cell Lipo. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 10, 2021 Share Posted April 10, 2021 1 litre 1000 ml / 25 = 40 ml of oil per litre petrol. 50 - 1 = 20 ml per litre For my Zenoahs I add 100 ml Bel-Ray oil per 5 litres of petrol. D.D. Quote Link to comment Share on other sites More sharing options...
Den Moran Posted April 12, 2021 Share Posted April 12, 2021 Thanks, everyone! Quote Link to comment Share on other sites More sharing options...
