SIMON CRAGG Posted December 9, 2020 Share Posted December 9, 2020 The 70mm 12 bladed EDF unit (3048 /2000kv 6s), unit has given up in my Hobbyking Flycat. Surprise, surprise HK do not stock any spares. I am going round in circles trying to find a replacement which would produce the same amount of thrust. Can anybody help please? Quote Link to comment Share on other sites More sharing options...
Brian Hammond Posted December 9, 2020 Share Posted December 9, 2020 Hi Simon,rapidradio have hobbywing 80amp escs in stock,I,ve got a couple of them and they seem to be ok. Quote Link to comment Share on other sites More sharing options...
Brian Hammond Posted December 9, 2020 Share Posted December 9, 2020 PS sorry I did not read it properly ,I will go and sit in the naughty corner. Quote Link to comment Share on other sites More sharing options...
Fun Flyer Posted December 9, 2020 Share Posted December 9, 2020 Have you tried 4 Max Simon? I've always found them very helpful. Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted December 9, 2020 Author Share Posted December 9, 2020 Posted by Fun Flyer on 09/12/2020 19:34:08: Have you tried 4 Max Simon? I've always found them very helpful. Thanks for the heads up on 4max. They have got a d2842 - 2300kv which looks a possibility, not sure it would as good as the 3048 - 2000kv it had in it to start with. HK do not quote thrust or total output, which is frustrating when trying to find a replacement. There is always the Dr Mad Thrust! b3048 -2300 which looks a bit of a beast......but out of stock as usual! Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted December 10, 2020 Share Posted December 10, 2020 Hi Simon . Quite a few available on eBay for not a lot of money . I bought one about eighteen months ago for a HK Viper I was given . All looked ok but it did need balancing . If you don't balance them they sound awful and scream like the early five bladers . Now gives good thrust and a great sounds. I opted for a 4s unit but there are still plenty of 6 s units on there. Worth a look ? Edited By Engine Doctor on 10/12/2020 10:37:10 Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted December 14, 2020 Author Share Posted December 14, 2020 Posted by Engine Doctor on 10/12/2020 10:35:02: Hi Simon . Quite a few available on eBay for not a lot of money . I bought one about eighteen months ago for a HK Viper I was given . All looked ok but it did need balancing . If you don't balance them they sound awful and scream like the early five bladers . Now gives good thrust and a great sounds. I opted for a 4s unit but there are still plenty of 6 s units on there. Worth a look ? Edited By Engine Doctor on 10/12/2020 10:37:10 Thanks for that. I have tried both dynamic and static balancing, without much success. There appear to be many ways to do it!. Please can you explain the way you balance a twelve blade EDF?. Quote Link to comment Share on other sites More sharing options...
Geoff Parkes Posted December 14, 2020 Share Posted December 14, 2020 Simon, i have tried all sorts of edf units, if 50mm i go for the FMS 4 s units, but dont run them up holding them, any pressure on the fan case will force the blades to fly off, anything above this i go for Chain-sun units from RCCastle in China, superb service and if you pay for air mail-only a few dollars more they usually arrive in14 days, the fans are balanced so you get that turbine sound, there is a company in France Turbines rc i think , they are worth alook. Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted December 14, 2020 Author Share Posted December 14, 2020 Posted by Geoff Parkes on 14/12/2020 08:53:58: Simon, i have tried all sorts of edf units, if 50mm i go for the FMS 4 s units, but dont run them up holding them, any pressure on the fan case will force the blades to fly off, anything above this i go for Chain-sun units from RCCastle in China, superb service and if you pay for air mail-only a few dollars more they usually arrive in14 days, the fans are balanced so you get that turbine sound, there is a company in France Turbines rc i think , they are worth alook. I have got an FMS 3060/1900KV 12 Blade, on its way from Bangood. According to the reviews I have read, they are a good EDF. I would stillike to find a decent way of balancing the blades, you are right about holding the case......destroyed my last one by holding it! Hopefully there is another way. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted December 14, 2020 Share Posted December 14, 2020 Posted by SIMON CRAGG on 14/12/2020 08:35:26: Thanks for that. I have tried both dynamic and static balancing, without much success. There appear to be many ways to do it!. Please can you explain the way you balance a twelve blade EDF?. Hi Simon .There are a few good demonstrations on youtube of how to balance a fan. I bought a very light and accurate balance from rapid RC . Use this can get the fan near to balanced. I use thick cyano dripped into the blade near the hub so little chance of being thrown off . If you apply too much cyano just grind off with a dremel .Then fit fan to the shaft marking the fan and shaft with a magic marker and fit to motor . try to find a shaft adapter that is a really good fit onto the motor shaft thats important . Now spin it up . I use a servo tester as a throttle control and mark it to set to about half throttle .I then test the vibes when running with either a mobile phone with a vibe app or a piezo crystal connected to a volt meter. Move the fan on the shaft a small amount and retest . you may also have to move the shaft adapter on the motor shaft as these can be quite out of balance . When you find the sweet spot tighten the shaft fully. takes a bit of time but well worth the effort. Hope it helps . There are probably far more experienced EDF balancers on here who can advise . Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted December 14, 2020 Author Share Posted December 14, 2020 Posted by Engine Doctor on 14/12/2020 12:27:42: Posted by SIMON CRAGG on 14/12/2020 08:35:26: Thanks for that. I have tried both dynamic and static balancing, without much success. There appear to be many ways to do it!. Please can you explain the way you balance a twelve blade EDF?. Hi Simon .There are a few good demonstrations on youtube of how to balance a fan. I bought a very light and accurate balance from rapid RC . Use this can get the fan near to balanced. I use thick cyano dripped into the blade near the hub so little chance of being thrown off . If you apply too much cyano just grind off with a dremel .Then fit fan to the shaft marking the fan and shaft with a magic marker and fit to motor . try to find a shaft adapter that is a really good fit onto the motor shaft thats important . Now spin it up . I use a servo tester as a throttle control and mark it to set to about half throttle .I then test the vibes when running with either a mobile phone with a vibe app or a piezo crystal connected to a volt meter. Move the fan on the shaft a small amount and retest . you may also have to move the shaft adapter on the motor shaft as these can be quite out of balance . When you find the sweet spot tighten the shaft fully. takes a bit of time but well worth the effort. Hope it helps . There are probably far more experienced EDF balancers on here who can advise . Thank you so much for that. I think my prop balancer is way to course, so I'll have a look at the Rapid RC version. Great idea about the vibe app. which I have now got! Quote Link to comment Share on other sites More sharing options...
