Marutaka project
kevin b
Hi Kevin,
looking at it it seams the only options for fitting the motor is inverted or upright, 4st motors are popular for scale now mainly for noise reduction, I thought it would be better to have a side mounted motor in a radial cowl to make tank positioning better. Looking good so far, I thought you would sunburst red dye on a Japanese plane.
Cheers Eric.
1 hour ago, Eric Robson said:
Hi Kevin,
just looked at the Zero drawings and a 61 two stroke does fit nicely in the cowl, at the current price of balsa I think that block on top of the fuselage where the guns go would be better as an ABS moulding.
An ABS moulding would be good, but I don't think the demand would justify the time and costs.
I built it up from off-cuts, the same as the big bits of balsa at the tail will be.
Nothing much to see at the moment.
The wings are being covered and the fuselage planked.
The cowl has been tried on and the elevators made.
I have also been doing some adding up as well.
Does anybody want the uncovered airframe for less than the cost of the wood ?
  • 3 weeks later...
  • 4 weeks later...
5 hours ago, EarlyBird said:
Yorkshire I would need to renew my passport to cross the bridge then there is the risk that I would not be let back into Lincolnshire ?
East Leeds?
Nay, up int' dales near Pateley Bridge.
Lincolnshire, you say ?
Well the border guard might let you in. you might have to bring some of your sausages for his dog though.       :classic_biggrin:
  • Haha 1
