tigerman Posted November 16, 2020 Share Posted November 16, 2020 Have a EDF and only have a 7 channel receiver .I have use all the channels up Throttle, Elevator ,Ailerons Rudder ,Retracts ,Flaps and Gyro I need to add the BEC connection ,is it OK to connect a Y lead to the Throttle and BEC connection and plug that in the receiver using only one channel ?.Or I am using the Futaba 3008 with S Bus can I connect the BEC to the S Bus socket ? Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted November 16, 2020 Share Posted November 16, 2020 A BEC can be connected directly to the power-lead plug or via a "Y" lead. I assume you have an opto ECU and need power for the radio . Dont know anything about S Bus Quote Link to comment Share on other sites More sharing options...
